Aluminium Teflon Coated Mouse Pad For Optical Mice
Hey, this is my first Instructable so I hope I didn't mess it up to bad! Let me know how ! did!
I recently got a new desk and and I had a lot of trouble with my optical mouse and its not functioning with the surface.
I did a lot of research and found that new optical mice work very well on Teflon coated materials. Immediately I bolted up the stairs and grabbed my mothers T-Fal frying pan.  Upon trying it out i realized how responsive and precise the mouse was now reacting (not to mention the Teflon pads of the mouse on the Teflon top is slick as butter) . After looking at some Teflon pads online i thought... "hey, there expensive.... imma build one of those." The next day I stopped at Wal-mart an picked up a Teflon Coated pan.
Step 1Materials
Materials
Materials: Any Teflon Coated pan really. I used a two burner skillet cause I wanted something fairly large.
This cost me about $25
50 comments
1-40 of 50next »
Aug 21, 2011. 6:39 PMcatmen says:
I have the same mouse!
Feb 7, 2010. 8:57 AMreptilezs says:
carbide tipped wood cutting blades cut aluminum very easily
Feb 20, 2010. 9:33 AMpedla says:
If you forget the fact that wood cutting blades have a lot less teeth so they tend to bite into ali rather than cut through it. A hacksaw will also cut wood BUT just use the correct tool and you will avoid stuffups and hopefully injuries. OK. Worksafe.
Feb 7, 2010. 8:01 AMnewbeak says:
Sorry to be negative,but I just use the surface of my computer desk,which is off-white in colour. I was using a pad,but found that my optical mouse worked fine without it..
Feb 10, 2010. 9:07 PMsrhadaham says:
some of us require a little more precision
Feb 10, 2010. 8:18 PMMr. Thrak says:
 whoahhhh.... that grinder is really dangerous
You should replace it with one that has a guard for cutoff disks. That way when the disk breaks, you won't end up with shards of hardened sand inside of you
Feb 10, 2010. 9:56 AMLuke401 says:
Couldn't you also use any solid surface and apply teflon spray? Teflon spray warningsTeflon info,  and you can buy the teflon sheets here, or at ebay.
Feb 4, 2010. 4:18 PMdchall8 says:
Feb 9, 2010. 9:33 PMTape-structable says:
Wow! Much cheaper than the skillet he bought, and already in shape.
Pretty large, so it could double as a laptop tray, and mouse pad?
Feb 4, 2010. 11:17 PMomnibot says:
Oooohh, well spotted.
Feb 9, 2010. 9:24 PMPeterParker says:
Yes, however that cookie sheet is 17"x14", bit of a large mousepad. Easier to shape down to size though I suppose.
Feb 9, 2010. 9:29 AMacornman says:
I am not sure what you mean by "pan" in the UK this would be like a skillet. Surely it would be cheaper and easier to buy a teflon coated Baking Sheet .These come with a nice safe edge all round and in small sizes . No cutting or work required ....use as is.
Feb 7, 2010. 9:07 AMblopez says:
you can buy teflon cookie sheets (IKEA has one for $6.99) that look just like your finished product. No cutting required.
Feb 8, 2010. 4:45 AMPhoghat says:
You did some nice work and I don't want to pee on your parade but he's right,
www.ikea.com/us/en/catalog/products/10133052
Feb 8, 2010. 7:26 PMBobthemonkey says:
Unfortunately, while that look almost exactly like the final product produced in this instructable, the picture gives no sense of scale. The pan linked to in the previous post has dimensions of 43 X 35 cm (17" X 14" for all you non-metric folks). In other words, it is roughly the size of an actual cookie sheet, not a mousepad, so it would not work very well for the purposes stated in this instructable. Just thought I would point that out.
-Bob
Feb 8, 2010. 11:48 AMdchall8 says:
Thanks for the idea here.  I looked at Wal-Mart for something like the Ikea cookie sheet but all they have is "jelly roll pans," the ones with the rim around like you started with.  What I bought was a regular, white, plastic (polypropylene) cutting board.  I got the 8.5x11-inch one for less than $4.  I've tried it on 3 mice and it works very nicely.  One of my mice has drag issues but works great on the poly cutting board.  The cutting board is, of course, much thicker than yours.  The cutting board is so slippery I might have to put something under it to hold it still.
Feb 7, 2010. 6:30 PMjohnnybgood91 says:
why didnt you just buy a teflon sill pat that use for bakeing.
Feb 7, 2010. 10:35 PMdanlab says:
"sill pats" aren't teflon, they are silicone (not silicon) with fibre glass reinforcement.
Feb 7, 2010. 9:45 PMarpruss says:
One can also buy a 0.060" bondable 12x12 teflon sheet on amazon for $12 (or thinner for less), and then use contact cement or, better, epoxy to attach it to a mouse pad, or some smooth plywood, or one's desk.
Feb 7, 2010. 7:57 PMFlyinseamnky says:
Nice! But why did you keep the back lip on it? Why not cut it flat, and perhaps chisle and sand a pit of the same size and width as your mousepad into the desk to inlay it into your desk? i want to do it now!
Feb 7, 2010. 7:01 PMshanmugammpl says:
 I remember using a Teflon "spray" from a compressed canister maybe that'd be a cheaper alternative and you can use the teflon for other purposes too!
Feb 7, 2010. 2:46 PMgnomesrule_42 says:
 Just a hint using some kind of greasy product in the filing stage will protect the teflon and trap any filings that come off during the process this should come off with the "bath" you give it later hope this helps :D
Feb 7, 2010. 8:38 AMpinkston32 says:
Wait, the mouse in the picture (MX Revolution) is a fancy laser mouse. Turn it upside-down and it says "Performance Laser". They track on practically anything except a few shiny surfaces like glass.
Feb 5, 2010. 6:50 AMHayabusa1337 says:
is that blood on that piece of wood next to the saw? in the first picture?
Feb 6, 2010. 11:49 AMAburame Shino says:
 Haha, yeah, he's right. That was from me refinishing some chair.
Alphonsus... I am your father!
Feb 6, 2010. 6:50 PMfrollard says:
"He told me enough; he told me you killed him"!
Feb 6, 2010. 8:32 PMAburame Shino says:
 Mr. Aburame, candlestick, workshop. Bwahahahaha!
Apr 4, 2010. 8:28 PMAburame Shino says:
Your mother is actually a fourteen-year-old Australian living in Portugal. Bwahaha.
Feb 4, 2010. 8:48 PMMaXoR says:
This is a good instructable. I have a question however, is that metal shiny enough to create jitters, or tracking when the side of the mouse is slightly lifted off the pad?
I know with a glossy finish counter top (Veneer over particle board), that my optical mouse will track, and also looses it's precision to an extent during design sessions in Photoshop, or Adobe Flash.
Let me know if you have any comment on this.
Feb 6, 2010. 1:16 AMMaXoR says:
Thanks a lot for actually doing a test of it. I am very intrigued indeed......
Good design, better look. Simple, clean, and obviously functional.
Feb 5, 2010. 8:29 AMEntropy512 says:
The Pan has a Teflon (not shiny) coating on the mousing side.
Feb 5, 2010. 9:44 PMtrike road poet says:
I made an outstanding optical mouse pad by simply getting one of those cheap plastic cutting sheets, and lightly running a sanding block with 600 grit sand paper over the surface.  The mico scratches are easy seen by the optical system and the mouse slides over the sheet easily.
The pad was heated with my wife's hair dryer while on the desk and the sheet lost all tendency to curl.  Flat, thin, slick and CHEAP!
Feb 5, 2010. 12:53 PMLightally says:
An interesting idea, but in my northern climate it would be too freakin' cold to use an aluminum mouse pad...it's cold enough hanging onto the mouse during the winter months nevermind running it on an aluminum surface!
Feb 5, 2010. 2:38 PMn0ukf says:
You could do what we do in northern Minnesota... turn on the furnace. ;)
Feb 7, 2010. 10:40 AMac-dc says:
Funny, yet true.
Seems like another instructable... USB heated teflon coated mouse pad.  Shouldn't be too hard either, put feet on the pad to raise it off the desk a quarter inch then epoxy 4 x 10 ohm, 2W resistors to the bottom in a 2 series x 2 parallel configuration for 10 ohms (500mA from 5V USB power) total, add USB connector and a couple wires.
Or turn on the furnace.  ;)
Feb 7, 2010. 11:30 AMjumpfroggy says:
Instead of resistors, would be better to use small 30 AWG gauge wire.  There's an instructable on here about doing juts that for jackets/motorcycle clothing.  This would be more even heating that resistors, just run a line around the edge, or a few loops where your palm will rest.
Metal objects tend to feel colder even at room temp, since they suck heat away from your body faster than less-conductive materials.  So even in a warm house, a heated aluminum mouse pad might not be a bad idea.
1-40 of 50next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Alphonsus
