Another Arduino Taffic Light
2,431
8
7
Posted
Introduction: Another Arduino Taffic Light
       After working with the arduino and not knowing what the heck I'm doing I made Another simple traffic light. I looked around the web to find one that looks about normal and came across none. They seemed too fast. So, I found and modded some code to make this work. The coding is pretty simple.
Step 1: The Parts
1 - Arduino (Obvious)
1 - Breadboard
6 - 270 ohm resistors
2 - Red LED
2 - Yellow LED
2 - Green LED
Misc. - Wires and Patients.
Step 2: Wiring
I used Pins 2 - 7 to make things easy. I don't know if it hurts the Arduino to use both PWM and standard pins or not but, It works.
I wired up the grounds to the ground rail through the 270 OHM Resistors, it seems backwards to me, because I'm and electrician, to go to ground through a resistor but, I have seen this alot.
I took the 6 LED's Anode lead and wired......
Side 1                                  Side 2
1 - Red to Pin 2                  2 - Red to 5
1 - Yellow to 3                    2 - Yellow to 6
1 - Green to 4                    2 - Green to 7
Step 3: The Code
I hope I didn't miss anything but if I did just comment.
The code I use seems simple, But I got confused so I had to get some help on figuring out what did what to who and how many.
There are some commented out sections that could come into play later.
void setup(){
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  pinMode(6, OUTPUT);
  pinMode(7, OUTPUT);
void loop(){
  digitalWrite(2, HIGH); //Side 1 Red        ON
  delay(100);
  digitalWrite(7, HIGH);  //Side 2 Green      ON
  delay(5000);
  digitalWrite(7, LOW);  //Side 2 GREEN      OFF
  // delay(2000);
  digitalWrite(6, HIGH);  //Side 2 Yellow    ON
  delay(2000);
  digitalWrite(6, LOW);  //Side 2 Yellow     OFF
// delay(2000);
  digitalWrite(5, HIGH);  //Side 2 Red      ON
  delay(100);
  digitalWrite(2, LOW);  //Side 1 Red      OFF
  // delay(2000);
  digitalWrite(4, HIGH); //Side 1 Green     ON
  delay(5000);
  digitalWrite(4, LOW);  //Side 1 Green    OFF
  // delay(1000);
  digitalWrite(3, HIGH); //Side 1 Yellow   ON
  delay(2000);
  digitalWrite(3, LOW);  //Side 1 Yellow    OFF
  // delay(1000);
  digitalWrite(5, LOW);  //Side 2 Red    OFF
   // digitalWrite(2,LOW);  //Side 1 Red
// delay(1000);
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    7 Comments
    I'm going to work on another that has the pedestrian switch, one side will stop traffic and the other side will let traffic go. Sounds neat anyway.
    On the video you said this is your first time using C++, but I didn't think it was possible to program the arduino using that language.
    I said that because I thought it was c++. I'm used to vb. Could you help me in correcting my statement? What language is it?
    Good instructable by the way.
    Thank you HIggs. It is my first Instructable.
    Not really sure. I know it is some variation of c++, but obviously not exactly the same thing. it is simplified and some commands are changed. Over all though it is very similar to c/c++.
