Introduction: Arduino Circular Cylon!
This is a quick arduino project that is great for beginners. Enjoy! There is a video on the last step!
Step 1: What You Need
To build this project you will need:
10 LEDs, any color will do.
Some wire, I used a ribbon cable I had
Most importantly, an Arduino
Perhaps some electrical tape
Prototyping board
Step 2: Build It!
Start off by arranging your LEDs on the proto board however you choose, I chose to place them in an oval shape.
After that, solder them to the board. After they are soldered, solder all the cathodes (shorter leads, - or the lead that has the flat side) together. Then, solder a wire to each anode (other lead of the LEDs) to a wire.
Step 3: Connect It to the Arduino and Program It!
Wire it up like schematic shows!
After you are done wiring it, you can start programming the arduino. I understand that there are many ways of bumming the code but since this example is for beginners, I made it as simple and understandable as possible.
void setup() {
pinMode(1,OUTPUT);
pinMode(2,OUTPUT);
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
pinMode(5,OUTPUT);
pinMode(6,OUTPUT);
pinMode(7,OUTPUT);
pinMode(8,OUTPUT);
pinMode(9,OUTPUT);
pinMode(10,OUTPUT);
void loop() {
digitalWrite(1,HIGH);
delay(100);
digitalWrite(1,LOW);
digitalWrite(2,HIGH);
delay(100);
digitalWrite(2,LOW);
digitalWrite(3,HIGH);
delay(100);
digitalWrite(3,LOW);
digitalWrite(4,HIGH);
delay(100);
digitalWrite(4,LOW);
digitalWrite(5,HIGH);
delay(100);
digitalWrite(5,LOW);
digitalWrite(6,HIGH);
delay(100);
digitalWrite(6,LOW);
digitalWrite(7,HIGH);
delay(100);
digitalWrite(7,LOW);
digitalWrite(8,HIGH);
delay(100);
digitalWrite(8,LOW);
digitalWrite(9,HIGH);
delay(100);
digitalWrite(9,LOW);
digitalWrite(10,HIGH);
delay(100);
digitalWrite(10,LOW);
Step 4: You Are Done!
MUST READ! :
The first person to make this project and post some images of it in the comments below will receive 1(one) patch acknowledging your accomplishment! Start Building! OFFER VOID PAST January 15, 2012
4th Epilog Challenge
Make It Glow Challenge
Hack It! Challenge
Pocket-Sized Contest
