Introduction: Arduino MEGA 2560 Home Automation With 8 Channel Relay
Check the next pages for the schematic and code.
Step 1: The Schematic
Here you see the schematic.
Should be very easy to understand.
Just connect it as the schematic shows.
Step 2: The Code
You need to include the SPI and Ethernet Libraries.
You probably need to change the IP Address and gateway. Subnet will be as it is in most cases.
You can find this below on the top of the code to change IP and gateway.
byte mac[] = { 0xAE, 0xFE, 0xDE, 0xEF, 0xFD, 0xFD }; //You can change the mac address to!
byte gateway[] = { 192, 168, *, *** }; //
byte subnet[] = { 255, 255, 255, 0 }; //
ip(192,168,*,**);
To find out what your gateway
Select Start > Run. Type command into the dialog box, then click OK.In the command line window, type ipconfig /all.
Here you will find your gateway.
To find the control panel. Just go to the IP adress you assigned to the Ethernet Shield in your browser, phone or tablets browser. From here you can Control each relay.
Good luck!
Full Spectrum Laser Contest 2016
