loading
What this is:
This instructable will show you how to make your Arduino into an R/C interface that you can use for just about anything requiring remote control. I will also show you how I built an R/C lawnmower using my Arduino, a cheap R/C transmitter and receiver pair, and a couple of electric-wheelchair motors from Ebay.  I have used this interface to control anything from basic LED's to Bipolar stepper motors, mini-robots, lifeless R/C cars from the thrift store, and even a 100lb lawnmower (all with appropriate motor controllers). It is very flexible and easy to change and very simple to set up.
See a slightly different version of the Lawnbot400 in my new book "Arduino Robotics" , as well as a DIY Segway and several other bots.
Check it out in MAKE magazine in the April 2010 issue (#22) or here:
UPDATE 3-24-10
New wheel-barrow bucket mounted on top with hinges so it can dump its contents.
UPDATE 3-10-10: NEW CODE
And new video of the Lawnbot400 moving a bunch of dirt from my truck to the flower beds across the yard, also I updated the code again.
I added some new code to the project that is safer, including a manual kill-switch and a Failsafe switch.
To implement the Failsafe, I used another Atmega168 (or an Arduino), to control a normally-open 60amp power relay. The relay disconnects the power to the motor-controller unless receiving a "good" signal from the 2nd microcontroller. This signal is updated 2 times every second and is either ON or OFF. If the bot gets out of range, it loses power to the motors. If I flip the kill-switch on the Transmitter, it loses power to the motors. This is also a handy way to disable it remotely if anything were to go near it that wasn't supposed to. The updated code for both microcontrollers is on the CODE page.
In addition to the failsafe, I changed the way the code reads the PPM signals to make it more reliable. Also, I realized that I was only able to run the bot at 80% speed with the old code, so now it is quite a bit faster and has more power (it can carry me across the yard @ 155lb).
Check out this new video of me riding the Lawnbot400, my wife driving it over a bunch of branches, then me making do some wheelies. Don't worry, the mower was turned off this time since the grass didn't need cutting, we were just having fun.
Disclaimer:
DANGER!!! This is a VERY dangerous piece of equipment if not handled appropriately. Since all the electronics have been home-built and the Arduino code is new, you MUST be very careful while operating anything heavy with this code. I have had 1 or 2 times during testing - and before adding a secondary failsafe - that the main Arduino jammed up and I temporarily lost control of the mower for a few seconds!!!! Though I have added several filters to discard unwanted signals and I rarely have any issues, an un-manned lawnmower IS STILL A POTENTIAL DEATH TRAP and I assume no responsibility for anything that happens as a result of your use of this code or this tutorial. This is meant as a guide for people who not only have the ability to build such a contraption, but the responsibiltity to operate it safely as well. Any suggestions or ideas on how to make this a safer project is always gladly accepted. Having said that, it's also awesome.
Background:
Most R/C equipment comes packaged for a single specific use, which makes it easy to use but is very limited in what you can do with it. So using the Arduino as an interpreter between the R/C system and the motor driver, I can use any motor controller that I want (depending on the size of the motor and power required), reprogramming the Arduino to supply the required signals.
What I ended up with:
After successfully hacking a few R/C cars from the thrift store, I got bored driving them around the driveway and I was having a hard time convincing my wife that there was any usefulness in the revived toy car. So I decided it was time to make my biggest chore at home, a whole lot easier and actually put my Arduino to work, and thats how I ended up building an R/C lawnmower.
While designing the lawnmower, I thought it would be cool to learn about the electronics that made it move, so I designed and built my own motor speed controller (or H-bridge) to power the lawnmower. I looked around at every H-bridge design I could find before deciding to go with a Mosfet h-bridge that uses both N-channel and P-channel Mosfets.
I built several different motor driver boards for this project, the first two were on Radio-Shack perf-board and the next 4 were designed using EagleCad and etched to a piece of copper-clad PCB, using the toner-transfer method. The most recent board is the one I use to mow the lawn as it has the ability to stay cool even while operating for long periods of time (30-40 mins straight) at 10-20amps and 24vdc. FWIW, I had to burn up a lot of Mosfets to find this out. If you want to see any of my other motor controllers, go to www.rediculouslygoodlooking.com and check out the Mosfet shield.
Here is what I bought already assembled:
FM R/C transmitter and receiver pair from ebay = $40
Arduino = $30
I already had a used push-mower = $60
Here is what I bought and assembled into the Lawnbot400 (as I call it):
(2) electric-wheelchair motors from ebay = $40 ea
(2) 12v marine deep cycle batteries - Walmart - $60 ea new (used batteries might work)
36" pieces of 2" angle-iron (2) and 1" square-tubing (2) from Home Depot = $8 ea
36" pieces of 1" angle-iron (2) and 1" flat steel bar (2) from Home Depot = $5 ea
(a lot) of nuts, bolts, washers, lock washers 3/8" or 1/2" with drill bit = $20
(2) caster wheels from Harbor Freight Tools = $14 ea
(2) drive wheels from Harbor Freight Tools = $8 ea
(36") 5/8" threaded rod with several 5/8" nuts and washers from Home Depot = $8
(2) sprockets from Allelectronics = $5 ea
#25 roller chain and a few universal links from Allelectronics = $10 for 3'
sprockets from Electronics Goldmine = $1.50 ea
(24) mosfets from Digikey = $1 ea
(there were quite a few small parts for building the H-bridge, they are listed later on)
Step 1: Setting Up
1. Get R/C transmitter and receiver (I have tested FM and AM systems and they both work)
2. Upload code to Arduino (it is on the last page)
3. Make sure you are getting a good signal
You will need an R/C radio transmitter(Tx) and receiver(Rx) pair, which is the most expensive part of the project, but can be used for every future project you might have involving R/C.  I went with a 6-channel FM system, but  I have tested a 27mHz AM transmitter/receiver and it works just as well. The beauty of the Arduino is that if you want to adjust the deadband or the motor-speed at turn-on, (unlike commercial ESC's) it is all easy changed in the Arduino IDE.
Once you have your radio, all you need to do is upload the code to your Arduino, plug in the 2 channels that you want to use from your radio receiver into Digital pins 2 and 3 of the Arduino (these are the 2 external interrupt pins on the Arduino) and you are ready to control whatever you want. If you don't have a batter pack for the receiver, you can run jumper wires from the Arduino +5v and GND to the R/C receiever for power, you only need to supply a single channel with GND and +5v (it is not necessary to power every channel).
Upload the code using the Aruino IDE (I am using version 0016 on Ubuntu).
I started by controlling 3 LED's with 1 channel on a breadboard. I wired a red LED to be Forward (digital pin 9), a yellow LED for Reverse(digital pin 5), and a green LED for Neutral (digital pin 12). This allows you to adjust the code to fit the needs of your radio system. You will have smooth 0-100% PWM control of both LED's and the neutral light will turn on when the control stick is centered. If needed, you can widen the deadband for Neutral, but doing so will increase the speed at turn-on (which starts at 0%, so that would likely be desirable). See pictures.
The code has 4 PWM outputs for motor control:
channel 1 Forward = Arduino digital pin 9
channel 1 Reverse = Arduino digital pin 5
channel 2 Forward = Arduino digital pin 10
channel 2 Reverse = Arduino digital pin 6
2 outputs for Neutral indicator lights:
channel 1 = digital pin 12
channel 2 = digital pin 13
The 2 INPUTS from the R/C receiver should go to:
channel 1 = digital pin 2
channel 2 = digital pin 3
If you are interested to see your readings, turn on your Serial Monitor in the Arduino IDE (set to 9600bps) and you can see the actual real-time pulse readings for each channel, they should read:
full forward = 2000 (2 milliseconds)
center = 1500 (1.5 ms)
full reverse = 1000 (1 ms)
These readings reflect the number of microseconds that the pulse signal from the R/C receiver stays HIGH (or at 5v). The typical Servo signal that comes from an R/C receiver is a pulse whose length varies from approximately 1 ms to 2 ms with 1.5 ms being Neutral (which should also be the position that the control stick returns to when you let it go). The transmitter reads the position of the control stick and sends that pulse length about once every 20milliseconds. So it is constantly updating for precise control (for more info, look up PPM on wikipedia).  If you push the transmitter control stick forward, the reading should go up to 2000, if you push it backward it should go down to 1000. You can also use a voltage meter at this point to see that Digital Pins 5, 6, 9, & 10 will be changing from 0-5v depending on the position of the control sticks on the R/C transmitter.
If you care to know, the code uses the Arduino's 2 external interrupts to capture when the Rx signal pin changes states (goes from HIGH to LOW or vice versa), when it does at the beginning of each signal, it calls the interrupt function which reads the digital state of the pin and if HIGH, it records the microseconds value on the Arduino system timer0. It then returns to the loop until the pin goes LOW, at which point it subtracts the previously recorded microsecond value from the new current microsecond value to determine how long the pulse stayed HIGH (which tells us the position of the Transmitter control stick). It then does that over and over really fast.
I have the values constrained from 600-2400 in the Arduino code to keep things simple. Once it receives the signal and constrains it, it maps that value to be proportionally between 0 and 511, where 255 will be Neutral. The code then determines when the value changes and uses a function to determine the appropriate 0-255 PWM value in the appropriate direction and each direction has it's own PWM output pin to control the H-bridge.
On a side note:
To make things easier, I built an Arduino-based breakout board using Radio-Shack perf-board, a 28pin DIP socket, a 16mhz oscillator, and a bit of wire. I also added a set of female-headers in such a way that I can plug my R/C receiver directly onto the breakout board. For secure connections while mowing grass, I added screw-terminals on each Output pin and each of the 6 channels from the receiver. It also has a built in 5v regulator to power both the Atmega168 from the Arduino and the R/C receiver (which gets power when you plug it onto the breakout board). So you just route jumper wires from the channels you want to use on the receiver, to the Atmega digital pins 2 and 3. I also added 2 LED lights that are hard wired to the digital pins 12 and 13 for the Neutral lights for each channel so I can easily see when I am in neutral.
Since this bot is a Tank steer setup with 1 drive motor on each wheel, the coding is very straightforward where the left stick controls the left motor and the right stick controls the right motor. Both sticks forward means lawnmower goes straight forward, both backward and it goes in reverse. If you push the left forward and the right backward, it does a zero-turn circle. As you can imagine, mowing the grass is really fun now.
Step 2: The Motor Driver
I built several motor drivers before finding a design that worked for my needs. For what it's worth, there are several nice products already out there that are fully assembled and require a lot less work if you are not interested in building your own electronics. The Open Source Motor Controller is an open source design that has been under constant community improvement for several years now and can handle up to 160amps at 36vdc! But they are over $100 and only control 1 motor. The Sabertooth 2x25amp motor controller is nice and controls 2 motors, but it is $125.
So I thought I would just make an extremely simple dual h-bridge that could handle at least 25 amps at 24vdc continuous and handle surges of up to 100amps for a few seconds. Once I found out that you can parallel Mosfets and multiply their current carrying capacity accordingly, I thought I would come up with a simple design and slightly complicate it by adding more mosfets until I had enough to handle the current that I needed.  Digikey has a good selection of Mosfets to choose from and good filters to narrow it down by what you need, so I spent a lot of time looking for Mosfets that were rated for around 50amp and could handle over 30 volts. Also, they have to be cheap because my plan is to use a bunch of them. I decided on the FQP47P06 p-channel and the FQP50N06L n-channel Mosfets from Fairchild Semiconductor, which I bought from Digikey.
If you are wondering what an H-bridge is, find out here: en.wikipedia.org/wiki/H-bridge and this will all make more sense to you.
The design is simple: 2 P-channel mosfets control the high-side switches and 2 N-channel mosfets for the low-side switches. But instead of using 1 mosfet for each switch, lets use 3. Now we have 12 mosfets per H-bridge (3 mosfets x 4 switches) and theoretically the ability to carry 150 amps (that is not accurate though). The board is as small as I could make it with nothing touching. Each set of 3 mosfets have heatsinks and are bolted together to help dissipate heat. Also, there is an 80mm cooling fan mounted directly above mosfets to further keep them cool.  The mosfets are very good at handling sudden changes in direction and speed changes.
Since there are 24 mosfets in total (8 groups of 3) I dubbed it the Triple-8. It is running at the Arduino default PWM frequency of 1kHz (I plan on playing with that to get the frequency higher). The board has 4 inputs, 2 for each bridge. If you bring an input HIGH, that side of the bridge goes HIGH.
Ideally, you would control the board by holding 1 input LOW and applying a PWM signal to the other input. This allows for easy speed control. I have written into the code that if you bring digital pin 7 HIGH, the code switches to Relay mode and either turns the mosfets all the way ON or all the way OFF. This is far more difficult to control, but is useful sometimes.
If you are interested in building your own H-bridge you can download the eagle file to etch a pcb and the schematic to show where everything goes. You can get everything to make this dual h-bridge at Radio-shack (including the copper clad), except the Mosfets and a special resistor network I used to save space. I bought most of the parts from Digikey though because it was cheaper and arrives to my house in 2 days.
Here are the parts needed for this motor driver:
(12) FQP47P06 - P-channel mosfet 47a 60v - Digikey - $1.73 ea
(12) FQP50N06L - Logic level N-channel mosfet 52a 60v - Digikey - $1.04 ea
(4) 2n7000 - Logic level N-channel mosfet 200ma 60v - Digikey - $0.26 ea
(8) 4606X-1-470LF-ND - 47ohm bussed resistor network - Digikey - $0.25 ea
(6) ED1609-ND - 2 position screw terminal - Digikey or Radio Shack- $0.46 ea
(24) CF1/84.7KJRCT-ND - 4.7k 1/8w resistor - Digikey or Radio Shack - $1.78 (for 50pk)
(1) PC9-ND - 3"x4.5" 1-sided copper-clad .064" 2oz copper - Digikey or Radio Shack- $4.66
(4) P5575-ND - 1000uf Capacitor or similar - Digikey - $1.19 ea
(1) 330ohm - 1kohm resistor 1/4w - for power LED, doesn't have to be exact
(1) power LED any color you like, I use the 3mm size to save space
Maybe something smaller?
If you are going to use this for something smaller than a 100lb lawnmower, you can look up one of the many H-bridge circuits and build your own smaller motor controller with as few as 4 mosfets (or BJT transistors) or even use a packaged IC H-bridge like the l293d (dual 1 amp) or the l298n (dual 2 amp).
Or if anyone is interested, I will post a schematic and Eagle .brd file for a smaller version of this H-bridge that only requires 8 mosfets total (everything else is the same), and it can handle about 10amps at 24vdc.
Etching:
I am not going to go into all the details of PCB etching, because there are already many excellent instructables on that topic. So once you download my .BRD file of my motor controller, all you need to do is print the .brd file onto some magazine paper using a laser printer, and iron that onto a piece of clean copper-clad. Then etch it with your favorite etchant solution (I use 2 parts Hydrogen Peroxide to 1 part Muriatic Acid and it works perfectly). And remove the toner with Acetone when done etching.
For ease of assembly I designed this board to be Single-sided and to use only through-hole components, no surface-mount stuff to mess with!  Yay for you.
You can get the .brd files for the various h-bridges at www.rediculouslygoodlooking.com
Step 3: The Wheels
First you need to mount the drive sprockets to the wheels.
The EASY way:
If you are smart and have more money, you can find a set of wheelchair motors that have the wheels mounted to them.
The CHEAP way:
I could not find any in my price range, so I went with just the motors, then bought wheels, then sprockets. Believing it would not be strong enough to mount the wheels directly to the motors, I opted to mount the drive wheels on an axle, then the motors to the frame, and use chain to transmit the power. A picture is worth 1000 words, so look at them carefully.
Mount the sprockets to the wheels:
I had to place the sprocket on the center of the wheel and drill 3 holes through the sprocket and then through the wheel itself. Once the sprocket is lined up and properly centered, I placed the 3 bolts through the sprocket and wheel and tightened them up as much as possible. I then welded the sprocket to the wheel hub to keep it centered.
The wheels from Harbor Freight Tools have built in bearings for a 5/8" shaft, hence the 5/8" threaded-rod we are going to use as an axle.
Repeat this process for both wheels.
There is more detailed info tagged in the pictures.
Step 4: The Frame Part A
This is the difficult part to explain. You will likely have to have some mechanical ability and a good set of tools to build a large metal frame from scratch. And since this was a prototype, the dimensions are not all perfect, but luckily they don't need to be.
The frame will be custom measured for your particular lawnmower, so I won't be giving you exact measurements.
Tools needed to build a frame:
measuring tape
angle-grinder
ratchet set
crescent-wrench
a level
electric drill
bolts, nuts, washers, and lock washers of either 3/8" or 1/2" diameter and 3/4"- 2" long
drill bits the size of the bolts you are using
1" and 2" angle-iron (36" long pieces) you'll need both
1" square tubing (36" pieces, steel)
1" flat steel bar (36" long pieces)
the 4 wheels you got from Harbor Freight Tools (2 drive wheels and 2 caster wheels)
5/8" threaded rod (36" long) and several 5/8" nuts/washers
First you need to plan out the frame of your bot. Since I was attaching a lawnmower, I started by measuring the height that the lawnmower stood off the ground and took some basic measurements to see how big the frame needed to be. My frame turned out to be about 24" wide (this distance must match the width from the center of the rear lawnmower wheels)  and 48" long (long enough for the front caster wheels to swing 360 degrees without hitting the front of the mower deck) and about 18" tall. Since we want the height of the mower-deck to be adjustable, we are going to attach the mower to the frame by removing the lawnmower wheels and using angle-iron to suspend the mower-deck from the frame of the bot.
1. I started out by using 2 of the 36" pieces of angle-iron (2" wide) for the main part of the frame running long-ways.
2. Cut the rear-piece of angle-iron the width of the rear of the mower (this measurement will be from the center of the left-rear wheel to the center of the right-rear wheel).
3. Drill holes in the ends of the angle-iron and bolt the rear-piece to the adjacent pieces from step 1, making sure they are straight.
4. Cut two front-pieces using 1" square steel tubing, the same length as the rear. We need 2 in the front to bolt the caster wheels to.
5. Drill holes and bolt these 2 pieces to the front of the angle-iron from step 1. You have to measure the holes from the 2 front caster wheel's mounting plates and drill the pattern into the front square tubing bars. Then bolt the wheels through those holes onto the front of the frame.
I later added another set of 2" angle-iron bars to the front caster wheel assembly to make the length of the bot adjustable at the front (see pics)
Now we should have a rectangular frame with the front wheels attached.
Step 5: The Frame Part B
We now need to see how far down to mount the drive axle to make the frame level. So raise the rear of the frame up until the top of the frame is level with the ground (use your level). Now measure the distance from the top-rear of the frame to the ground, this is the frame height.
Now we need to take into account the height that the wheels will raise the axle off the ground.  So measure the distance from the center of the rear drive wheel to the ground (the wheel's radius). Subtract the wheel radius from the frame height and we will have the correct distance from the top of the frame to the drive axle, which we will call the frame-riser height (we need to cut these pieces next). They are going to connect the rear of the frame down to the axle which the wheels will be mounted on.
6. We are going to add 2" to the frame-riser measurement (so we have a little to work with) and cut the 2 frame risers (mine were about 10-12" long).
7. Now drill (2) 5/8" holes, 1 at the bottom of each frame riser (about 1" from the bottom), this is where the drive axle will go through.
8. Drill 2 holes at the top and bolt the frame risers to the rear of the main-rectangular frame with the frame-risers pointed down.
9. Now feed the threaded-rod through the bottom holes of the frame risers and use 4 nuts to secure the frame risers to the drive axle (1 nut on each side of each frame riser, tightened down).
10. put the rear wheels on the axle and use 1 more nut on each wheel to secure them to the axle (these wheels have built in bearings). The sprockets should face inward toward the frame.
Now we should have a frame that stands on it's own with 4 wheels. However, the rear axle is not completely secure yet. We will need to add 2 braces from the bottom of the frame risers (near the axle) to the main part of the frame in order to keep the frame risers positioned properly. These braces can be flat steel and do not need to be very thick, they are just keeping the frame risers from moving.
Measure about 2" above each axle and drill a hole, then measure how far down that hole is from the top-rear of the frame and measure the same distance from the rear of the frame toward the front. Drill another hole on each side at this measurement. The support braces will need to be measured to be bolted in through these holes on each side (see pictures). The placement of the support braces is less important, meaning you can bolt them in wherever is convenient, as long as they are present.
Step 6: Mounting the Motors
This was the most difficult part to plan out on the frame. We need the motors to be adjustable so we can adjust the tension of the chain, however they just have 4 holes in the bottom of each motor and nobody makes a mounting plate that I could find.
The simplest way I could come up with was to mount the motors to an 8" long piece of 2" angle-iron, and then mount that piece of angle iron to the frame through some specially cut holes that allow the motor mount to travel forward and backward (but not side to side) along the frame.
Make the motor mount plate:
Cut an 8-10" section of 2" angle-iron, depending on how much room your motors need to mount. Mine only needed about 4", so I made it 8" to have plenty of room for the mounting bolts. Drill a hole about 1.5" from each end of the top of this bar, this is where the mounting bolts will go through the frame.
Mount the motor to the motor mounting plate:
Now you have to find the center of your motor mount plate (the 8" long piece of 2" angle iron) and measure the mounting holes on your DC motors. Use a sharpie marker to plot the hole pattern from the motor, centered onto the motor mount plate.  My motors have (4) 1/4" diameter tapped holes in a rectangular pattern on the bottom of the gear box.
Drilling and cutting the adjustment holes on the frame:
Next you need to drill and cut the holes in the frame to let the motor mounting plate become adjustable. I cut these holes using a dremel tool and a cutoff wheel. You have to line up the motor mounting plate (with motor mounted preferrably) onto the frame rail and use a sharpie marker to mark where the holes will need to be on the frame rails. Start as far back as you can (without hitting any other bolts underneath the frame), and mark the center of each hole. Then move the motors forward 2" and mark the holes again. You want to cut the holes out of the frame so that the motor mount plate (with bolts going through the frame), can move forward or backward about 2". The holes in the frame are the width of the bolt and about 2" long. I drilled 1 hole at each end and used the dremel to cut out the rest.
The holes drilled in the motor mount plate are just single holes for the bolt to fit through, the holes through the frame were cut with a Dremel tool with a cutoff wheel to make channels for the motor mount bolts to travel forward/backward through. You want the 2" angle-iron motor mount bracket to set as much on top of the main frame rails as possible, the bolts (which you can't see with the motors mounted) that hold the motors to the motor mount plates will keep the motor mount plate  from laying flat against the frame bars. Go ahead and mount the motors loosely to the frame using 2 bolts on each.
Cutting and connecting the chain:
Now get your 10' of #25 chain and wrap it around the main drive sprocket on the wheel. With the motors pushed all the way toward the back of the frame (closest to the drive wheel sprockets), wrap the chain around the motor drive sprocket and mark where they overlap. You need 2 of the universal chain links from to connect the 2 loose ends. Cut the 2 pieces of chain and connect them to each side with the universal links to connect them.
Tensioning the chain:
Push the motor mounts forward until there is good tension with the chain, and tighten up the bolts that hold the motor mount plates to the main frame.
Now you can generate electricity. Connect a voltage meter to 1 set of motor terminals and push the bot around.
Step 7: Mounting the Mower Deck
Next we need to mount the mower deck to the frame. Remember we made the frame wide enough that the edges of the frame would be centered on the lawnmower wheel shafts.
All we have to do is cut 4 pieces of 1" angle-iron equal lengths so that the mower deck hangs evenly from the frame.
So measure the height of the frame from the top to the ground. Now measure how high the mower sits off the ground from the center of the wheel shafts (when the original wheels are on the lawnmower and all the height adjusters for each wheel are in the middle position).  Now subtract the height the mower sits of the ground from the frame height, and cut 4 pieces of 1" angle iron to that length.
Now drill 1 hole in the end of each piece of angle-iron, about 1/2" from each end. The holes at the bottom will need to be the diameter of the lawnmower wheel shafts and the holes at the top will need to be bolted into the frame (hung at equal distances from the top of the frame).
Once you have all 4 hangers installed, you can install the mower deck and tighten up the bolts. Make sure you have at least 1/2" of clearance or more between the drive tires and the lawnmower wheel shafts.
You are almost ready to go.
Step 8: Select and Install the Batteries
This is the simple part. Go BIG. I only bought 1.. which I got at Walmart for $62.
I got 2 car batteries (actually 1 marine deep cycle and 1 gel-cell car battery) both 12vdc. They together keep my lawnmower running strong for the duration of my front and back yard (I have about 1/2 acre of grass to cut and it is somewhat hilly). I slacked while trying to learn about batteries and just went with the biggest ones I could find for the price (the gel cell is actually used). I initially thought 12vdc would work, but the added weight of the mower deck made it travel so slowly at 12vdc, that it would not quite make it up some larger hills, so 24volts was necessary. The 2 batteries are connected in series with each other.
The microcontroller is also powered by these batteries. I have never had any problems with the electronics not getting enough power, so I didn't see the need to have a separate power supply.
The batteries (due to their weight) are mounted behind the rear wheels. This GREATLY improves control of the bot because it counters the weight of the mower deck in front. Zero-turns are very easy now.
I needed a place to hold the 2 big batteries that were going to power the lawnbot, so I measured the 2 batteries and welded a small 1" angle-iron frame to hold them. It is welded to the rear of the frame behind the drive axle to maintain even weight distribution.
You can use bolts and 1" angle-iron to make a battery holding cage that is bolted to the rear of the bot, or you can use smaller batteries and secure them to the top of the bot. 12v 20ah Sealed Lead Acid batteries can be found online for around $35-45 each. Any battery rack that you can whip up will likely be just fine, as long as it can support the weight of the batteries it is carrying. I used a welder to speed up the process.
Step 9: Mount the Electronics
Connect the electronics to the motors and batteries. The motor drive board has 1 connector for the main battery power and 1 power connector for the 80mm cooling fan that I would highly recommend you install directly above the mosfets. There is spacing for some long skinny bolts to hold a cooling fan. I bolted the motor driver above the Arduino breakout board to save space.
Also, you might want to use some smaller wire coming from the batteries to power the Arduino board, as the 10ga wire I used for main power and motors is a bit overkill for the microcontroller.
I installed a 30a 120v toggle switch from Radio Shack to switch the main power ON/OFF, this is my kill-switch. I also found a terminal-block for power distribution at Radio Shack for a few bucks. It is the white thing that all the wires go into in the pictures. This makes removing the electronics a whole lot easier.
It is very important that you wire everything up correctly. Otherwise you might blow up the motor controller.
So make sure that you check the code before connecting anything to verify that you haven't mixed any wires up.
Step 10: The Code
I changed the code so that the Interrupt Service Routines (ISR) would run more quickly and the sketch would spend less time in the ISR. This means less overhead which means more signals are processed and smoother operation of the bot.
I also added a 2nd sketch for the 2nd microcontroller to process 2 signals (you can add as many more as you want) using the pulseIn method instead of using interrupts. This only processes about 1/5th of the available signals from the R/C Receiver, but also severely decreases the chance of receiving a "BAD" signal. Also, since the power relay is setup to only be ON if the signal is "GOOD", when you go out of range, it automatically shuts off the power to the motors only.
The 2nd Atmega by default should have digital pin 4 used as the R/C servo signal input from the R/C receiver, digital pin 6 should control a 5v relay or N-channel mosfet that is used to switch the 60amp power relay ON/OFF. That is all that is needed, you can also use an LED on pins 12 and 13 to indicate whether the relay is ON or OFF.
You can also add 2 12v running lights from Walmart for a car... I use an N-channel mosfet directly tied to pin 9 of the 2nd Arduino to control the brightness of the lights using a hacked channel on my transmitter. This input from the receiver would go to digital pin 2. Check the code.
Download the .zip file on this page and upload the sketches. If you don't plan on adding the 2nd Atmega with the failsafe and killswitch, that is fine. You can still update the new code for just the main Atmega and it should run more smoothly.
Step 11: More Videos
here are a few more videos in case anyone wanted to see...
#2
#3
#4
#5
Should we mount an umbrella on this?
Does anyone still have access to the schematic and eagle file?
<p> you considerer using software similar to that of Arduo-pilot to use GPS and allow the mower to autonomously mow the lawns?<br><br>alos how did you pront the boards for the H-Bridge did you print wiht your own printer or send the CAD drawings away to a third party to print for you?</p>
<p>Instead of h- bridge you can code for it. which will save your money .</p><p>H- bridge by coding Set pwm.</p><p>transmitter $ receiving bluetooth module 4.5$ only</p><p>Control by android app </p><p>Save , secure and efficient method </p>
<p>can you explain a bit more about the coding set PWM to control the motors? my mail is gabriel.badilla.alfaro@gmail.com</p>
<p>Kudos to you!! Brilliant!! You inspired to work on my own project. A newbie with no knowledge. Even if i do not get anywhere, i would like to start.Please help.</p><p>Do you have the .brd file or .sch file. i want to try making the R/C Landmower. I have never etched a pcb before. so looking for the drawing and try making one.. if not give it outside to get it made. </p>
Anyone who made this; where did you get the sprocket for the wheelchair motor shaft? My shaft is 17mm with a 6mm keyway.<br><br>Also, what gear ration did y'all go with?
Awesome project, thanks for the clear documentation too.
<p>Here is a unit I built from scratch with a track drive and complete stainless construction. It is fully functional but I have yet to add the lawnmower accessory to the front of it. If you have questions...feel free to ask. It has tons of torque. Two wheelchair batteries and two wheelchair motors and a sabretooth controller. I am thinking I may want to sell it if anyone is interested.</p>
hi ed! i have some cuestions for you. do you have an email, facebook account or phone number where i can reach you.at?
<p>Up front, I don't have the money, but if I did, how much would it cost me? I really could use something like this being wheel chair bound and maybe I can save my pennies. Great job though. Semper Fi</p>
<p>Approx. $600 should get you there depending on how handy you are.</p>
That is awesome! Where did you get the tracks?
<p>Seems like your website is not working, can you link the .brd file?<br></p>
What would you charge to build the frame with all components except the mower? <br> <br>viperguy@suddenlink.net <br>
Hi Viper,<br><br>I would have to source the parts first and it would depend on that. Also, shipping would be expensive if I pack a box full of angle-iron and heavy duty motors to ship... what state do you live in?<br><br>Ballpark figure... I would probably have to charge around $600 or so to build the frame (sans mower and batteries), though for the next two months or so, time will be tight for me... so it would probably wouldn't be complete until around the first of next year.<br><br>On the other hand, I am happy to offer (free) help with building problems and parts sourcing, should you want to build it yourself.<br><br>Cheers,<br>JD
Hi I'm working on my capstone project for electronic engineering and I'm trying to build a very similar bot to yours. I'm getting your book for my bday in a month and that will probably answer any questions I have but I'm working on the hbridge now and was wondering if you could send me a schematic that could handle the load. My email is Carmichaeldaniel12@yahoo.com<br>Btw your bot is awesome!<br>Thanks man!
Very good, thanks for the info.
<p>This is truly awesome and will be a great help if I can get one together. Semper Fi</p>
What was the total cost into making this?
<p>Hey can you sent me the code, because it won't download on my iMac</p>
<p>Hey! Still Need The Code? Message Me If You Do.. </p><p>Shouldn't be too hard to replicate if you wanted to but I have the zip from above.</p>
<p>please, I want to make a car to carry 15 kg So :What are motors I need ?</p>
That's cool :) nice build! Was thinking as another possible safety feature, perhaps you could buy a &quot;invisible fence&quot; that people use for dogs. You put the wire a few inches under the ground to create a boundary and hack what is normally on the dog. This works in 2 stages, a sound to warn the dog (use this output to change mower direction) if the dog/mower is ignored the second stage gives a shock. (Use this output for closing your &quot;lost signal&quot; relay.
<p>Can you provide a more detailed schematic of how everything is connected to the arduino?</p>
<p>I built your H-bridge for a project im working on. Not sure if i made a mistake or if its working as designed. I connect motors to the triple8 and when i apply power to the board the motors both start. was not sure if it should default to stopped or running. I am also curious how to connect this to a standard arduino. Most of the refrences I can find show 3 wires per motor and this obviously only has two. Any help would be greatly apprieciated.. thanks!</p>
<p>This is genius! A beautifully executed idea with so much potential for other applications. Very good instructable.</p>
<p>Hi! First of all congrats to this great instructable! Very well documented, and very genius ideas.<br>However, I would be concerned with the parallel connected mosfets. Not one electronic part is equal (exactly the same characteristics). So if you take two LED's for example they will not be perfectly identical. This is the case for mosfets as well. So if one of them opens faster then it will have to handle amperage which it can't handle...<br>This is just a thought....:)</p><p>THank you and best regards,</p><p>Lorant</p>
Anyone have a copy of the .brd files the link is dead. I was looking forward to making this, but I dont want to buy the parts if there's no instructions to go with them
i am seeing your schematic, and, sorry to say, it's wrong. All the P-channel mosfets are reversed, you have a pair of p-channel mosfets on each H-bridge disconnected from the power. But apparently you fixed those two things on your PCB, it's a trap for beginners, you should fix it.<br /> <br /> You have no back EM protection, not even a diode, and the mosfets are too small in voltage, i used 100v mosfets with a 24vdc motor, 12A and&nbsp; they just exploded, all the protection died, and the microcontroller died. We measured the inductive peaks in approximately 200v, and you have 2 times the current here. You have no hardware protection to prevent both sides of the H-bridge from turning on at the same time.<br /> We even used toric transformers and 100uf capacitors next to the motor and, even then, it exploded, with fire and everything. <br /> <br /> The only solution that worked, after a year of trying (we didn't find something like a BTS7960 in my city, we looked for it) was to use a double inverter relay in series with 2 500v 8A mosfets in parallel, plus all the usual diode based protections, thermistor based protections, capacitor based protections, and, of course, optoisolated from the control logic.<br /> <br /> that was for an electric wheelchair.<br /> <br /> so, if your circuit worked, the motors are almost magic, you are extremely lucky, or you are omitting something.<br /> <br /> i wish you the best<br />
<p>Hey</p><p>you seem to be a expert on this field. I need some help. I made a remote lawn mover with wheel chair motors and 2x25A. It caught on fire after over heating. Now I am looking for a powerful MOSFET H bridge. Could you please send me a schematic with high power H bridge if you have got one. I am doctor in profession therefore minimal knowledge in electronics, need good good explanatory schematic. my email is Isuru7777wg@yahoo.com. Thank you for your help.</p>
sorry about any schematic and board differences... I am a beginner in Eagle, so I made the .brd file before the .sch file. <br /> <br /> The mosfets&nbsp; I used are 50 amp and 60v.... I am also fairly new to mosfet theory, so I can't argue with you on much, but I do know that they have built in ESD protection diodes that are rated far above the 24 volts that I am using. I thought about adding additional diodes, but as it turns out, that is not necessary. My bot weighs over 100lbs and I can do very fast direction reversing and it does nothing to the mosfets or the microcontroller (It has had the same Atmega168 since I&nbsp;built it a few months ago). I was worried about the gate-source voltage spikes above 24 volts affecting the P-channel mosfets, but the mosfets I used have a Vgs max of 25v and they have performed very well so far at 24vdc.&nbsp;&nbsp;<br /> <br /> I have used this controller with several different motors and it worked with each. Also it will carry me on top of my mower across the yard... so that is over 300lbs and it doesn't heat up at all. I may be very lucky, but it can handle anything I throw at it and it is very responsive, which is far more than I was expecting to get when I started.<br /> <br /> I&nbsp;think 2 people have already made this board and said it worked... but I am designing a new board based on the OSMC schematic, so I will post it as a replacement when&nbsp;I am done.<br />
maybe those mosfets are extremely good and more resistant to transient voltages than normal ones (IRFxxx), normally mosfets are very sensitive to overvoltages, and they are good with high currents.
<p>This is the best Instructable on Instructables. Pure genious. I think I first found this on RC Groups and then Googled around until I ended up here. I searched on eBay and Craigslist for wheelchair motors. They were all way to expensive. ($300 for a set). But I just found an old guy that rebuilds wheelchairs in his garage. I got a set of motors and wheels, some castor wheels, battery boxes, and several other things for $50! I'll be FPV-RC lawn mowing by spring!</p>
<p>Hi! Great job. I have a question. I'm in a similar project. what are the engine specifications?</p>
<p>Wow, Great job! Do you have a steering mechanism for the front wheels (IE a servo etc) or is all the turning done by the rear motors and the front wheels just pivot?</p><p>Thanks :-)</p>
<p>I want to make one with a bit more features :D</p><p>one with a good webcam or 2 and computer control ;P (me being a programmer)</p><p>it would be the pinnacle of lazy lawn mowing especially if i could turn it on from my computer. :D</p>
<p>Does anyone have the schematic or .brd file? None of the links seem to work.</p>
<p>One more thing. What kind of arduino did you use? Will an Uno work? Thanks!</p>
<p>Hi! I'm lazy and don't feel like doing the math on how much it is going to cost to make. Do you have a good minimum to maximum price range on building this thing? Thanks!</p>
<p>How do you pull and hold the throttle cable?</p>
<p>I took the spring off of the switch on the motor that the throttle cable pulls... then used a zip-tie to hold the switch open so it would allow me to crank the mower and it stay running. Then connected 2 wires to the contacts on the cutoff switch, connected to a relay to turn it off.</p>
ssaaludos<br>
<p>amaizing... maybe you can tech me how to make it..beocuse i'm newbe</p>
You have inspired me to create one! On the search for wheel chair! Thanks for laying the ground work and doing all the hard work.
<p>Sorry to bug you all again, another question. I am having an issue finding a 6ch Transmitter Reciever for a car. Does it need to be 6 channel, can it be more or less. Or is that for expansion of future stuff?</p>
<p>Hello, i have recently had this project rekindled in things to build. I have wanted to do something like this for a long time. And with the recent snows this year i have had a thought to put a snow scoop on the front of it to shovel. I have one maybe two questions for you. All the RC transmitter reciever pairs i am finding on ebay are in the GHZ range. I am new to arduino and not sure if this will work. And i guess the second question is, I see alot about the scooter motors, wheel chair motors are pretty expensive versus the scoter motors. Do you think the scooter motors handle mowing the lawn, hauling dirt and or a person around, and shoveling snow? Thank you in advanced for any comments</p>
About This Instructable
497,134views
1,361favorites
License:
Bio: I have always been one to take things apart to figure out how they work, so most of what I own has been dismantled. If ... More »
More by johndavid400:Arduino controlled Bluetooth-bot Core3duino Arduino R/C Lawnmower (painted)
Add instructable to:
