THIS IS THE LINK FOR THE VIDEO OF IT IN ACTION, CHECK IT OUT!!!
Remove these ads by
Signing UpStep 1What you are going to need.
-Cutting board (I got mine at Target for $8, it’s a 20” by 15”, the bigger the better because you have more working surface. Don’t get a wood one because the big ones are way to heavy for a person that would be using only one arm)
- Knife (the size of your knife should be relative to the size of your board, my knife is 8”. Make sure the cutting part of the knife is flat, not curve)
-Wood screws or nails 2” (I used wood screws because they hold the food better but nails are easier to clean, you decide)
-An extra piece of plastic at least 6” by 6” and ½” thick ( I used an acrylic sheet, this is for the supports and holders you can replace this if you have a better material)
-Anti slide soft pads/ sugru (sugru works best)
- Two machine screws and nuts 1"
TOOLS:
-Dremel with cutting wheel and drilling bits (or any tool that you have that can do the same job)
-Hot glue gun
-Screwdriver
One tiny edit I would suggest is to recommend stainless or brass screws for the food holder since they don't rust, and some of your readers may not know this.
thanks and great ideas are always appreciated
CHECK OUT THE VIDEO!
http://www.youtube.com/watch?v=QjYWXI_6nfE
