AutoCAD 2D Drawing Tutorial Step by Step
4,405
16
4
Posted
Introduction: AutoCAD 2D Drawing Tutorial Step by Step
In this instructable we will learn how to draw a 2D object using AutoCAD.
You can find a full course here:
https://www.udemy.com/autocad-2d-and-autocad-elect...
Coupon Code: FBAUTOCAD
Step 1: Start Point (the Central Point)
Draw a circle with radius of 625;
Step 2: Another Circle
Draw another circle inside the circle of step 1 with a radius of 312.5;
Step 3: Adding Lines
Draw a line from the center of those circles into the right with a length of 2312;
Step 4: Add Circles to Lines
At the end of this new line, draw a circle with
a radius of 876
Step 5: Specifying the Angle
Draw a new line from the center of the circle of
step 1 for 2312 as length with angle of 40 between this line and the one created at step 3
Step 6: New Circle
Add a new circle at the end point of the new
added line with a radius of 876
Step 7:
Draw a circle that have the same center point of
circle of step 1 with a radius of 2312
Step 8:
Draw 2 circle with a center exactly on the
center points of circles created at steps 4 and 6 with a radius of 437
Step 9: Trimming
Trim circles and you get the following image
Step 10: Trimming
Trim the circle with the radius of 2312 with the
2 lines that have an angle of 40 degrees between them, until you get the following image
Step 11:
Create an offset of the previous made arc to the
left and to the right with a value of 876
Step 12:
Draw line from the center of the circle of step 1, to the left with a length of 3492 and an angle of 180 degrees
Step 13:
Draw a circle on the end point of this new line
with a radius of 626
Step 14:
Make an offset of the circle of step 13 to the
inside with a value of 313
Step 15:
Add a vertical line that cut the 2 circles into
half and trim the right arcs, to get like the following shape
Step 16:
Now we have those 2 arcs. At each end point of
them, add an horizontal line with a length of 1000
Step 17:
Use the mirror tool, and create a copy of those
arcs, until you get the following shape
Step 18:
Add dimensions, according to the original image
that we have at the first page of this file, and add the 1875 and the 750dimension line
Step 19:
At the intersection of those dimensions, add a
line, then add a circle with a center point as the center of this line, with a radius of 437.5
Step 20:
Draw another circle from the same center point
with a radius of 875
Step 21:
Draw a circle with a center point, the center of
the original circle of step 1, and with a radius of 1375
Step 22:
Add a vertical line to this circle that passes
directly from the center, and trim this circle according to the original shape until you get the following object
Step 23:
Draw a line from the end point of this new arc,
and connect to the point of the arc at the left of the screen until you get something like this
Step 24:
Using the fillet tool connect the arc created at
step 11 with the arc created at step 21-22 but choose the fillet radius as 625
Step 25:
Do the same for the upper of the arc created at
step 11, with a radius of 625
Step 26:
The final step is by using the fillet command to
get an arc between the circle created at step 20 with the outer arc created at step 17 with fillet radius as 1750
Step 27:
Connect the disconnected line of the arcs
created at step 17
Step 28:
Delete the extra lines that has been added for just the measurements and you will get the final shape.
AutoCAD 2D and AutoCAD Electrical 2017
Full Course on Udemy:
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
were do you draw the dimension
lines
2 Comments
Thanks for sharing :)
you are welcome.
