Introduction: Batman Cowl
I've been wanting to make a Batman costume for some time now, and as Halloween approached it gave me a good excuse to dress up as the caped crusader. I made a full costume with armor and ordered a latex cowl hoping to save some time. Well, the cowl arrived and I hated it, so I decided to make my own. Here is the process I went through:
Materials needed:
- Plaster Strips
- DAP Modeling Clay (air dry)
- Cardboard (from a cereal box)
- Sandpaper
- Plasticoat Spray
- Black Spray Paint
- Velcro Strips
- Heavy duty fabric glue
Step 1: Plaster Strip Your Head
This is the part where you get dirty. It's actually fairly easy though. Get a swim cap to cover your hair (plaster + hair = bad) and then apply Vaseline to areas you will be applying the plaster strips. Then just start laying them on. You want to make sure you get the general shape of the mask set up. I made sure not to go under my jaw as that would make it difficult to open my mouth and to get the mask off.
Also, as I made my cowl in 2 parts, don't cover the back of your head either or you won't be getting that bad boy off at all. You will need to do a minimum of 3 layers of strips.
Step 2: Sculpt Face
This is where you get to bust out the clay and shape your own Batman look. I looked up several different styles of cowl and picked the parts that I liked most.
The DAP clay works well and you can smooth it over the plaster strips well. I worked on making sure the nose was really pointy and the eyebrows had a convincing scowl.
Then, before I got too crazy sculpting, I added the ears. To do this I fashioned them out of cereal box cardboard and taped them on. This was one of the more challenging parts as you want to get the shape and symmetry right. (Sorry no pictures of that process) Then, once I had the look right, I plaster stripped over the cardboard to make it solid. After that dried I was able to apply the clay over the top for a smooth look.
I don't have any pictures of the back portion of the cowl. Basically it is the same process. I plasters the back of my head and then cut the two prices to match up. I then covered this part with clay too.
You can also see that I applied a chin strap. Use the plaster strips for this. Keep your jaw open for this or you won't be able to open it at all when you wear it. Luckily it dries pretty quick. After it was stiff enough to take off I placed a couple strips on the inside to reinforce it.
Step 3: Sand It Smooth
No pictures for this. It's pretty straight forward though. Get out your sand paper and make sure it is smooth. I got out my dremmel too for a few shaping issues. Once it is nice and smooth (this can take some time) you are ready for the next step.
Step 4: Paint It
This is the fun part where it really starts to look cool.
First, I did a couple coats of Plasticoat spray. This was to help make a better surface for the spray paint. Then I did about 3 coats of a matte black spray paint. Let it dry
Step 5: Velcro
UPDATE:
Here are some pictures of the back of the cowl to see how the velcro system works.
Again I don't have any pictures of this. However, I think it is fairly intuitive. Cut your Velcro strips and glue them to the inside of the front piece of your cowl. This should run around the back of your head and be able to hold the mask tight to your face.
Then I placed 3 tabs of Velcro (hook side up) out the edges of front (one at top and one on each side.) I then glued the soft side of the Velcro onto the corresponding locations of the back piece. This allowed for it all to stay together.
Step 6: Put It on and Look Awesome
Paint black around your eyes and strap that thing on. Put some marbles in your mouth and growl, "I'm Batman!"
You can see the full costume here. That was way more work and I may post the process for another instruct able.
My wife is looking super hot in her Catwoman costume. We took my son out as Robin for trick-or-treating. It was super awesome
This is my first instructable, so I hope you like it. Feel free to give feedback as I will probably do a few more.
Manly Crafts Contest
Halloween Costume Contest
