I became fascinated with wood lathes when I was in Junior High. I saved my money until I could buy my own lathe. Soon I wanted a bench or table saw, too. I decided to fit a saw blade to my lathe and make a table for it. The unit in the photo is not my first effort, but is an improved version.
Step 1Blade Mount
My lathe uses a smooth shaft 5/8 inch in diameter. There is a flat spot ground into the shaft for attaching fixtures with a setscrew. Blade mandrels are available from various hardware concerns. This one slides onto my shaft and is secured with a setscrew. It has a 5/8 inch diameter threaded end with spacers, a washer, and a nut. Check your lathe. Some lathes use a hollow shaft with a Morse taper. You may need to get a special mandrel direct from the maker of your lathe.
SAFTY FIRST, DAMM THE EXPENCE, YOU CAN'T BUY YOUR FINGERS BACK...
www.wired.com/gadgets/miscellaneous/news/2007/07/xfinger
But, in all seriousness, you are correct; never skimp on the safety equipment.
I hate to rain on your parade but doing this to a lathe could result in SERIUS INGURY OR DEATH, a lathe is not designed to withstand these stresses and neither are the blade mounts.
-To the instructibleler ,It's nice that this have worked out for you, but other lathes may react differently to the stresses that sawing in this matter will create.
Possible results include: shattering of the blade, shattering of the axle. This simply means that the blade, axle and other tool and projectparts might shatter and fly out of the contraption with enormous amounts of energy.
I hope that neither you or anyone else get hurt doing stuff like this, remember DO NOT TRY TO SAVE MONEY ON SAFETY, you might end up regretting it your whole life.
The actual idea is very similar to the Magna ShopSmith. Check them out if you'd like some more ideas. there is a thriving shopsmith community too, if you were looking for parts or photos of parts and pieces in operation.
(i have a ShopSmith VII, which isnt technically the same breed as the vaunted shopsmith V and 5xx series... but i grew up with one and like it just fine.)
the ability to raise and lower the table (for deeper or shallower cuts) is great, and your hinge system is very simple and robust!
another option would be using threaded rods as post for the table-top, and nuts at the corners of your cleat-base, with sprockets welded/attached to the nuts, and a chain around the outside. then rig an oversize "wheel" rim to one or two of the nut-sprockets: turning them would cause all four posts to raise or lower in unison (assuming the sprockets are ll the same size!)
many thickness planers use a similar system for adjusting the bed/blade depth. obviously you would need some stabilizer posts too so the table top isnt wobbly, but that could just be plywood perpendicular to the table that slides through slots in the cleat base.
but the hinges are surely simpler!
for some more ideas:
shopsmith main site
shopsmith community forum
http://www.bolis.com/amillar/category/project/tablesaw
