Introduction: Big Egg + Arduino +IR Sensor = EasterEgguino
Step 1: Stuff Needed
The main items used are:
1. Ardweeny - a small Arduino compatible Microcontroller from Solarbotics .. This is inexpensive but you are required to solder the pieces to the included PCB.
2. A small hobby servo - I used a Futaba GWS03n
3. an IR sensor - I used a Sharp GP2Y0A -
4. you will need the cable that goes to the sensor also
5. 8 Leds
6. 74HC595 shift register to do the LED chasing.
7. 7805 voltage regulator
8. AC adapter to provide the 9 volt current required
9. A big egg(and some smaller ones) - from the Hobby Lobby.
Also
1. hot glue
2. some decorative items - the ears,eyes from a hobby shop or a toy store
3. wire, soldering iron
Step 2: Build the Egg Part
1. hot glued 3 of the smaller eggs to the bottom to form a base. Using tape to hold in place worked well.
2. added a hinge to attach the top part to the bottom part.
3. Cut a piece of scrap wood to fit inside the egg. This is screwed to the egg and will be used to mount the servo.
4. glue a smaller piece of wood to the semi-circular piece. Attach the servo to the smaller piece with a zip tie.
5. cut another scrap piece of wood into a circle which fits nicely near the bottom of the egg. The bread board and battery will be mounted on this. Hot glue this in place .
6. Make an arm for the servo. This will depend on where you place the servo, size of egg. I cut a pice out of an old CD case and spray painted it black.
7. attached the IR sensor to what would become the front .
8. need to cut a piece which fits in the egg but just a couple of inches down. This becomes the shelf upon which the candy will be placed.
Step 3: The Electronics Part
1. The Ardweeny
This comes as a kit from Solarbotics. It includes instructions on how to assemble.
Once assembled it can be used right on the bread board which is what I did.
Connections that need to be made to the Arduino are:
IR sensor
black wire to gnd
red wire to 5v
yellow wire to analog pin 0
Servo
- I have tried to power the servo in various ways but it seems it needs its own power so I
provided 3 AA batteries for power
black wire to gnd
red wire to batteries
white wire to digital pin 9 on ardweeny
- I wanted to have the LEDs chase but did not know how to do this. I found the following
http://www.arduino.cc/en/Tutorial/ShiftOut
I followed the instructions there and it worked.
I must admit I am not completely sure how it works but it does work.
Some other issues:
- had to play around with the servo locations to get it to open but not open too far or not enough
- used a routine" millis" to give the appearance of the chaser working continuously as the lid opens.
(first video was before this refinement and you will see the chasing does not work but once)
- I power the Ardweeny with an AC adapter . I had hoped I could use it to avoid all batteries but when I try to include the servo , it just is not enough power to open the lid. I do not know how long the batteries will last.
Step 4: The Code
Below is the code I used :
I started with the servo sweep example and added to it .
// Sweep
// by BARRAGAN <http://barraganstudio.com>
// This example code is in the public domain.
// modified 4/11 c. dubois
// Made a candy server from a big plastic egg
// idea:
// IR sensor will tell when a hand reaches for the egg and will
// signal servo to open the egg.
// shift register is used to do a LED chase when the egg opens
// updates
// v3 - 4/24/11 add routines to get LEDS to chase continually
#include <Servo.h>
// distance sensor
int sensePin = 0;
// Servo
Servo myservo; // create servo object to control a servo
// a maximum of eight servo objects can be created
int pos = 0; // variable to store the servo position
// 74HC595 shift register
//Pin connected to ST_CP of 74HC595
int latchPin = 8;
//Pin connected to SH_CP of 74HC595
int clockPin = 12;
////Pin connected to DS of 74HC595
int dataPin = 11;
// other variables
int ledToDisplay;
int posServo;
long previousMillis = 0; // will store last time Chase was updated
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long interval = 1000; // interval at which to blink (milliseconds)
void setup()
//set pins to output so you can control the shift register
pinMode(latchPin, OUTPUT);
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
// Serial.begin(9600);
myservo.attach(9); // attaches the servo on pin 9 to the servo object
void loop()
// read the sensor
// if getting close , thwn want to open the egg and start the leds.
// Leds will continue to chase until egg closes
int val = analogRead(sensePin);
// Serial.println(val, DEC);
// map the val to a servo position - pos
// int val = analogRead(0);
// pos = map(val, 0, 1023, 0, 100);
// open egg and turn on LEDs if close
if(val > 225)
// 2. open egg
posServo = 0;
for(posServo = 0; posServo < 24; posServo += 1) // goes from 0 degrees to 65 degrees
// keep chase going
runChase();
// move servo
myservo.write(posServo); // open top, wait 4 secs, close top and wait 5 secs
delay(25);
// run a loop for 3 seconds to avoid using delay
for (long xx=0; xx <= 200000; xx++){
// keep chase going
runChase();
// close the lid
for(posServo = 24; posServo >=0; posServo -= 1) // goes from 0 degrees to 65 degrees
// keep chase going
runChase();
// move servo
myservo.write(posServo); // then can read again
delay(25);
else
myservo.write(0); // tell servo to go to position in variable 'pos'
delay(25);
// my Functions
void ledChase ()
// 1. chase leds
for (int n = 1; n < 9; n++ ) {
ledToDisplay = pow(2,n) ;
// take the latchPin low so
// the LEDs don't change while you're sending in bits:
// Serial.println(n);
// Serial.println(ledToDisplay);
// delay(1500);
digitalWrite(latchPin, LOW);
// shift out the bits:
shiftOut(dataPin, clockPin, MSBFIRST, ledToDisplay);
//take the latch pin high so the LEDs will light up:
digitalWrite(latchPin, HIGH);
// pause before next value:
delay(50);
// now chase back in other direction
// delay(1500);
shiftOut(dataPin, clockPin, LSBFIRST, ledToDisplay);
delay(50);
void runChase ()
unsigned long currentMillis = millis();
if(currentMillis - previousMillis > interval) {
ledChase();
previousMillis = currentMillis;
Step 5: All Done - Another Video
This shows the insides and the LED chase working.
MakerBot Challenge
Egg-Bot Challenge
