3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Bike Painting Tips
Bike Painting Tips
I have painted a couple bikes for my friends so I thought I would share some tricks I learned in the process.
Step 1Frame Prep.
- To strip bike frames completely I use brushon (not aerosol) Aircraft Stripper. With the brush on variety you can load it on, let it dry and get almost all the paint off in an hour or so. Be careful though, this stuff is EXTREMELY TOXIC!
- If you only want to sand down the current paint, my favorite method is to use 180grit wet/dry sandpaper. I keep a bucket next to me and rinse off the paper when its starts to clog with old paint. The wet sanding cuts through the paint pretty quick but it still takes awhile.
- I tape off all the holes and trim the excess with an exacto. I stuff a roll of newspaper in the seat tube because Ive seen motorcycle builders do this so I feel cool. Get decent masking tape that sticks well but doesnt pull off paint. I have found that the blue house painters tape doesnt stick well enough for detail work but is fine for masking big areas.
- If you can, wait for a warm, dry day. It will help the paint bond well.
257 comments
1-40 of 257next »
Sep 17, 2009. 2:27 PMfastback570 says:
SICK blue print bike This is a bike that belonged to my mom from about 1964... 69 Camaro Hugger orange with a Dodge Off white . PPG Paint.
Jun 29, 2010. 11:50 AMfrenzy says:
This posting has won today's "I Made It" Challenge. For winning you will receive a 3 month pro membership!
Thanks for using instructables!
http://www.instructables.com/community/June-is-I-Made-It-Challenge-Month-Win-a-Pro-Mem/
May 17, 2012. 10:33 PMgfernandez2 says:
Do you think I can do this in two weeks?? Also, do you think it will last a two month cross country bike tour?
Oct 13, 2011. 7:25 PMgold fish says:
are we suppose to use 180 grit or 600 grit sandpaper?
Apr 22, 2012. 11:53 AMmetrometro says:
Both. 180 grit to remove paint. 600 grit to even out paint between layers.
The 600 will be very smooth paper compared to the 180.
Mar 29, 2012. 8:16 AMSamGerald says:
This is great advice for someone like me who wants to spruce up the look of their bike. Thanks for the guide!
Mar 14, 2012. 9:05 AMmga12 says:
Thanks for the info! Here's a shot of my newly painted bike (please overlook the dirty tires). I also found that it was useful to use a drill with a wire brush to take off what paint the stripper missed.
Feb 24, 2012. 4:24 PMpcorbett says:
That's a little plaid. This is a lot of plaid
May 6, 2008. 12:05 PMjohannalee says:
you could also ask the sticker or sign shops for odd pieces of vinyl. They run huge sheets that come wrapped around a tube through plotters and there's always ends that are usually too small to use for anything. there are a lot of extra pieces lying around our shop all the time. even mis-cut vinyl could be used for some cool paint effects. This is such a cool idea. I've wanted to do this for so long but never really thought about the right way to do it or the right materials to use. Love the plaid. Are there glittery spray paints?
Dec 6, 2011. 5:56 PMtwall3 says:
Yeah, they make aerosol cans of spray glitter. It's basically glitter suspended in a clear coat. I don't think it's super strong itself since it's kind of cheap and not really meant for high abuse jobs like bikes. I used it once on a bike that I was painting white but wanted to have a little metallic shine. I sprayed a coat of white, then a coat of glitter, another coat of white, glitter again, white a final time and then a few coats of clear. It came out pretty sweet, the glitter isn't overbearing but adds a nice touch and it has held up well.
May 27, 2009. 7:57 AMbibamofo says:
It's funny, when I saw the pics of Panda Face's bike, I just assumed that the plaid pieces were printed vinyl. I did something similar with my bike using JavaSigns.com and was pretty pleased with the way the vinyl decals turned out once I was done applying them. Still, I gotta say there's something more impressive about doing it the old fashioned way. Kinda cool to see someone do by hand what I used Illustrator to do. Bravo!
Nov 25, 2011. 11:55 AMckatzenburrger says:
so, i want to paint my handlebars like a candy cane i.e. white with red spirals. would it turn out fine if I used white primer, taped it up like white swirls, did the red, took the tape off and clearcoated it? would that look terrible cause on some parts it was only primer and clearcoat?
Nov 6, 2011. 2:29 AMbfunnekotter says:
I could not agree more with @fastback570....GET RID OF YOUR TELEVISIONS!
Feb 24, 2008. 7:51 AMxaviercugiecugat says:
Just finished my bike. Thanks for posting your instructions it was really helpful. I stripped the paint off, repainted a gray-blue base coat and used mod podge to glue on blueprints. The blueprints are from Rankin Steel Mill in Pittsburgh. They're schematics of blast furnaces and other parts of the steel mill. The mill closed in the 80s so these prints sat around for 20+ years which is why they are faded and have water blotches.
Oct 30, 2011. 6:58 PMWasagi says:
That is fantastic! I love how it turned out too. I may have to try this out with my Mountain Bike!
Jul 29, 2011. 4:04 PMstymemagnets says:
damn dude, that is just, wow
Jul 16, 2011. 6:10 AMxaviercugiecugat says:
I decided to do another bike a couple months ago. This one is covered in wallpaper. I used matte Mod Podge and then sealed it with a uv protective sealer. This time I mixed a paint color that matched the wallpaper and painted parts of the bike that I didn't want to cover in paper.
Jul 27, 2011. 7:17 PMflabiola says:
did you do anything before the mod podge or just mod podge straight on the bike frame? u should do an instructable...lol
Jul 27, 2011. 9:16 PMxaviercugiecugat says:
Lol. That's a good idea.
I used an angle grinder with a wire brush to get most of the orginal paint off the bike. I also used an eco friendly stripper that I found at home depot. Next I cleaned the bike and then primed it with a metal primer. Next I would cut a section of wallpaper and modpodge the backside strip of wallpaper and the section of bike frame. Once that dried I would give that section a sealing coat of mod podge.
Aug 20, 2011. 3:59 PMflabiola says:
Soo, i bought this bike and it has a pretty solid black paint on it... like real bike paint (idk what u call it) and i dont wanna strip it because 1) time 2) unsure how to do it right 3) scared lol ... if i just like... cleaned it good (wtvr that means?) could i modge podge OVER the original paint????.... do you think? orrrrr what would u recommend for not wanting to strip the bike.
Jul 16, 2011. 3:01 AMtmarques1 says:
your bike looks sick! I love it, awesome concept! did you have to spray the blue prints with acrylic sealer before mod podging it?
Jul 16, 2011. 6:05 AMxaviercugiecugat says:
Thanks! No I just put mod podge directly on the blueprints. It acts as a sealer. I then spray sealed it a few times. I should have put a uv resistant sealer because the prints faded a bit with time. Though it still looks good - just more of a light blue / green now.
Apr 18, 2010. 7:43 PMrattyrain says:
Wow, that's a really good idea; I'll probably have to try this with sheet music or something. . .
Jul 10, 2011. 8:26 PMnumber27 says:
heres what i did with sheet music and mod podge.
Jul 11, 2011. 6:47 AMxaviercugiecugat says:
Sweet! I love it.
Apr 18, 2010. 2:06 PMDemondavid says:
Amazing job
Jun 18, 2009. 10:24 AMnagutron says:
I love the texture! Awesome job.
Jun 2, 2009. 2:19 PMpineapplenewton says:
it looks like the paint is coming off is it?
Jun 2, 2009. 4:14 PMxaviercugiecugat says:
nope. the blue prints are layered and burned on the edges
Jun 2, 2009. 6:15 PMpineapplenewton says:
is it pasted on or is it a paint design?
Jun 3, 2009. 6:48 AMxaviercugiecugat says:
I pasted on old blueprints with mod podge.
Feb 27, 2008. 7:36 PMDr.Paj says:
did you put anything over the blueprints like a clear coat? or does the mod podge protect it (I have no idea what mod podge is). By the way, sweet bike, I have one almost exactly like it (old fashioned shifters too) The whole wall papering your bike with old blueprints is very original.
Feb 28, 2008. 5:26 AMxaviercugiecugat says:
http://www.plaidonline.com/apMP.asp#ModPodgeBrands
On the mod podge website it says a woman decoupaged her vw bug w/ mod podge
The topcoat of mod podge does protect it but I decided to also spray it with a high grade clear coat. I think I sprayed it 5 times.
Thanks
Feb 28, 2008. 4:28 PMDr.Paj says:
Nice, what brand of clear coat did you use and what did it cost?
May 2, 2009. 11:43 AMxaviercugiecugat says:
Nothing special. A clear coat that I found at Lowes.
May 2, 2009. 1:46 PMDr.Paj says:
What a speedy response.
May 28, 2009. 10:24 AMxaviercugiecugat says:
I try
Oct 11, 2011. 12:07 AMasofia says:
Here are a few things we have painted/ powder coated/ pin-striped/ made designs on for our www.villycustoms.com customers :)
Sep 17, 2009. 2:29 PMfastback570 says:
The plaid Looks great. Check this variation..
Jul 29, 2011. 4:06 PMstymemagnets says:
dabasseb dude!!
1-40 of 257next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
35
Author:Panda Face
