Birch and Aluminum Desk
  • last photo ←
This desk was designed to meet specific needs- it had to be:
1) Large enough to spread out a textbook, notebook computer, and writing notebook.
2) Durable, with legs that do not wobble or a span that bends under weight.
3) Without nooks and crannies that would fill up with knick knacks.
4) Modern, clean, stylish and a positive addition to my workspace.
My finished product has douglas fir legs, a birch top with steel panels and an acrylic overlay. The edges are finished with aluminum angle.
And so we begin with the materials:
1 4x8' 3/4" Birch Plywood
1 3x6' 0.118" Acrylic Sheet
1 12' 4x4" Douglas Fir
2 8' 1" Aluminum Angle
12 8x12" Galvanized Steel Flashing in Pre-cut sections
10 3/4" #8 Stainless Screws
4 4" 3/8" Hanger Bolts
4 3/8" Tee Nuts
1 Can Polyurethane Finish
Double Stick Tape
Glue
Wide Tape
Aluminum Polish
Car Wax
Tools:
Circular Saw
 Jigsaw
Square
Tape Measure
Drill with various drivers and bits
Router
Tin Snips
Step 1Plan and Cut to Size
This step was relatively  simple for me, as my steel panels were 8x12". My final dimensions for the top were therefore 32x60".
But layout a design on your available plywood and see what works best. With an acrylic top, you can put nearly anything underneath, I considered pictures, lights and many other designs.
I used a circular saw to cut the plywood down, a table saw or hand saw would work just fine as well.
23 comments
Mar 14, 2010. 1:46 AMtecneeq says:
Not bad. Not bad at all. Did you consider to get real glas instead of acrylic sheet? Should be scratch free for many years.
Mar 18, 2010. 6:46 AMFieldownage says:
 Yeah and you can always sand the plexiglass back to clear if you need to.
Oct 30, 2011. 9:47 AMorvis says:
Can you sand plexiglass to clear? I've not had luck with that; is it just a matter of going to a high enough grit?
Actually, even sanding the plexiglass frosted would be a very interesting look with the checkerboard materials behind it.
Oct 30, 2011. 10:10 AMFieldownage says:
You can sand it to clear again, but it is a slow matter of working up from ~200 to somewhere above 10 000 depending on how clear you want it to be.
Oh and also you would be sanding with water on the surface (to clear the dust between the surface and the sandpaper) for most of the time.
Sep 18, 2010. 1:39 AMkid007la says:
Great instructable. Just one quick question. Where did you buy the acrylic sheet and how much did it cost you?
Nov 13, 2010. 10:38 AMscrain says:
I was able to find a sheet with the exact same dimensions listed above at Lowes for $47.75... on their site it's listed as "DURAPLEX 30" x 60" Clear High Impact Acrylic", Item #: 11289, Model #: 1AG1775A.
Sep 20, 2010. 1:34 PMprenticehill says:
How durable is the acrylic with use?
Jul 7, 2010. 7:26 PMf2a says:
Nice, you could even write on it with dry erase markers if you wanted.
Jun 1, 2010. 2:52 PMZeboaz says:
Did you cut in more then you did on the second picture? Or simply cut all the way through the top part of the angle, and bent the bottom to fit the work bench?
Mar 14, 2010. 4:03 PMballisticboy101 says:
Thanks for the great instructions. How long did this take you and about how much did it cost?
Mar 20, 2010. 9:32 AMBHStibal says:
 does the price it cost you include all of the tools, or was it just materials? I really like the table and it looks really cool!
Mar 20, 2010. 11:52 AMDpdk says:
Haha, that's going to be only for the materials.
Mar 18, 2010. 2:34 PMjosiahkerley says:
Must be hell without a mousepad.
Mar 18, 2010. 5:06 PMjosiahkerley says:
Ok, cool.  Great looking project!
Mar 16, 2010. 10:51 PMRCMadMatt says:
Very nice! Simple, yet elegant at the same time. Well done!
Matt
Mar 14, 2010. 3:49 AMlemonie says:
Very nice job, and good instruction.
L
Mar 14, 2010. 2:56 PMnanosec12 says:
I think I would like to try this, but with a set of tarnished brass plates and a deeper mahogany stain.  I like the step by step of your 'ible, not too many boring details, and an overall assumption that if you are going to try this, you have some clue of what you are doing. Well written.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
21
Author:zwild1(Wild Inspired Media)
I like to explore.
