3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Blow Dryer and Red Brick Aluminum Forge
A charcoal forge for casting aluminum electrodes and casings can be made from a blow dryer and some clay bricks. Aluminum scrap comes in a variety of forms, mostly involving impurities of one form or another. This scrap can be reduced to (more or less) pure aluminum oxide (what we commonly call aluminum is actually aluminum oxide) by smelting it and removing the impurities which float to the top. The molten metal can then be cast into forms which are convenient for use in low and medium voltage al-air or al-oxide energy generation systems as well as other casting applications.
Unlike many other forges this one can be reasonably used in a residential environment without attracting undue attention from the neighbors. It's not particularly noisy and doesn't project huge fiery jets. It doesn't require permanent construction or a specialized installation. It can be put together, used and torn down in a single afternoon.
I really like many of the propane designs I saw but most people don't have a propane burner or nozzle assembly to spare so I decided that design which leveraged existing BBQ technology would be more widely useful.
The mandatory note: I believe the insurance company add that says 25 burned down their houses attempting to deep fry turkeys. Don't be an idiot.
No blow dryers were injured in the making of this instructable if would be nice if folks who tried this exercised great care and caution and no humans get injured in trying to do this.
Step 1Bill of Materials
Bill of Materials
As promised in the title the key are ingredients are common red clay bricks and a household blow dryer.
You'll need:
23 ordinary red clay bricks. I had some used brick laying around but new brick from Home Depot costs about 17 cents each. You can get firebrick if you want (I didn't). The concrete bricks would probably be okay but I can't speak to that.
An ordinary blow dryer. You can pick up a cheap one at Walmart or Target for around $15 or you can use on that you have. It will not be damaged or changed in this process.
A coat hanger
A BBQ grill at 18 inches in diameter. When all was said and done I used the top grill from my Weber, you will learn more about this decision in the next step.
Charcoal or biochar briquets, the charcoal must be sufficiently formed to rest on the fire grill.
A 30oz steel can. I happened to use Rosarita Refried Beans, this is a standard super market can size and almost any 30oz can should do. A small size may be used but for this design the 30oz is appromiximately the largest size that can be accomodated.
A catalog or magazine, preferably with slick, glossy pages ( clay paper ). We actually only need one page from it which will be damaged in the process.
A long handled tea spoon or small ladle for removing slag.
Masking tape
A 1 foot or so piece of steel pipe of approximately the same diamater as the blower tube on the blow dryer is convenient. Different diameter pipe may be used but if so a smaller diameter should be chosen.
A 2 foot or so wooden stick or pole that can be used in handling the crucible.
A can opener. I didn't show all the tools needed but I'm showing off the fancy, shmancy one I have...
Okay now if we've got all the bits together let's make a furnace...
84 comments
1-40 of 84next »
Dec 12, 2010. 11:40 PMafartinthewind says:
I have a old cast iron stove i use to melt Al. I cut a old Co2 tank for a pantball gun in half and use that as a crucible, its high carbon steel with 1/16" walls and when I pre heat it to a deep red (and dont overheat the Al) I dont get any sticking and minimal slag. i just welded 3 legs@2" on the bottom and a "U" shaped handle for pouring on the top. gave it a football shape in a vice and good to go. it can hold about 3 cups no problem and can hit a good yellow hot without damage. By far the easiest to make and most durable crucible i have ever used.
May 14, 2012. 4:13 PMcfreitas says:
Very nice instructable, I will give a try on this one. I have only one doubt : I understand that the molds are sand made to permit the gas from the molten metal escape from it when solidifying, but, is possible to make molds from cement or something that I can use several times ?
Thankyou for sharing this instructable.
Jan 8, 2012. 1:11 PMthecrow117 says:
does this furnice get the aluminum hot enough to make lost foam castings?
Dec 21, 2011. 10:06 AMjadronx says:
awesome instructable i will be trying this soon!
Dec 19, 2011. 5:12 PMpdidit says:
lot of great info here. Gotta try this build some other places you all might like are www.backyardmetalcasting.com and www.metalcastingzone.com
2 things that will help the casting are cover flux and degasser A quick search will turn up sources
Dec 18, 2011. 11:53 PMwilkinde says:
In your introduction you claim that all aluminum scrap is really aluminum oxide. This is false. All aluminum scrap contains aluminum oxide - which is a clear ceramic with a melting point of 2000 degrees Celsius (3600 degrees Fahrenheit). The base aluminum melts at 660 degrees Celsius. This is why aluminum must be welded with an inert cover gas. Once the thin ceramic surface is fractured in air it oxidizes generating more aluminum oxide, until the over all heat builds up enough to fracture the oxide coating away from the edge - creating destructive puddling of the metal near the weld point.
In terms of your casting endeavor, the only significant issue is that the aluminum oxide coating guarantees there will be slag - no matter how pure your aluminum is.
Sep 12, 2011. 7:08 PMcardboardwizard says:
I love this instructable. But the part where you said aluminum is aluminum oxide is only partly true. Pure aluminum metal gets an extremely thin layer of aluminum oxide. Also called alumina it is in itself a great refractory & is extremely hard.
Sep 19, 2010. 8:06 AMComputothought says:
Cool. Have to try this with my heat gun.
May 14, 2011. 9:59 PMsparmar1 says:
a blowr can give much efficient.
Sep 22, 2010. 9:16 AMComputothought says:
Your probably right though the extra heat could not hurt. I can always go to Goodwill and get a cheap hair gun and not wear out the heat gun..
Sep 22, 2010. 4:55 PMmoonchylde says:
Cold air is denser and thus has more usable oxygen. Hot air is just a waist of electricity.
Oct 6, 2010. 7:59 AMtomtortoise says:
Yo im wondering if the can is going to melt holding the aluminum
Apr 18, 2011. 8:18 AMasteidl says:
The can is (usually) made from steel, which has a much higher melting point than aluminum. Different steel alloys have different melting points, so I couldn't say what a "tin" can's mp would be without knowing the alloy, but it's generally around 1370 °C. Elemental aluminum melts at 660.37 °C, while Al2O3 has a melting point around 2,000 °C.
Apr 1, 2011. 12:44 PMxraver7086 says:
I tried this and i couldnt get the aluminum to melt. any suggestions?
Apr 8, 2011. 12:38 PMxraver7086 says:
i used a tin can, like yyou said. i used a whole bag of charcoal, i was trying to melt soda cans. i used a leaf blower for air and it got extremely hot
Apr 18, 2011. 5:13 PMxraver7086 says:
Our county currently has a fire ban and im currently in High School so trying to find the time to do this and a secluded place is really hard, but i plan to use a smaller fan. just need a good, cheap fan.
May 4, 2011. 5:18 PMDrDontDoDis says:
I use a leaf blower, but the nozzle must be kept a few feet from the mouth of the furnace or the air/charcoal mix will be too lean and the fire may actually be colder (not to mention you could go through 50 lbs. of charcoal in 15 minutes). If you have a very large melter than you could hook the blower right up. However, if you do go with a leafblower DO NOT use wood charcoal. A leafblower used in a tall, thin furnace could give hardwood charcoal enough air to reach steel melting temperatures (as in a cupola), and ordinary bricks can't handle anywhere near those temperatures.
Dec 5, 2011. 6:26 PMxraver7086 says:
hey its been a while but ive been thinking of a new plan that uses these materials and a few modifications to increase insulation.
Dec 18, 2011. 11:34 AMxraver7086 says:
unfortunately, my dad used my bricks for a different project with out asking, and they cant be retrieved(under at least 1 and a half foot of cement). With it being christmas, i cant afford the bricks. when i get them, i will test it out immediately.
NOTE: my bday is commin up, and so i expect to get cash to get bricks, so the inst. is coming soon.
Mar 8, 2012. 9:00 AMxraver7086 says:
I finaly did it!!! Instead of bricks, i just dug a hole and attatched a pipe to the bottom. worked great!!
Apr 18, 2011. 8:26 AMasteidl says:
Love the idea, will try this soon! I drink a boatload of [citrus soda] and [cola] (I'll be fair, and not advertise, lol), and always save my cans for profitable scrap. I'll see how the scrap yard responds to processed ingots! I'm thinking I might even get a better price, since many impurities are removed, and pretty much did what the large recyclers do. The smaller recycling yards compact the cans, then ship them to a processor that either ships the cans to manufacturer (who processes the cans themselves) or shred and melt them down to ingots. I'll report my findings! :D
Mar 4, 2011. 10:31 AMcowscankill says:
The use of the grill cover is brilliant. I think this is going to be the design for the forge I am building. I don't have the resources for concrete, bricks will do fine.
Mar 5, 2011. 4:47 PMcowscankill says:
I tested the design today and was able to heat treat two knives! It's great, thanks for the post :D I also manage to melt aluminum in it, so I plan to do a lot more in the future.
Jan 29, 2011. 6:59 PMAppollo64 says:
This looks really great! But does anybody have any idea on how to make a good mold for casting the liquid metal?
Oct 30, 2010. 8:22 AMmasoon says:
what setting did you have your hair dryer set to? Did you let the charcoal burn awhile before using the blow dryer. If I use unheated air will that work?
Sep 29, 2010. 10:51 AMFirestorm_101 says:
I have just had a brilliant idea! I hope its brilliant anyways... I got to a technical career school for computer, and in another class on the other side of campus is a machine tool shop with several lathes and the like. I know they get there Al peices from a factory that tosses the pieces out as scrap, being they must be a uniform size in there machines. I doubt they will give it up to me, but the machine tool shop in the school is going at is constantly, could the Al shavings from the lathes be used for this setup?
1-40 of 84next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
155
Author:egbertfitzwilly(More about me at LinkedIn....)
