loading
Beds are problem for the nomad: too big to move, and too expensive to leave behind. By default, many of us end up with a box spring on the floor, down in the dust bunnies and lost crumbs. Putting the mattress on the ground also eats up a lot of square footage in a cramped apartment, taking away an opportunity for storage underneath.
I moved halfway across the country recently, leaving my old 2x8 Bed behind, and was looking to buy a spare, modern storage bed to replace it. Looking at Ikea's offerings online, I came across the Brimnes bed and realized hey, I could make that! While this version lacks drawers, it is still a sleek, low-slung modern bed with four sizable storage compartments, hidden behind sliding geometric screens.
The Box Bed breaks down into four identical plywood units, each small enough throw in the backseat. Each unit is stiffened with an internal rib, fitted with a shelf, and has two sliding doors made from old radiator covers. The platform nature of the bed gives good, even support and eliminates the need for a box spring (saving money!).
I made mine from high-grade plywood, running up the cost. Very little of the plywood is actually exposed, so you could substitute cheaper grades to save cash. I used 1/2" stock instead of 3/4" where possible in an effort to reduce weight and expense. I also made this whole project with just a circular saw; it would go faster and be more accurate if you had access to a table saw.
(Apologies for some of the photos; the bedroom is small and so it is hard to back up far enough to get the whole bed in the frame)
If you find this Instructable helpful, please throw a vote my way in the I Could Make That contest! Thanks!
You will need these materials:
2 4x8 sheets 3/4" plywood
2 4x8 sheets 1/2" plywood
Wood glue
#6 x 1-1/2" slip-fit wood or drywall screws (I used Spax hardwood screws, which are superb for preventing splitting in plywood)
3/8" dowels for shelf pins and screw plugs
You will need these tools:
Pencil
Tape measure
Speed square
4-6 12" bar clamps
Circular saw
Drill/driver
Relevant safety equipment
Step 1: Cuts!
To make these directions easier, I will just relate the construction of a single box; repeat four times for a whole bed. The dimensions here are for a queen mattress, which is 60" by 80". Refer to this Wikipedia chart and adapt for the dimensions of your own mattress. A single (twin), could be supported with just two boxes instead of four.
Cut one panel of 3/4" plywood at 32" x 42" (the top); one 3/4" panel at 32" x 14" (side one); one 1/2" panel at 32" x 14" (side two); one 1/2" panel at 40-3/4" x 14" (the stiffening rib); one 3/4" panel at 40-3/4" x 3" (the door track); and one 1/2" panel at 40-1/2" x 18" (the shelf).
To cut square pieces out of sheet goods with just a circular saw, clamp down a straight edge, forming a temporary fence. Measure your circular saw from the edge of the baseplate to the face of the blade, and offset the straight edge from your desired cut line by that same amount. When cutting, push the straight side of the base plate of the saw against the straight edge, guiding your cut. For clean cuts in sheet goods, use a 60-tooth finishing blade with carbide teeth, which will cut smoothly with minimum chip-out.
For cross cuts, clamp down a speed square, registered against the long edge of the work piece, as your saw guide.
All the measuring and clamping and re-arranging is kind of tedious, but important for accuracy. Take the time to make precise cuts, and later joinery will be painless.
Step 2: Dadoes!
dado is a groove made in a piece of wood by running a blade through it at a shallow depth. Dadoes are much easier to make on a table saw, so if you have access to one, by all means use it.
Set the blade depth on the circular saw to 3/8" of an inch. Test cut on a piece of scrap to ensure the blade depth is accurate. Run two cuts on the underside of the top (the side that is more flawed), parallel to the long side, at 1" in from the edge and 1-3/4" in from the edge.
Set the blade depth to 1/8" of an inch. Repeat the above cuts, mirroring them in the 3" strip of wood that will be the bottom track for the doors.
It is important that these cuts be super accurate, so take care in setting up the straight edge. The depths are also important, as they allow enough play in the doors to make them removable if need be, so again, take care in registering the saw and make some test cuts to confirm accuracy.
Step 3: Assembly!
On each 32" x 14" side panel, mark a line 12-1/4" in from 14" edge. Mark out three screw holes. On the opposite side of each panel, mark a line at 12" from the same side, which will serve as a straight line to register the internal rib. I plugged the screw holes for looks, though this is not strictly necessary; if you want, counter-bore each screw hole with a 3/8" bit, a 1/4" deep.
Coat one end of the rib with a thin, even layer of wood glue. Tilt up and align one side of the 3/4" rib panel with the 12" mark on the side panel. Pre-drill and screw together, using a square to check that everything is flush.
Attach the door track parallel to the rib, flush with the front of the 3/4" side.
Repeat for the matching 1/2" side panel, forming an asymmetrical "H"-shaped arrangement when viewed from above.
Coat the top edges of the "H" with a thin, even layer of wood glue and lay on the top, making sure all corners are flush (tweaking the underlying structure as necessary), screw the top to the sides and ribs. Lay out your screw holes evenly for a neat appearance.
Halfway up the inside, drill out 6 3/8" diameter holes 3/8" deep -- two on each side and two on the stiffening rib -- and glue in 3/4" chunks of dowel to serve as shelf pins.
Keep in mind as you assemble the boxes that you must make 2 sets of 2 boxes, mirroring the arrangement of the 3/4" and 1/2" sides.
Step 4: Doors!
I made the sliding doors out of old sheet-metal radiator covers, salvaged from a house where the radiators were being ripped out. Any number of materials could work, though the dadoes might need to be widened. Use Masonite, frosted acrylic, sheet metal, or even heavy-duty chipboard.
Set the material on a scrap piece of plywood. Clamp a straightedge down. Set the blade depth on the saw to about 1/8". A carbide finishing blade (60-tooth) will cut sheet metal fairly handily (it's what I used). You can also buy specialty sheet metal blades, or use a regular framing blade with the blade rotating backwards. Wear safety glasses, tight-fitting gloves, ear muffs, and long sleeves. This process is really loud and kicks up a lot of crap.
Cut eight panels, each at 13-1/2" x 22". If using a radiator screen with a geometric cut-out pattern, strive to make the cut lines fall on solid seams.
Smooth down all the burrs, rough edges, and corners with a flat file and sanding block. Spray paint with metal enamel. Mount a handle at each end of each door with sheet-metal screws, made out of a scrap of 1/2" plywood.
Step 5: Finishing
Sand all surfaces with 120 and then 150 grit sandpaper on an orbital sander. Make sure to get the plugs flush and take care not to grind through the veneer.
Plywood tends to be rather dense and un-accepting of finishes. The high glue content and thin veneers keep it from being very absorptive. In an effort to darken the wood a bit and bring out the grain, I used a mixture of 80% teak oil and 20% paint thinner for the undercoat. The thinner helps get into the denser grain. Rub the oil into the wood with a clean, lint-free rag, let sit for fifteen minutes, then buff off any excess with another rag.
Once (thoroughly!) dry, buff down with some high (220+) sandpaper, then top coat with an oil-base poly. I used a water-base poly, which is fine as long as the undercoat is 100 million percent dry before the top coat is applied. Otherwise, the top coat can bubble and peel.
Once dry, buff down with 220 grit and wax. Assemble the four boxes in a grid so that the 3/4" sides of each bed are all to the outside perimeter and the 1/2" sides are to the interior. Insert shelves, then flex doors into place, sliding the top of each door up into the top dado first and then settling into the bottom dado. If doors don't slide freely, sand down the edges and wax a little bit with paste or auto wax for smooth operation.
Throw your mattress on top and take a well-deserved rest!
<p>Hi!</p><p>I made a CAD model of a box bed using openscad (http://openscad.org):</p><p><a href="https://github.com/markvdb/openscad/blob/master/boxbed.scad" rel="nofollow">https://github.com/markvdb/openscad/blob/master/bo...</a></p><p>Change the 3d parameter in the source file to switch between 3D view and (work in progress) 2D panel cutting instructions.</p><p>Thank you for the inspiration!</p><p>Mark</p>
<p>Hi Mark, that is rad! Could you credit me as the designer in the GitHub page though (www.objectguerilla.com)? Also, there is a rad new platform for posting code for objects here: http://www.openthings.wiki/. This would be perfect for it.</p>
<p>Hello Wholman,</p><p>I did as you suggested:</p><p><a href="https://www.openthings.wiki/en/project/view/41" rel="nofollow">https://www.openthings.wiki/en/project/view/41 </a> .</p><p>Kind regards,</p><p>Mark</p>
<p>Hello Wholman,</p><p>There was already a reference to this page in the source file. I have updated it and the README file with references to you (&quot;Wholman&quot;) and your objectguerilla.com url as requested.</p><p>I'll have a look at posting this openthings.wiki too...</p><p>Mark</p>
<p>how much did this cost you though?</p>
<p>I'm not sure if I'm doing some bad math here, but how are you able to make 4 boxes with only 4 sheets of plywood? With 42&quot; sides, you cant cut more than two pieces from a single sheet, no? </p>
might be a stupid question, but I need to make (quickly) a couple of bed bases like this to get our mattress of the floor (hellacious dust bunnies here). I assume that the doors are for aesthetics only and that they don't provide any support...ie are the necessary? to speed/make it cheaper, I can leave them out, right?
Oscelot is right, the doors are not structural. It is helpful, however, to still include the 3&quot;-wide strip of plywood that is used as the bottom track for the doors, as it braces and squares the structure.
great stuff, thanks for that, you have my vote! <br>
I imagine if the doors were structural you wouldn't be able to move them. Generally the support for this sort of thing comes from internal struts, which is why things like tv cabinets often have so many compartments - the walls are supporting the load.
How important is the placement of the internal ribs? Can they be made smaller? It's not super important, but I was thinking with them all the way to the back of the box (or with them being three inch ribs towards the top of the unit) you could gain a lot more storage space under the bed.
The ribs essentially divide the structure into thirds, so that the ribs fall roughly right under the sleeping occupants for maximum support. If you move the ribs all the way to the back, the top of the boxes might sag. Secondly, the storage space, as is, is about as far as you can reach. The gain in storage space would be essentially inaccessible.
This looks really awesome, but I feel like the mattress would slide around a lot when, uh, &quot;getting intimate&quot;.
Adding a lip around the edge would help and wouldn't be too difficult. Just a piece of wood 3&quot; wide and as long as the side of the box you're putting it on. One for each outward facing side of the box, creating an 'L' at each corner.
double sided carpet tape is your friend.
I LOVE this! I'll bet I could make this myself with these instructions. I'm not a guy, but I love working with tools and wood. Thanks for a lovely idea!!! I have always wanted one of these box beds and it would certainly help with our storage shortage. Big house -- no closets to speak of! Need extra storage and this is just the ticket!
Looks nice! But have you thought of ventilation? An average person looses about half a liter of water a night, some via breath, some from sweating, estimated is that at least 0,1 liter goes in the matras and it needs to leave it again else you will get fungi or other species growing under and in the matras. Suggestion, raise the matras and supports with smal beams so at least half of the bottom surface is open.
I wondered about the same thing. Another idea would be to drill a bunch of holes on the top sides of the boxes to provide some ventilation.
Platform beds are pretty common; even beds with slats often have a thin sheet of Masonite or plywood to more evenly distribute the weight of the mattress. The mattress has 16 hours of unoccupied time to dry out every day. An mattress pad also keeps a lot of that moisture from ever entering the mattress. <br>
Agreed, wholman. If you just leave the bed stripped once a week and don't be too fussy about making it up tight every morning, that helps to keep it dry as well. There's also the old 'flip the mattress' every month or so if you don't have a pillowtop one. Mine's unflippable, but I do turn it so the foot becomes the head about 3 - 4 times a year and that helps too.
Good idea for storage space! <br> <br>My DH made us a king-sized platform bed (with no storage underneath). No problems with mold under mattress. But important suggestion: Make the box assembly a bit smaller than the mattress, or you'll be barking your shins against the wood all the time.
I'm always looking for projects to do with my girlfriend. So this helps. I'll admit I haven't read it thoroughly; do you have drawers on the left side as well?
There are shelves on both sides, yes; it is made of four identical units tiled together.
Im doing this. Ive been chilling with the dust bunnies too long now, very good. I voted for you...
WOWZERS!
About This Instructable
88,622views
1,449favorites
License:
Bio: Furniture hacker. Author of Guerilla Furniture Design, out now. Find me on Twitter and Instagram @objectguerilla.
More by wholman:Flat File Base Campaign Desk How to Launch a Pop Up Shop
Add instructable to:
