Introduction: Bride and Groom Lego Couple Halloween Costumes
In one particularly foolish moment we decided to go large, and make perfectly proportioned lego heads for the halloween parade in New York City. The heads would be worn as part of a Lego Couple (Bride and Groom) pair. This is a quick guide on how we made the costumes, in particular focussing on the heads themselves. With on-board electronics, they deserve a detailed look.
Enjoy!
Step 1: Materials (necessary and Not-so-necessary)
Polystyrene Insulation
We got through a fair bit of this. They come in large 8 foot by 2 foot sheets. They're meant for housing insulation but they also work great as the basis for lego heads. They also provide maximum fun while carrying them back for 20 blocks through a windy New York October. Depending on the proportions of your body size, you'll need to adjust your head size (and amount of polystyrene) accordingly.
Fans, Battery and Switch
All from radio shack - as I was building these heads I realized how ridiculously hot they were going to be inside. The fan was meant for a computer and the battery was a 9 volt with a small switch in between. If you're going for the less complicated route, this would be the thing to skip. In fact my better half was shocked that I was putting time and effort into such an elegant solution. Hey, it was worth it on the night!
Paint
Again, we tried to match an actual lego head as closely as possible. Home depot was our supplier in this case. Vast quantities of yellow and black (Groom) and yellow, white and black (Bride).
Step 2: Cutting Heads
Measuring
The most important part of making the heads was the preparation. We took a picture of a mini-fig off google, printed it out, and made it into a kind of grid, with the proportions based on a 6 foot tall boy and 5 foot 5 girl. We made the decision that even though we're different heights we'd make the heads themselves the same dimensions. When you scale the mini-fig dimensions (e.g. width of head and height of head including 'bit' on top of the head) to human proportions, they really are bigger than you think. Don't back down at this point and think 'oh well make them smaller', they really do need to be that big to get the slightly 'square' look of the mini-fig.
Once we had the dimensions (the head was about 15 inches 'wide' - diameter in the end) we went ahead with planning the cutting of the circles into the sheets of polystyrene. Our heads landed up being made of discs which were 1 inch thick - 2 discs around the neck, 13 discs high for the main part of the head, and 3 discs high for the 'bit' on the top of the head. Total of 18 inches high, roughly... I actually just measured it and it looks like they've either squashed slightly or they were always slightly less than 1 inch - total height is about 17 inches.
Cutting
Work out how many discs you need, and what sizes, then it's just a matter of drawing them out on the huge sheets of polystyrene without wasting too much in the gaps. We had to keep going back to the hardware store because we underestimated. Then the hardware store ran out, then we had to go to hardware stores further and further away... fun!
A craft knife / box cutter with the blade pushed out so that it easily reaches through the thickness of the polystyrene works easily for cutting out the discs. We drew the circles using a pin and string with a tiny loop tied into it at the appropriate length. High tech stuff.
I cut out the discs 'whole', so no hole in the middle at this point. At the end of it, i had a stack of correctly sized discs that i could pile into a shape of a lego head. Due to either my drawing skills or my cutting skills I landed up with very slight differences in the discs, so at this point I spent a while shuffling them all into the optimum order and orientation so that they were pretty much all perfectly lined up. At that point, I drew lines on them and numbered them so that I could put them back together in the right order and orientation. Probably in my sleep.
Step 3: Fitting and Gluing
I started at the bottom. I'm not sure if that's contentious in lego-head making circles, but that's what I did. I started by cutting the bottom two discs' holes out, pretty much an inch or so away from the edge so they were reasonably thin. I then put my head through, and had a feel around and felt how I needed to put my head through it. Cut a hole in the first large disc (the lowest 'full' disc in the head), then tried that on too. When I was comfortable, I hot-glued the two smaller 'neck' discs together, and then glued the lowest 'full size' disc on to the top of that. Again, tried it on just to make sure it was comfortable.
The next 12 discs were basically trying them on my head, cutting, trying it on, cutting more, trying it on, gluing, then next disc. Gradually working my way up to the top of the head. HOWEVER I did make some just-in-time adjustments for the fan, switch and battery at this point, which is waaaaay easier to do when you're still cutting the individual discs, not when they're all glued together. See the next section!
Step 4: Battery and Switch for the Fan!
On the third disc from the bottom, (so that's the first large disc, right? are you with me?) I made a small notch into the inside wall of the disc so that I could stuff the switch into the gap. I didn't really plan on gluing it, I'd just let the polystyrene hold it in place. Then up on the 7th and 8th discs up (5th and 6th full size discs up from the bottom) was where I was going to store the large-ish 9 volt battery. On the 7th disc, after cutting the hole in the middle to the desired size, I cut a 9v battery sized hole near to the inside edge of the disc, but not *at* the edge, so if you imagine the discs on both sides of it, effectively that hole would be hidden. However, on the one above (8th disc up) I then cut a hole which was cut in from the inside edge of the disc, but was slightly shorter. Basically if you can imagine (and I'd be impressed, given how badly I'm explaining this), when you fit the discs together you want to be able to insert the blocky battery in the hole on the 8th disc, and push it into the snug gap that's in the 7th disc. That way gravity keeps it on the 7th disc, and it can't slide out and hit you in the head.
I've drawn an equally dismal sketch of a top view of discs 7 and 8. You can see the battery size hole where the battery actually finally sits in disc 7, and the disc above (disc 8) you can see where the hole is where you slide in the battery from the inside. The mess underneath is the side view of someone wearing the head, with the tetris shaped hole in the right where you slide in the battery and it goes down to the lower disc level.
The end result of these placements is that the battery is nice and safe, and away from rain etc, and the switch is nice and accessible right by the neck, where you can easily fit a finger up between your neck and the neck discs to flick it on/off as needed.
Step 5: Fan Placement and the 'Bit' on Top
Towards the top of the head, the natural inside hole size starts to get smaller and smaller as your head curves into a crown at the top. So the top 2 or 3 discs might be whole, with no middle hole needed. However for the fan, I cut a circular hole so that the fan air could travel through to my head, but the fan mounting (which is square) would sit wedged safely up in the top disc (note that this was the top full disc, not the two 'bit' discs).
I didn't want to skimp on details, so even though both of us would be wearing something on top of the heads, I wanted the 'bit' on the top of the head to be proportioned correctly. These were the 3 smaller discs on top of the head. Again there was a hole cut in these, not because anything was going there, but so that fresh air could be sucked in from the outside and pushed through into the head itself. I also added black mesh to the middle disc to keep out anything from fluttering through in case it somehow got through to the head and the fan.
Step 6: Finishing Steps
Once the main head was glued together, we used an electric sander to smooth the side of the head into a perfect circle, and to smooth the bottom and top corners of the head, to make it into that characteristic mini-fig smooth cube shape.
One thing I would do differently - the polystyrene sheets have plastic backing on each side, which kind of comes off, but doesn't really. We tried to peel it off, but when it was so difficult we left it, figuring it wouldn't harm as we'd be hot-gluing them together anyway. The only point where this became a problem was when we were sanding down the sides of the head. We found that the double edge of the plastic between the discs was just enough to stop it fully sanding. So we had to painstakingly use a knife around all the disc joins to attempt to cut out the plastic edges. I think this is why you can see the joins between the discs more than you really should.
Step 7: Painting and Head Accessories
Once the smooth heads were finished, it was a matter of stabbing the eyes into place (literally). At this point we could wear them snugly, and they were completely dark inside. we marked where our eyes were roughly on the inside, then drew out the actual lego eyes and mouth in paper shapes on the outside. We moved the face so that it roughly lined up, and then put a screwdriver through and hollowed out the two eyes. They never really matched our actual eyes, so seeing through them was like looking through two wider-than-your eyes toilet rolls. To be honest we didn't fully think this through, but we cared more about the look of the front of the head compared to actually being able to see anything on a parade route through New York.
Painting the heads and eyes (I went with mesh in my eye pieces, Jeni declined for added visibility) was pretty self-explanatory. The top hat and the bride's veil were made in the same way as the heads, with discs of polystyrene. Both 'snapped' perfectly onto the dimple on the top of the lego head by making sure the outside ring of the top hat fitted snugly to the outside of the head, and the inside piece of the hat had an opening for the head-top dimple to fit through.
The other consideration was that both the hat and the veil had vents in the top (more subtle on the veil, and just a circular hole with mesh on the hat) to allow fresh air to be pulled through into the head space by the fan.
Step 8: The Body Part of the Costumes
This instructable is really about the lego-heads themselves, but the costumes were pieced together using the dimensions found from scaling up the mini-fig right at the beginning - then cutting out the pieces in vinyl. The vinyl was then stuck onto poster board to make it more rigid. Corners of the suits were made by wedging triangles into the corners of legs and bodies, to make them keep their shape.
The front of the groom had the white areas cut out of poster board (it looked like a wiggly martini glass) and stuck onto the black vinyl body. This was drawn freehand on white poster board, then cut out and glued to the black vinyl.The flowers were then made from leftovers - a nice touch for a late night wedding parade down in the village. Leftover polystyrene made the flower heads themselves, and rolled up card for the stems.
The hands were cut from Quaker Oats canisters. Two layers for each hand, with a large hole to slip your hand into on the back layer. Once assembled, they were also painted yellow. Simple yellow kitchen gloves were used to cover our hands and wrists.
Step 9: The Final Result
In hindsight we had a fantastic time making these. We bit off more than we could chew with the timeline, but we were determined to do the best we could. We were finishing it right up to the last minute, which meant that we had tried on the body individually, or the head on its own, or the feet etc. Down at the parade was the first time we put the whole costume on, and at that point we were bowled over with gratefulness that we had a number of awesome 'minders' down there for us. We could just see a point on the road ahead of us about 10 feet, and a small area around that. Getting off / on sidewalk steps was a fun game, and avoiding others in the parade nearly impossible!
Fans? Definitely worth it - they get really hot in there. I guess the stuff that they make to keep houses warm/cool also insulates human heads very well. Everything held together well, and I think the only running repair was chewing gum applied to one of the flower heads that slipped down the stem at one point.
We even made it into a movie - 'Fat Sick and Nearly Dead'... a random shot of the NY halloween parade included a side view of us!
Would definitely do it again!!! Hope you enjoyed reading, and hope you have fun if you decide to give this a try.
Halloween Epic Costumes Contest
