So what do you do with them when they die?
Just throw them in the trash - which harms the environment?
Or just take them to a recycling facility for them to be recycled?
Well, here is the best solution, bring your dead batteries back to life that can save you a chunk of change - By zapping them!
Here is one great instructable, Revive Nicad Batteries by Zapping with a Welder. Of course, you will need a welder, and not many people has one... So I came up with this idea that almost anyone can build!
UPDATED: This instructable has been featured in hackaday!
DISCLAIMER:
This instructable involves hacking a device that operates on 300 volts and can be dangerous if not handled correctly. So, I am NOT responsible whatever happens to you using this information.
Remove these ads by
Signing UpStep 1So, Why do Ni-Cad batteries die?
They don't exactly 'die', it is the sulfur crystals that is causing the problem.
The crystals are formed and begin growing caused by:
- Overcharging the cell
- Leaving the cell in the discharge state for a long time
- Memory effect
- Being exposed in high temperature
But, the good thing is the sulfur crystals can be easily destroyed, by putting a hefty surge current through the cell... This vaporize the crystals and the battery should be good as new again!
thought I'd share this, as it was very helpful to me (ran my roomba today for about an hour or so, so I'd say it worked especially seeing as before it couldn't even make the startup noise).
Don't think your batteries are going to be "good as new" afterwards though. Yes, you can get some more life out of the battery, but I've found they never have the same capacity afterwards (apparently it does some irreversible damage) and it only works a few times on a battery before it's gone for good. For this reason, I don't like to do it on a battery from a multi-cell pack -- then you just wind up with a weak battery in series with stronger ones, which is doomed to be overworked by the stronger cells and will die very soon anyhow.
Saludos.
and i saw this it looks very interesting. will this work with multi-cell batteries, like those from cordless drills, rc cars, and nicad laptop batteries?
Thank you .....
sasrf 04/03/11
Only thing I'm wondering is amps... seems like thats the key to the whole thing. Perhaps for single 1.2v cells it would be fine but for a larger bank of cells you may need something that supplies 30+ amps when it delivers the voltage? You know they always say its not the volts that kill ya, its the AMPS.
A lot of electronics beginners on this website like to use disposable cameras without understanding what they are playing with. :(
NiCd batteries do grow crystals, but they are not sulfur, because there is no sulfur in NiCd batteries.
Lead acid battery plates get covered by sulfur (sulfation), because their electrolyte is sulfuric acid.
Both are typically zapped one way or another to revive them, and it may or may not work, depending on your setup. Mine have often worked.
Similar concepts, incorrect wording in instructible.
A large number of people on this site who do not have the electronics knowledge needed to A: build a high voltage power supply, and B: keep them safe from high voltage, oftenly use disposable cameras as a high voltage source. Not that their safety is my problem, but still....
Sorry for any misunderstandings or ambiguities.
Does this work with nimh batteries?
or is there a different chemical composition in nimh's that makes this not work?
~/Lee
will this work with nimh batteries? i have 12 of them and if i can do this to them then i can use them again.
so does it work on nimh's?
http://www.instructables.com/id/Revive-Nicad-Batteries-by-Zapping-with-a-Welder/
We call it "Blowing Off The Wiskers".
~/Lee
