3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build A Work Table For Your Work Shop
Build this 4 ft x 4ft Work Table. Built from pine 2x4, 4x4 and 3/4, 1/2 MDF plywood. Features a pegboard, two electrical outlets, and three shelves on each side. The top has tic-tac-toe board shaped tracks for holding down work with your own jigs. Table edges extend past edges to allow for clamping. Top inserts between track are removable/replaceable. Can be replaced with soft material so that delicate items are not scratched. Put hard top pieces on for rough building work.
Comments welcome. If you build one, send me a picture... I'd like to see it.
Author comments added (6-Dec-2008):
1) Some of you want dimensions. I have these in AutoCAD DWG format for each part. I will upload that today for you to download. If you don't have AutoCAD to view the drawing then you can download a free DWG file viewer. All parts and assembly are on one DWG drawing. Use tabs across bottom (or zoom in) to view each part and assembly. Turn layers of the drawing on and off as desired.
2) For those that just want rough dimensions. Well it has 4x4ft top and is built to be the same height as my table saw to help hold large pieces while being cut.
3) For those that wanted to add wheels. As you can see in the pictures the bottom of the table has a gap between the floor. My plan is to build a device to mount under the table which will allow the table to be moved on a cushion of air connected to my shop air compressor or shop vac. That device is still in the prototype stages though. As you can see in the AutoCAD drawings the bottom rails have a cutout. In case you are wondering what these cuts are for... well its is to accept the air lift module that slides under the table.
4) I uploaded a material list (with assembly order instructions). It fits together nicely like a puzzle, but you must follow the assembly order to get all the parts together correctly.
5) Added a few more pictures for your enjoyment.
Step 1Tools Used
Tools Used
Table saw, drill press, circular saw, scroll saw, sander, sand paper, dado blade, router, wood chisles, newspaper, blue masking tape, rubber hammer, drill, level, square, screwdrivers, wire cutter/stripper, paint supplies, rags, vacuum, pencil, ruler, AutoCAD (or free DWG viewer program).
21 comments
Jun 8, 2011. 10:14 PMsypher says:
SO, can I just buy one?
Sep 26, 2010. 6:37 PMteh darkcloud says:
Nice.
Reminds me of the work tables we had in my middle school woodshop class. Except we had lockers on the bottom of ours and vices on each corner.
Jan 25, 2010. 3:33 PMjohnpombrio says:
Heh, Got one very similar but it is 4 by 8 and is on wheels. I use it for all of my portable stationary tools, (Router table, drill press,  drum sander, grinding wheel, belt sander, planer (underneath), plus a lot more!). One thing to try is to build a cord drop in the middle of the table by cutting out a section of the top and dropping the cords down to a strip on a shelve or cubby. That avoids cords being hung up on  the corners and keeps the surface clear of cords.
 Wheels work fine. Only hassle is the power cord that snakes out the bottom to power the bench. That can be a pain when moving it around a lot.
Jan 25, 2010. 3:45 PMjohnpombrio says:
May 21, 2009. 6:57 AMthdewey says:
Man that great. Nice tight/clean electrical work.
Jan 12, 2009. 1:03 AMxbox360ufo says:
ok!!!!!!!!!!!!!!
Jan 9, 2009. 2:03 PMseamster says:
This is a nice, well-made, tidy workbench. I really like the design. Good work!
Dec 25, 2008. 1:03 PMInstructagirl says:
This is an awesome plan and could be converted to a kitchen island if drawers were added.
Dec 11, 2008. 4:47 PMchrisbaker says:
Not to be a pain, but is there a chance of a different file format on the .dwg file? I don't have AutoCAD and Google Sketchup won't import it properly. I have several programs that claim to import .dxf files, so maybe that's an option for you? Failing that, how about a .pdf file (not editable, but at least more of us CAD amateurs could see it). Thanks! BTW: nice bench. ;-)
Dec 5, 2008. 6:15 PMshilohjim says:
Well,you've told us exactly what to buy. Some dimensions would be nice.
Dec 5, 2008. 11:35 PMravenxl says:
I think the dimensions are up to you, what you can fit in your workshop. Really, this is an awsome project, Ill be working on one that I can move since i dont have a workshop, plus, it would be awsome if we could mount a hand saw and make it a table saw. :D
Dec 6, 2008. 9:07 AMshilohjim says:
It is a great table. I'd like to build one myself. However, if the dimensions are up to me then the materials list won't be the same. I'd like to know his dimensions with his materials list then I can go from there.
Dec 6, 2008. 2:41 PMshilohjim says:
Thank you.
Dec 6, 2008. 5:23 AMjongscx says:
I agree, I have no idea how large to cut anything, or where the cut pieces go... and how much of what kind of wood? Great slide-show though.
Dec 6, 2008. 7:00 AMsoundmotor says:
I haven't thought about this kind of shop table in years. My high school had similar except with project lockers on 4 sides. Yours is a nice update more suitable to the home.
Dec 6, 2008. 5:30 AMRe-design says:
Nice work. I like the idea of storage on all 4 sides. I've had more fun building my jigs, cabinets, tables and such than I have building "real" projects.
Dec 5, 2008. 7:20 PMrc jedi says:
This is a great project to help future projects. I would add wheels with stops, (harbor freight). As you have done, leave it in the open so you can walk all the way around it. Dimensions are up to you. I prefer a higher table. Thanks for a great tool idea!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
52
Author:thb43
