3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a 6'-0" tall Wooden T-Rex Model
Build a 6\
I'm sure we've all seen those small wooden 3D dinosaur models. I had a few that I loved as a kid, but they all shared a common flaw. They were much too small!! As a father I set about to rectify that problem for my son. In the following steps I'll provide all the information you'll need to make your very own 6 foot tall T-Rex model!
(Please vote for me in the DADCANDO contest!!)
Step 1Tools & Materials
Tools & Materials
MATERIALS:
2) 4'x8' sheets of Oak Plywood (*see notes below)
Templates printed on 24"x36" sheets (from attached PDF on Step 2)
Wood Stain & Finish (optional but recommended)
Felt with adhesive backing
TOOLS:
Jigsaw
Jigsaw blades - 12tpi (teeth per inch) skinny blades
Drill with 1/4" bit
Sander w/ various grits
Router w/ 1/4" roundover bit
*NOTE: My T-Rex was sized and built using 1/2" thick plywood. Upon completion I realized that the legs, tail, and spine are a bit too flimsy. I'm going to recut just these pieces using 3/4" plywood. I would recommend using 3/4" thick for this project if you only want to buy two sheets of plywood, but keep in mind there is a weight advantage by using 1/2" for all the other pieces. I went with oak because it has a nicer grain and accepts stain better than pine. If you choose to go with pine, you'll need to use wood conditioner before applying any stain.
82 comments
1-40 of 82next »
Apr 28, 2012. 2:28 PMRobert McGrath says:
wonderful, thanks for making the plans available.
I adapted the Pterodon plans to cut with an Epilog Min laser at the Champaign Urbana Community Fab Lab.
Here is a blog article:
http://cucfablab.org/blog/pterodon-project-adapted-instructablescom-inlcudes-plans
Jan 12, 2012. 7:47 AMMichell Kwon says:
waw.. u made a big Tyranno! I bought 2.25cm Miss Tyrannosaurus almost 5 years ago, and now she has severe arthritis..! wooo.. but I love her!
Oct 21, 2011. 8:29 PMsarujin says:
This is what I built with help from the local CNC.
https://lh6.googleusercontent.com/-TXCqsDGaS0Y/TqIsMP82IJI/AAAAAAAAJqw/dLMsojsG4XQ/s720/P1050086.JPG
May 27, 2011. 11:06 AMtinker234 says:
add to my shop
Aug 3, 2010. 10:33 AMMischievous1 says:
I don't understand the cloud. Is there or is there not a cloud ? Why ? And if there is, how do pieces 8 and 3 hold together ?
Aug 3, 2010. 2:43 PMMischievous1 says:
Okay ! Thank you for your answer ! This cloud has been very confusing for me, I had not understood what it meant : I thought it was part of piece 8, I drew it and cut it in the wood (!!!) (And it did not fit very well with pieces 3, as you may imagine) Well, it learns me I should read all the comments before trying an instructable. I love this one. I will post photos of my little T-Rex soon. Thank you ! (PS : I printed the pdf on A4 paper, and my T-Rex happens to be only about 60cm high (sorry, I'm french, I don't measure with inches or feet. It must be about 2 feet high, a little less). How was I supposed to print it, so that it would be 6 feet tall ? I don't think I can put anything else than A4 paper in my printer...)
Aug 4, 2010. 7:07 AMMischievous1 says:
Thank you for your answer ! Here is the photo. It is 55 cm high, made with 10mm plywood. (One piece is missing in the tail, I had lost it when I took the photo, just found it back.) It's not perfect and it's got a few problems (particularly around piece 8, that I will have to do again), but I learned to use the jigsaw with this instructable, so I'm still happy with what I've done. About piece 8 : I've cut the cloud, but did only 2 notches, and I don't undestand why there should be a third one : one notch for each piece 3 (right and left), and what is the third one for ? I haven't got a router, and I was wondering what it was for. Making round edges on the pieces ? Is it really important, does it change the T-rex a lot ? I couldn't see on the photos. Is it a usefool tool? Isn't it a little expensive ? Are you planning on giving the plans of another dinosaur ? I'd love to try a new one !
Mar 16, 2011. 12:10 AMakgooseman says:
My spine and tail weren't very stable, even held by piece 8. I screwed metal splice plates alongside the notches in the spine and tail, above the slots, so they wouldn't interfere with the other pelvic pieces. It's rock solid now. Paint/stain blends the metal in with the wood. Awesome instructable and a great birthday present for my paleontologist girlfriend. I used 5mm ply for the bird and 3/4" ply for the strong-jawed walker. We'll tuck these bad boys on the edge of the woods bordering the road so sharp-eyed passers-by can enjoy them. Thanks!
Aug 4, 2010. 3:07 PMMischievous1 says:
Ok ! Thank you very much for your answers. It's the first instructable I achieve, and I'm really happy with the result. Be sure I'll vote for you at the "dadcando contest" as soon as I will have understood how to.
Jan 29, 2011. 11:31 AMaction pig says:
I searched "laser puzzle dxf" into google and came up with a bunch of sites promising free downloads. The bee puzzle looks particularly interesting...
Aug 31, 2010. 10:01 PMSirMonkeyBalls says:
Hey, great instructable! It took me a couple weekends to finish mine. I had a blast completing it, and made a little video of the final assembly...Enjoy! http://www.youtube.com/watch?v=7QYGfGb8-_8
Aug 1, 2010. 7:48 AMearlye says:
So funny to see this show up as part of the instructables email today. I just finished cutting and assembling, yesterday, a pteranodon as the first in my 3-member dino-menagerie for Halloween. I plan to suspend him from the house such that he looks like he's flying out of the garage. (Don't know if this link'll work or not... If not, there's a few progress photos...) http://www.facebook.com/album.php?aid=2059274&id=1522353866&saved#!/album.php?aid=2068825&id=1522353866
Aug 1, 2010. 9:18 AMsarujin says:
I have access to a CNC machine and i think that I am going try your method with a few tweaks. What about arranging the pieces on the scanner to fit in the 4x8 space? Do you know the copyright of the original models?
Aug 1, 2010. 7:50 AMearlye says:
For mine, I scanned a balsa pattern, rearranged the pieces in Inkscape (great open-source vector graphics app) until they fit very snugly into a 4x8 rectangle. I then hooked laptop to projector, and scaled the entire drawing until it consumed the entire sheet of plywood. Trace, paint, cut, done.
Aug 5, 2010. 8:40 AMsarujin says:
If you have the file, it would save me a lot of time. I have another dinosaur coming that I am going to scan too. I would be happy to share that file with you regardless.
Aug 5, 2010. 9:09 AMearlye says:
I have to look at the box for copyright info; if it looks kosher I'll post. The inkscape approach didn't take very long - the main thing was to avoid resizing the bits once they were traced. It'd be nice if you could put it in a mode where the sizing widgets are disabled. Maybe an hour or two for that.
Aug 7, 2010. 6:46 AMconfortif says:
I'm thinking about building this in 1/4" steel to put out in the yard. I can cut the metal with my plasma cutter by following a line but it is best if I use a wooden pattern which requires me to offset the pattern lines for the plasma nozzle size and that takes me modifying the CAD model before plotting it out. It is obvious you created the pattern using a CAD program of some sort. I was wondering if you would share the CAD file?
Aug 4, 2010. 1:38 PMfizzix18 says:
Great work, nice project. It would be nice if you would share your CAD files (DXF, SVG , CDR or whatever) with the rest of us, I would like to cut out the part with a laser cutter at a FabLab.
Aug 7, 2010. 9:33 PMsarujin says:
Found a German site that might have what you need. Here is the t-Rex http://www.blechwelt.com/teil_des_monats/dxf/Tyrannosaurus-1.dxf Here is the main site: http://www.blechwelt.com/teil_des_monats/archiv Lots of CNC/laser cut stuff there and he got the t-rex on one sheet! And there is this: http://www.epiloglaser.com/sc_dino.htm
Aug 8, 2010. 11:35 AMsarujin says:
Now I just need a few other dinos and I got it going on. Freeside Atlanta (www.freesideatlanta.org) has a visiting CNC expert. He got our sputtering machine running and is teaching me how to build a better one. (future instructable.)
Aug 5, 2010. 8:38 AMsarujin says:
If you do have a CAD or vextor file, that would be great. I have a triceratops model coming today and when I build them both to people size, they will fight.
Aug 29, 2010. 2:55 PMsarujin says:
I tried to scan it but it did not come out right. The site I linked to has the same model (http://www.blechwelt.com/teil_des_monats/dxf/0405-Brontosaurus-3mm.DXF) Not really a brontosaurus...
Aug 23, 2010. 3:36 AMNostalgic Guy says:
I love these I just wish I had space & a reason to make one. I remember building the origial small ones of these with my boys almost 15 years ago. I always wanted to scale them up but never really had the space although I was tempted to do some for my huge garden they would have looked great peering out of the shrubs. I had a friend who made some out of plexiglass with LED illuminated bases they were great my boys had one in their room for several years, I may have a go my self that would make a great ibble. Nice one kaptaink_cg now how about a giant spider or preying mantis?
Aug 9, 2010. 12:38 PMavarice574 says:
This by far the coolest project i've seen you do yet! Hope you win!
Aug 8, 2010. 12:30 AMWasagi says:
Roar!! This project is amazing!
1-40 of 82next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
88
Author:kaptaink_cg
We spend our youth trying desperately to fit in, and then the rest of our adult life doing whatever we can to stand out in the crowd.
