3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build a Battery-Powered Amp for an old Carbon Mic
A friend of mine acquired a 1970's aviation-style headset for use as a live gaming prop.  This Instructable documents the development and construction of a stand-alone amplifier and general-purpose adapter for it.  I was much aided in my task by other Instructables, as well as helpful hints in various audio forums.
Step 1Breadboarding
Breadboarding
The first problem to solve is that carbon-button microphones, like condenser mics, need an external source of power.  A battery and a resistor in series with the mic gets you a current loop (the resistor limits the current) and then you can pick off the audio at any two points with a voltage drop between them.  A single AA battery and a 1K resistor is enough to get a signal you can pick up with a mixer or an audio interface.
To get the rest of it, I bought up several fresh Jim-Packs of capacitors and resistors in useful-sounding values, opened up the National Semiconductor datasheet on the LM386, and started playing.  When I got in trouble (which was most of the time) back-posts in random audio forums gave me new ideas to try. One of these led me to a zobel filter, and  Wikipedia (of all things!) told me how to make a passive low-pass filter.
Okay, I still think you can do better with the same resources.  There are lots of good circuit diagrams floating about the net.  But here's my schematic anyhow (see below).
8 comments
Jun 25, 2010. 1:33 PMQuercus austrina says:
JimPak??!!! Where did you get them? I haven't seen them for years since the local independent  Radio Shack went out of business.
Nice build. I especially like the way you adapted the drain cover and handle for use. The Sidetone control is a great function, something most people would not think of.
Qa
Jun 27, 2010. 7:53 AMQuercus austrina says:
Ah, to have a local electronics store. (Sigh) Actually, the independent RS went out of business before the internet was around and mail order was a looonnnggg process.
Thanks for the info,
Qa
Jun 25, 2010. 12:27 PMxxInSAniACxx says:
HEY!!!!! I've been looking every where for instructions on how to build an AMP. does this only work with carbon, or with modern equipment too?
Jun 25, 2010. 11:50 AMrandofo says:
Very cool! I have a headset exactly like this that I have been too lazy to figure out how to wire up. This will be very helpful. I like your casing too. It has a very nice aesthetic.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:nomuse(The Starving Theater Artist)
