Take a look at http://www.cathodecorner.com/bikeboombox/ showing the system in detail.
The amplifier circuit board is of my own design. It uses a Texas Instruments Class D stereo amplifier chip to provide 15 watts per channel of clean sound with very low battery drain. I designed a circuit board with everything needed for a nice bike system, including a charging port for your MP3 player.
The amplifier board details are http://www.cathodecorner.com/bikeboombox/cdamp/
Remove these ads by
Signing UpStep 1The components
The amplifier circuit board is available from my one-man company Cathode Corner for $100 assembled. you may also download all the design info from my website and build your own if you are good at surface-mount assembly.
The 6" sewer pipe is available from any big plumbing supply house (not Home Depot or Lowe's, unfortunately) but needs to be cut carefully, a task that I describe how to do.
The bike rear rack is available at any decent bike shop. You may already have one on your bike.
Parts required:
A fully assembled CDAMP amplifier board with angle brackets
A battery pack, Li-ion 18650x4 series cells with protection circuit (Batteryspace)
A 14.4V Li-ion charger (Batteryspace)
A 5.5mm/2.1mm DC power plug to fit the amplifier board (Digikey or Mouser)
A pair of Kenwood KFC-1652MRB marine speakers (eBay)
Two each .250 and .187 quick-disconnect crimp terminals to fit the speakers
Three feet of two-conductor speaker wire, 18 to 22 gauge
A rear bicycle rack, standard aluminum type (local bike shop)
Two feet of 3/4" Sch. 40 PVC electrical conduit
18" length of 6" Sch. 40 ABS sewer pipe (big plumbing supply house)
One foot of 3/4" to 1"x1/8" 6061-T6 aluminum bar stock (hardware store)
A dozen #8x3/4" sheet metal screws
Two 8-32x1/2" machine screws, flathead preferred
Two 6-32x3/8" machine screws, nuts and lockwashers or nylock nuts
Tools required:
Electric drill and/or drill press
Fractional drill bit set, up to 3/8"
Countersink, #8 screw head
Hacksaw
#1 and #2 Phillips screwdrivers
Sharpie marking pen
Small file, square or flat
(optional) Large miter box or the parts to make one and a crosscut saw
it would be cool if you posted a youtube video so we could hear it in action. i like the punchier sound of sealed designs like this than the boomy sound of ported designs. i bet your rig sounds crystal clear.
if anyone is looking for a forum dedicated to bicycle stereos, stop by the bikeology website's forum. the owner of the site has built some pretty ambitious & LOUD trailer systems, but we'd like ANYONE with any kind of bike system or even just interested in them to visit.
as many different systems as people have built, it would be nice to have a community that shares info & ideas as well as a common place for everyone to show their rides off & just hang out.
I designed and dropped in my own Power supply, with 5v for USB, and regulated power for the amp and EQ.
I figure, that with a little bit of work, I can have something nicer than anything I could get at the store.
I'll send a link to some pics when I get it completed
http://www.oobject.com/category/boombox-bikes
now I is getting ideas.
Virtualvillage also do a stereo chip-amp made up board for around £4, plus £4 P&P, and a slightly more expensive version of the above with a USB charging socket.
I'll order one to see if the build quality is any good. The generic $20 class D amp board I got from eBay was a dud - it was hand soldered but they didn't solder the chip's heat pad to the board, and the chip itself was made by a defunct company. Nothing I would recommend.
You do get what you pay for.
Where on earth did they get used Power AMP chips from? Crazy!
I used one of those T-Amps in a previous 12v project (26ft sailboat I was singlehanding), which was extremely impressive - but they don't seem to be available anymore, and my one is now permanently epoxied to a bulkhead...
http://www.tnt-audio.com/ampli/t-amp_e.html
So is there really no well-working chip-amp in a box that can be bought ready made for a sensible price?
-this should work.
...also, check out my solar boombox for ideas-
http://www.instructables.com/id/DIY-Solar-Boombox/
Nice work!
