When the delicate timing mechanisms of the shutter begin to deteriorate, the shutter times can change, and this results in incorrect image exposures. Sometimes the inaccuracy iis substantial and clearly noticeable, but at higher shutter speeds, it is difficult to tell the difference between 1/500th of a second and 1/1000th of a second. However, to the film that difference is substantial.
When doing camera shutter repair, having a way to measure the timings can help give you insight into what might be wrong, and also lets you test as you tinker with things to see if you're making things better or worse, and how close you are getting to your desired shutter accuracy. It's an invaluable tool for any aspiring camera repair tinkerer to have.
This project is based on the PIC18F2525 microcontroller, and an HD44780 16x2 character LCD. It uses an OPT101 photodiode with integrated trans-impedance amplifier for the sensor, and a 1 watt red LED for the light source.
Remove these ads by
Signing UpStep 1Tools and Materials
Materials:
- 6.5" x 4.5" x 2" Aluminum project enclosure
- Chemistry bolt-down retort stand base
- 8" stainless steel retort stand rod
- Retort stand clamp x 3
-1/4" thick aluminum plate
- 1" length of 1/4" aluminum or steel rod
- 1.5" length of 1/8" steel rod x 3
- 1/2" hole rubber grommet x 2
- Various screws, nuts, washers
- Epoxy
Circuit Components:
- 16x2 character HD44780-based LCD
- PIC18F2525 microcontroller
- 28 pin IC socket
- 10k trimpot
- 7805 voltage regulator
- 100nF capacitor x 3
- 10k resistor
- 4.7 ohm 2 watt resistor
- 8MHz crystal
- 15pF ceramic capacitor x 2
- Male header pins
- Female header pins
- Various lengths of wire
- OPT101 photodiode IC
- 8 pin IC socket
- 1W red LED
- SPST toggle switch
- Panel-mount pushbutton
- Panel-mount DC jack
- Heatshrink
Tools:
- Drill
- Various drill bits
- Mill (if possible)
- Soldering iron
- Solder
- Wire stripper
- Wire cutter
- File
- Center punch
- Hammer
- Tap and die set
http://en.wikipedia.org/wiki/Focal-plane_shutter
This is a common problem with old shutters, it is a result of dried lubricant in the mechanism preventing faster motion. The first shutter is slow due to a malfunction, so the second shutter overtakes it mid-exposure, resulting in a partially-exposed image.
I have read that and tried it myself once, didn't seem to work, all I saw was a blur of screen, not as it was demonstrated on the internet.
This method also works for any shutter type, such as leaf shutters.
