Build a Miter Saw Table - I Made it at TechShop by jeffaudio
Featured
This instructable will show you how to build a miter saw table so it's easier to cut long pieces of wood. It is customizable to your miter saw, but for this instructable I'll be using a Dewalt DW715. It has four compartments and can be placed on two sawhorses wherever you need it. I made this at TechShop, so all of the tools required can be found there. The table in this instructable is based on instructions found at Family Handyman.
Tools Required
Panel Saw (If you don't have access to one, the place you buy your wood should be able to do these cuts).
Table Saw (If you don't have one you can use a hand saw).
Miter Saw
Drill with Bits
Safety Glasses
Ear Plugs
Pencil
Square (Speedsquare or Combination square).
Tape Measure
Clamps (optional)
Materials Needed
4 x 8 plywood (I used 1/4" but 3/8" would work great too)
1 x 6 x 10 wood board
2 or 3 2 x 4 x 8 wood studs
4 hanger bolts and nuts (use the size that fits your miter saw. Mine uses 1/2")
Nails or Screws for fastening
Step 1: Measure the Miter Saw
The first step is to measure the width, depth, and height of the miter saw.
The width is just the width of the entire saw. You might want to include a little extra so it's easier to take the saw in and out. For mine, I used 24.5 inches.
The depth is the minimum depth of the table. It should be at least deep enough to for the base of the saw to be firmly on the table. I wanted a some extra space, so I used 18 inches.
The height is the most important measurement. Here you will measure from the base on a flat level surface to the miter saw surface (where you put your material when cutting it). To get the divider height, you can either subtract 2x the plywood thickness or just measure the height directly using some scrap material.
vincent7520 says: Feb 12, 2013. 10:43 AM
nice !
the same design could make a nice desktop !…
JamesRPatrick says: Dec 21, 2012. 10:04 PM
Next step: integrated sawdust trap.
infiernet says: Dec 18, 2012. 7:23 PM
Great... cheap and usefull.. thanks.. i am making my workshop.. :)
anilbedse says: Dec 14, 2012. 12:11 AM
Great, and usefull
Edgar says: Dec 13, 2012. 9:13 AM
Great, and usefull, gone to my Blog.
http://faz-voce-mesmo.blogspot.pt/2012/12/60-materiais-para-3d-mais-radio-raspi.html
fretted says: Dec 12, 2012. 12:19 AM
You did a great job and a nice ible as well but you will find as i did when i built mine standing the 2x4's on end instead of flat and gluing between joints and using screws instead of nails will save you tons of headaches down the road ..
It may not seem like it but if your going to use this on sawhorses most of the time your going to get a lot of flex after awhile without some strong wood glue between joints the table i am currently using i've used for 4 years without a twist the first two i built slowly decayed over a time from usage and cutting large boards in the end i built a full table on wheels and ditched the sawhorses
Regards
jeffaudio (author) says: Dec 12, 2012. 5:46 AM
Thanks for the tips. When I next build a workbench, I'll be sure to use your advice. I'm still really new at woodworking so I'm learning as I go.
BrianJewett says: Dec 13, 2012. 7:02 AM
You could still stiffen the thin area where the saw sits by screwing a second 2x4 to the flat 2x4's underneath.
fretted says: Dec 12, 2012. 6:12 PM
Your welcome you did a great job !
RTHeath says: Dec 13, 2012. 6:58 AM
I am soon to build new workbenches for my barn/shop -- this is a terrific idea that I will incorporate, as my miter saw currently sits on top of a bench and I'm forever struggling to get long pieces level to make straight cuts. Thanks so much for this great idea!
Lorddrake says: Dec 7, 2012. 4:38 AM
Nicely done.
jeffaudio (author) says: Dec 11, 2012. 2:11 PM
Thanks!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
