3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Build an Arduino-powered talking robot head!
This robot head was originally built as a end of the year project for my physical computing class, but over the summer it has "learned" how to talk.
The head is powered by two Freeduinos, 3 TLC5940NT chips and an Adafruit Industries Wave Shield found here: www.ladyada.net/make/waveshield/. The head is currently connected to a computer by two USB cables, one for power, one for sending it serial commands on what to say/emote. Once the head receives the typed commands on what to say/emote it plays back the individual word files in order creating a sentence or multiple sentences. It also changes its emotions according to the emotional commands sent from the computer.
This robot head is a foundation for many possible applications since it can say anything that it has the vocabulary for. Right now I am currently working on connecting it to the internet and making it check and read my email via PHP script. I will update this Instructable as I progress along with that.
Here's a video of it in action:
The head is still an on-going project so any comments on anything here are more than welcome!
Special thanks to Liz Arum for helping me with everything!
Update: Due to popular request I now have now added a video of the robot talking and expressing itself! Enjoy at your leisure!
Step 1Compile all materials/parts/electronics.
This robot head uses:
1 Breadboard (It has to be more than 48 rows long with a gap running down the center of the board to connect IC chips. A power and ground bus running along the side of the breadboard is also a necessity.)
2 RGB Leds (For the multicolored eyes) Common Anode. $1.50 - 1.95 each. 2 X $1.75 = $3.50
36 Red Leds (For the mouth) somewhere around the 40-50 cent price range for each. 36 X $.45 = $16.20
2 HXT900 Micro Servos (For moving the eyebrows) Can be found at:  http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=662 2 X $3.65 = $7.30
3 TLC5940NT's (To drive/light up all the Leds and control the servos) can be found at Digi-key http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=296-17732-5-ND where they are priced at $4.28. 3 X $4.28 = $12.84
or Mouser http://www.mouser.com/ProductDetail/Texas-Instruments/TLC5940NT/?qs=sGAEpiMZZMu8%252bGBKj8XSFEjwsgnt5grMZ49G/W4nR14%3d
3 Capacitors (~1000uf) (for ironing out line noise from the Leds and servos) Salvaged from an old computer power supply. Free
2 Original Freeduinos or Arduinos.  The Freeduinos can be bought at http://www.freeduino.org/buy.html They are priced at 23.99 each. 2 X $23.99 = $47.98
Or www.sparkfun.com/commerce/product_info.php for Arduinos. Priced at $29.95 each. 2 X $29.95 = $59.90.
Warning: The Freeduinos require some soldering knowledge, if you would like not to solder your boards then buy an Arduino.
Warning: This Instructable requires some soldering knowledge anyway, so why not start now? :)
1 Waveshield from Adafruit Industries (To allow the robot to talk) Can be bought at: http://www.ladyada.net/make/waveshield/ Priced at $22 each.
Estimated total cost of all high tech parts(not including shipping) if you bought Freeduinos instead of Arduinos is.... $109.82!
The total cost of all high tech parts if you bought Arduinos instead of Freeduinos is.... $121.74!
And as for the low-tech materials you will need:
A cardboard box the same size that you want your head to be.
A small piece of cardboard
Tape
Glue
Breadboard compatible wire (22 gauge, solid)
Wire for fastening stuff to other stuff
A small block of wood
Power drill.
Heat Shrink tubing for isolating the exposed wire leads and something that blows hot air to shrink it with (Hot air gun)
Box cutter.
27 comments
Nov 6, 2011. 8:42 PMPeasy93 says:
hey nice work
what is the voltage of the capacitors??
Sep 18, 2011. 2:00 PMmagicthegathering says:
Great. I wonder how possible it would be to connect this to the internet and to cleverbots website. Add a microphone and be able to talk to cleverbot back and fourth? Anyone have any ideas?
Apr 26, 2011. 4:38 PMrocket_man says:
so how would i connect the arduino to my computer to communicate and take commands from a keyboard
Mar 27, 2011. 5:21 AMredzwan2008 says:
I want to add pir sensor to the arduino. how to connect it? and how to program the robot to talk when a human walk in front of the talking robot?
Jul 7, 2010. 11:54 AMgudenaurock says:
The penguin is Tux.
May 16, 2010. 5:56 PM1740 says:
WOW
Nov 25, 2009. 2:06 PMchosenone3 says:
I just watched the video and i can say that this is one of the coolest arduino projects I've seen so far :]
And I was wondering how did you get it to speak so clear ,I mean it sounds like a real human voice.
Would it be possible to get same results with pc (Besides MS sam voice which realy sucks)?
Mar 28, 2010. 8:22 AMEnki-][ says:
It's probably useful to use festival (that's what I'd use, anyway). The default voices in festival aren't terribly realistic, but you don't get the pauses (and the licensing problems -- the at&t thing has a big long license if you read it, and this project probably violates a bunch of the terms), and it doesn't limit the user base to windows users like using the microsoft voices does.
Jan 15, 2010. 4:45 PMwillrandship says:
That means three things to me.
1. You could record your own voice for it (even make it sing!)
2. Automatic talking text, similar to microsoft sam, through the head.
3. You could hook this up as a speaker and it would sing whatever sound goes through it. Might take some hardware modification though.
Jan 27, 2010. 6:48 PMdpdesigns says:
very cool robot head.  I've been looking for something to do with my arduino and this gives me some inspiration.
Dec 2, 2009. 4:01 AMnatfish says:
 congrats! I'm glad you finished your robot. Whatever happened to your walking/dancing soda can?
Nov 17, 2009. 11:13 PMdavewking says:
Dude, let's get your robot reading emails.  I just posted an instructable that could help out http://www.instructables.com/id/Read-Email-with-Arduino-and-Wave-Shield/ .  Feel free to send me emails with questions.
Nov 20, 2009. 7:12 AMmfleisig says:
Nice work!  I love the eyebrows.
Nov 14, 2009. 1:04 AMjefskil says:
i can't wait for that video either!
how much did all this cost you?
Nov 11, 2009. 1:29 PMKiteman says:
It talks?
The mouth "moves"?
We need to see video!
Nov 11, 2009. 6:13 PMcowscankill says:
Yay!
Nov 11, 2009. 2:13 PM_Scratch_ says:
what exactly does it do?? i've never heard of this arduino stuff before so i'm wondering what these do.
Nov 13, 2009. 3:50 PM_Scratch_ says:
In fact, i was wondering both but you cleared it up for me. Thanks!
Nov 12, 2009. 7:15 AMbeardy says:
Lots of fun stuff going on there.  Well done!
Do post a video if you can.  I think we'd all like to see and hear it in action.
[m]
Nov 12, 2009. 6:46 AMtigoe says:
Very nice robot head, good work!  You may want to include a  first step listing the parts, with links explaining them and where you got them, so that people who don't know them can find out more.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:xtremd
