Remove these ads by
Signing UpStep 1What you will need
* Please note that the following materials list does not include the shelving in the unit, I have not decided how many shelves I'll need so that part will be updated soon (-:
Materials used in my compactus:
eight bar track rollers
two 3 metre lengths of 13 mm by 5 mm flat steel bar
eight 11 mm bolts each with 2 washers, a spring washer and a nut
eight 8 mm bolts each with 2 washers, a spring washer and a nut
two 16mm thick sheets of MDF - 900 mm wide by 2400 mm high
one 16mm thick sheet of MDF - 1168 mm wide by 2400 mm high
two 16mm thick sheets of MDF - 900 mm wide by 1200 mm high
four 32mm by 18mm pine DAR shorts - 1200 mm long
two lengths of 40mm steel box section - 1200 mm long
two lengths of 40mm steel box section - 1120 mm long
ten 6mm philips head concrete anchors
PVA wood glue
thirty 60mm long MDF self tapping screws
thirty 25 mm long MDF self tapping screws
5 welding rods
Tools required to build the compactus:
battery drill
electric hammer drill
a hammer
metal drill bit set
6mm masonry drill bit
adjustable wrench
safety glasses
welder
electric grinder
jig saw or small power saw
I'm not suggesting you did not think of this, just pointing it out for others that may construct this.
I would probably beaf up the bottom track if possible but apart from that it looks Great!
That's a great point, I went to some trouble to ensure the slab was level but should mention that it's a major requirement. I'm building the second cabinet soon so I will have a few more detailed photos to add. Thanks heaps for the feedback, it is very much appreciated.
Cheers,
Scozza.
