3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
"Building a One sheet boat" Alternate Building
\"Building a One sheet boat\" Alternate Building
Hello,
I build myself a "One sheet boat" like Vegra did http://www.instructables.com/member/Verga/
but with some minor changes as seen on the last pages
(btw: please ignore my grammar etc etc)
Step 1First one of my changes
My first change was that I cut down the Support frame from Vegras Original 32 inches to nearly 28 because i was to afraid that the plywood will break
51 comments
1-40 of 51next »
Feb 29, 2012. 11:51 AMGoldenlace710 says:
I have been inspired by this and if all goes well I along with the local barony (S.C.A.) will be building a 2 section,30ft viking long ship based on this concept. Thanks for the inspiration, I'll post pics if we do it. ;b
Oct 12, 2011. 8:41 AMjp armor says:
i would also like to see a video please
Oct 24, 2011. 6:07 PMDIY-Guy says:
JP Armor:
Do you know how to download a video in a .pdf file? I think these instructions are great to have filed away on the computer, PDF files are easy to keep, search, and even print. Video is a bit less friendly to file and find.
Jan 6, 2012. 6:10 PMmacrumpton says:
Probably better to put the video on youtube and just link to it.
Jan 5, 2012. 5:57 PMGoDu2 says:
Good Idea! How about putting two side by side for a simple catamaran!
Sep 29, 2011. 8:10 AMctz says:
My dad and I have being wanting to build a boat for a long tom and now I think I've found one that will work. GREAT INSTRUCTABLE :)
Sep 14, 2011. 2:59 PMfweall says:
I have followed your example and built a similar boat, extending the length by just over a foot and adding bulkheads forward and aft for storage/floatation, should be finished in a week or two, cant wait to get out on the water, cheers for the inspiration!
Sep 16, 2011. 8:49 AMfweall says:
Just writing one up the now, going to epoxy the hull this weekend! :-)
Sep 1, 2011. 4:01 AMdorybob says:
very well done.
Jun 27, 2011. 10:40 AMMiloMaloCro says:
please could you do a video of how it reacts in the water because I would like to see that...I'm considering to build one on my own but I'm not yet definitive about the design....
Jun 27, 2011. 1:09 PMMiloMaloCro says:
I'm looking forward
Mar 27, 2011. 12:37 PMdoggsboddy says:
my father taught us how to built canoes out of a single sheet of marine ply by slitting one end of the sheet down the middle far enough down to make the bow (or both ends if you want a double bow) then lay the sheet in the sun and put wet hessian bags over the bow section. It will curl up from the humidity. Then a piece of timber cut to shape was nailed in to the bow and same for the stern. Strips of timber nailed along the free board for rigidity and they where very strong and light. Carried them literally for miles to the nearest dam when we couldn't get a ride.
May 12, 2011. 7:33 AMclaudg1950 says:
doggsboddy: This is really interesting. We would like to hear more.
I guess that you didn't just slit the end of the ply, but you cut two tips (like the M letter in the McDonald's sign) so when they curve the two tips come together.
But it is my guess.
Lazarus441= great instructable and great work. Thanks a lot.
Apr 14, 2011. 12:45 PMreblacke says:
Sounds interesting. Any way you could do an instructable on that. I would be interested in learning how you built your canoes.
Mar 27, 2011. 5:13 PMTruth Seeker says:
Please show us what you mean!!!
Mar 27, 2011. 3:24 PMchcagr says:
That sounds VERY interesting. Could you make an instructable of that? I would love to see it in action.
Apr 20, 2011. 12:22 PMrlosiniecki says:
I really like your instructible, great job!
I was thinking about tweaking the design a bit to make it a square back so I can use my 2hp motor.
Anyone have any thoughts on that?
Apr 10, 2011. 3:30 PMfweall says:
Nice boat, Im swithering whether to build something like this for fishing or a sit-on kayak. I much prefer working with wood, sure my flatmates would rather I used wood rather than foam insulation and fibreglass, just not sure which would weigh less as may have a bit of a carry to fish some lochs. Have you a pic of it with a person in it or did you do some displacement calcs? Cheers!
Apr 10, 2011. 7:31 AM2DirtyKids says:
Really nice, how much does it weigh? A picture in the water would be great.
Mar 23, 2011. 10:01 AMilpug says:
i have been thinking of replacing my little canoe that i use for fishing, since it got holes shot in it by some mean person, and is kept afloat with duct tape. this looks like a great alternative! excellent project. enter it in the Epilog Challenge, i will give full marks.
Mar 27, 2011. 7:06 AMswizzle says:
Heat your boat up carefully with a blow torch and then put on the duct tape. It'll hold a lot better. Just don't burn a hole in your boat.
Mar 27, 2011. 3:57 PMilpug says:
The boat is aluminum, so that might not work. i will probably rivet some little patches over the holes, and patch the rest with fiberglass.
Mar 27, 2011. 5:18 PMswizzle says:
They have a muffler repair kit that has some JB weld type stuff and some screening. Put that over the holes inside and out and it should hold tight.
Mar 28, 2011. 10:01 AMilpug says:
yeah, i have some of that stuff. its called Bondo. might use it also
Apr 6, 2011. 12:33 PMrdaggett says:
If the holes are small it could be welded, use a steel sheet behind it the al filler will not stick to steel
Apr 6, 2011. 10:38 PMilpug says:
thanks for the idea, but i already patched it. i used some thin steel and small rivets to seal the holes, and then i used Bondo Auto-body filler to patch up around the edges, and smooth the outside. there were about a dozen holes, all large caliber, with jagged edges pointing out from the hull, so i had to hammer them flat and sand the rest. works fine so far, with no detectable leaks.
Mar 30, 2011. 2:49 PMjackhg says:
great job, really professional looking,,
do you think a sail could be some how rigged to the boat? could floatation foam be added to the bow and stern?
Mar 27, 2011. 11:28 PMvincent7520 says:
Very nice work.
Seamanlike.
and excellent carpentry …
Much much better than the one you took your inspiration from ! ;)
Only minor question : why didn't you use stainless screw for you transom post ?…
Best wishes
Mar 27, 2011. 8:25 AMbillbillt says:
Boat is great. My only complaint is you used machine tools to produce parts for this that most people can not afford. You should have done the complete project with minimal expensive tooling.
Mar 27, 2011. 11:22 AMwhiteynut says:
The milling steps could be done with a table saw, or set up a jig and make the cuts with a regular circular saw.
Mar 27, 2011. 8:49 AMmartynbiker says:
So I am asking you this, if YOU had the tools to do the job, would you use em? or would you "do it by hand because some poorer folks don't have access to a mill"....
Mar 27, 2011. 10:51 AMTumunga says:
If I did it, I would use all the expensive tools, and have some migrant workers do the build for me. When it was finished, I would dress up in some farmer overalls, tell everyone I built it with a nail file, and a handful of dirt, and take pictures of the aforementioned nail file and dirt to post on here.
btw, nice boat.
May 1, 2011. 11:43 AMmatits says:
Nice. Migrant workers need work too. I wish I could afford the migrant work, let alone the tools. I may have to hop the border to Canada for work seasonally to afford the Southern migrant worker so I can afford to make the boat.
Any suggestions for the propellor attachment
Mar 27, 2011. 10:37 AMbo88y says:
Nice work.
Mar 27, 2011. 9:52 AMcomputurwizard says:
Check out "Hannu's Boatyard", http://koti.kapsi.fi/hvartial/
Lots of very easy to build boats, 1 sheet, 1 and a half sheet (the Portuguese Style Dinghy" is awesome, I built two), and 2+ sheet boats.
Mar 27, 2011. 8:45 AMmartynbiker says:
What a nice job! Wish I had built something like that with my Dad.
1-40 of 51next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:lazarus441
