Sitting around the camp fire at a lake has left us too hot on one side and freezing on the other.
Drunken idea - A hot tub would keep us warm all over.
It would also get the girls in thier bikinis!
How will a 10x10x2ft body of water be heated and kept hot?
Don't forget to comment, rate and share! :D
Caution!
This intsructable is how to build a Camping Hot Tub and is for entertainment purposes only.
Safetey first!!! It involves power tools, fire, electricity and water. Recreation can be very dangerous.
I am in no way liable for anything you do, damage to vehicles or equipment,
loss of life, accidents that may occur, fines incurred, acts of god, etc.
Leave it the way or better than you found it! Clean-up and don't start a forest fire!
DO NOT CUT DOWN TREES!
Goals:
Transportable hot-tub equipment.
Tools:
Chainsaw
Shovel
car/truck or Generator
Materials:
Tarp 20x20
copper coil 5/8" OD. (outside diameter) @ 100 ft.
hose 5/8" ID. (inside diameter)
hose clamps, Get more than you need!
Washers
Power Inverter
pump 1/12 hp utility continuous operation
Large pond pump
large hose
Rocks (should be on the beach or in the river)
strong metal baskets (look around at thrift stores)
Remove these ads by
Signing UpStep 1Location
The tub needs to be close so it can be filled and refilled as needed.
Anouther method:
A friend of mine used his truck as the pump and heat source for a portable carnival "dunk tank". The tank was an old wood hot tub.
He diverted the radiator hoses to a scrap radiator that was submerged in the tub. Quick and easy. One person setup. 2- 2.5 hrs start to tubbing.
This is aimed at the commenters who post the "I would have done.........." or "You should have..........." comments, NOT at the ones who post the "I made one of these but I........" comments. You know who you are and you know what the difference is. Player2756 had an idea, worked on it and did it. If you think you have a better way, post a frakkin instructable. Just give Player2756 some credit even if you disagree with his methods.
There were several comments made about the extra work that may have been needed to make this tub the way it was made. So what?? I can't think of a better way to spend time at a lake than to work your butt off doing something and then relaxing with a cold beer and some cuties in a hot tub. Kudos, Player.
you control the temp by the amount of wood fire
Great...
then you are not going to open up the system on the car/van each time to use it, your just going to tap onto the heat exchanger.
im a gas engineer and it is whats used in combi boilers to heat up the hot water in your home.
http://www.industrial-boilers.org/wp-content/uploads/2010/07/boiler-heat-exchanger.jpg
I will probably do a revised ible this upcoming summer some time, maybe end of winter, that will include something like this.
i cant find a diagram at the moment to show you, and i am no good at drawing on a pc to show you either.
the closest thing for you to look at for the idea is a hot water cylinder.
if you where going to try this, i would reccomend getting an industrial heat exchanger as it will have a bigger flow rate and you dont want to over heat your car because it cant dump enough heat quick enough.
sorry if this is confusing for you but i do find it hard to explain things in general and worse at 3am.
good luck and as long as there is enough heat in the cars radiator fluid, then this would work, or at least get it to a nice warm temp.
This is a system ancient Irish (and presumably many others) used to cook meat. They are referred to in Ireland a Fulacht Fia
(see; https://sites.google.com/site/craggaunowenproject/Home/fulachta-fia).
They are marked on every detailed OS map. Just about every parish used to have one (at least).
More recent research now shows that they might even have been used for beer-brewing and also for bathing. - Hopefully not at the same time!
On and ditto on the honey on the left thing too.
http://www.amazon.com/Palm-Springs-Inflatable-Bubble-cover/dp/B003P6J9US
Somewhat negates the whole instructable aspect just a bit.
