Introduction: CandyCane Plasticine Pig
Do you guys like to make models? Well here is a really cool model that you can make! All you need is some plasticine and lots of enthusiasm.
Step 1: Materials
You need:
A chunk of red plasticine
A chunk of white plasticine
A chunk of pink plasticine
A little peice of black plasticine
Some glue
The amount of each material depends
on big you want your pig to be.
Step 2: The Body
The big needs a body now.
To make the body you must take some red plasticine
and some white plasticine. Semi-mix them together
so they have a swirly sort of candycane look. Roll the
mixture into a thick oval.
The body should look like this picture.
Step 3: The Head
The body needs a head now.
To make the head,roll some pink plasticine
into a ball.
Here is what the head will look like.
Step 4: Attaching the Head and the Body
This step is a very important step.
You will use this step whenever the
instructions say "attach the _______and the_______."
Choose one side of the body to be the
front of the pig. The add some glue
onto the front of the pig. Place the head
The body and head should look like this.
For other steps choose places to put the objects on and follow the rest of the steps.
Step 5: Feet
The pig now needs some feet.
To make feet you need some red
plasticine. Roll the plasticine into
4 little spheres. Shape them into
small cylinders.
Attach the small cylinders to
the bottom of the of the pig's body.
Step 6: Eyes
The pig needs some eyes to see now.
Get a little piece of white plasticine
and split it into two parts. Caution the piece of plasticine should be very small.
Roll each part into a small oval. Get a tiny bit of black plasticine
and put them onto the long part of the white ovals. There you ahve your eyes.
Attach the eyes to the top part of the face of the pig.
Step 7: Ears
The pig needs ears now.
To make the ears, get a little bit of
white plasticine and divide them into 2 parts.
Next form each piece into a triangle.
To make your pig look cute, you can fold the tip of their
ears.
This is what it looks like.
Attach the ears to the top of the pig's head.
Step 8: Snout
The pig needs a snout now.
To make the snout, get a piece of pink plasticine
and roll it into a ball. Shape it into a cylinder just like the feet
of the pig. Get a pencil or pen or whatever you need to make the
breathing holes in the pig's snout. Poke 2 holes into the middle of it's
snout. Make sure they are not that close together.
It should look a littlle like this.
Attach the snout under the pig's eyes on it's face.
Step 9: The Tail
The last step to making the
candycane pig is it's adorable
white tail. To make the tail
Get a tiny piece of white plasticine
and roll it into a short thin stick.
Then twist the stick ever so slightly
and then you've got your tail.
Congratulations on making this pig.
Attach the tail onto the behind of the pig's body.
Sorry if the picture is a bit blurry.
UP! Contest
Furniture Contest
