Cardboard Armor
Cardboard Armor
I made this for protection during cardboard tube tournaments ( http://www.tubeduel.com/ ). It protected me well; I took second place and I believe I would have won had the final match been allowed to progress to its natural end. Damn refs, grumble grumble.
I used the following as a general reference, and for the names of the parts (several of which I did not previously know):
http://www.reliks.com/suitofarmor.ihtml
http://www.swordsandarmor.com/mall/suit-of-armor-Dragon-Slayer.htm
http://en.wikipedia.org/wiki/Plate_armour
http://en.wikipedia.org/wiki/Cuirass
Step 1Breastplate and Backplate
Having quite a bit of experience making clothing, I figured fitting cardboard around the body would not be too difficult. As it turns out, there are some differences between the stiff cardboard and the much more malleable fabric. I worked out a technique of scoring the back of the cardboard with the cap of a pen along lines I wanted it to bend on. This, along with a way of making darts, allowed me to shape the cardboard fairly accurately.
For the front and back plates (together these are called a cuirass), I first drew a flat shaped based on my body measurements. For the front I used these:
  • front of the waist (a little more than half my waist measurement)
  • length from waist to shoulder across bust
  • length from waist to bottom of neck hole
  • front of the bust (quite a bit more than half my bust measurement)
  • width from arm to arm, above the bust
  • length from waistline to underarm hole
For the back I used these:
  • back of the waist
  • width from underarm to underarm
  • width from arm to arm across the shoulder blades
I drew the front with darts at the bust so the armor plate would fold out there. (I didn't bother to put any darts in the back plate and this was fine.) A less busty person would need less of a dart, but most people will need at least a small one. We're all just curvier in front. I did place the waistline for each piece on the edge of an existing fold, where the original box had an edge. I also left about an inch of extra cardboard there out of habit, but it turned out this was a good thing (see Step 6 about the pauldrons).
Cut out the pieces with a knife of some kind - a utility knife or box cutter works well. Cut only the lower side of the dart marking all the way through. The upper side, cut through only the top layer of cardboard. Then peel the top layer and the corrugations off, revealing the inside of the corrugated sheet. It looks like a small flap. To construct the darts, bend the cardboard so the dart edges meet, and hot glue the flap down to the outside of the front plate.
It's easier to bend the cardboard if you score the inside first, just run the cap of a pen firmly along the line you want to bend on. A stiff ruler helps a lot for scores that run diagonally to the corrugations. In addition to the bust area, score and bend the shoulders and sides.
71 comments
1-40 of 71next »
Jun 3, 2011. 11:35 AMwillisawesome says:
I HAD A SOCIAL STUDIES PROJECT AND THE CARDBOARD ARMOR INSTRUCTIONS REALLY HELPED US OUT
May 10, 2011. 7:19 AMdinosaursoup says:
I'd like to do this for a history project. We have to dress up as historical figures and I have chosen Joan of Arc. I might duct tape or spray paint on the final project if possible.
Oct 2, 2010. 10:55 PMgchace says:
really just had to choose fruit of the loom huh.... didnt you? But other than that its %$#&$#@^Z#$%ing sweet!!! 8-0
Oct 30, 2010. 6:19 PMDarwinfish says:
In the middle ages, underpants could stop a broadsword. Fruit of the Loom mellowed out a little later... XD
Oct 27, 2010. 9:42 AMjack harkness says:
Thanks for the great instructions.
My 9yr is almost finished with his costume and I basically just supervised (and did the exacto knife work leaving him with the scissors stuff).
To give it a nice finish we decided against paint but rather are using aluminum foil with a dab of glue and he will call it the SilverNight.
As well, a shield will be attached to one of the arm vambraces.
Oct 27, 2010. 8:32 AMhellrider75 says:
easy and fun i will try this thx
Oct 18, 2010. 11:03 AMbustedit says:
hmm, a bit of criticsm has been posted, but i think this looks great, and i love the Fruit crest
Oct 12, 2010. 8:18 AMylpihs says:
Absolutely love this the armor looks really cool
Oct 11, 2010. 4:23 PMcyprian916 says:
thats a pretty could base for a structure but i would have put more work in and come out with a better finale product.
Sep 27, 2010. 7:22 AMEdgar says:
For that old, early Middle Ages, Black Steel look, try painting the cardboard matte black, then, after it dries up liberally use Graphite dust on it.
Oct 2, 2010. 10:56 PMgchace says:
GREAT suggestion thanks
Oct 3, 2010. 12:06 AMEdgar says:
Happy building! :)
Sep 26, 2010. 4:26 PMbcjfla76 says:
You can also hot-glue some velcro along the inside of the seam. This would allow the wearer to easily put them on or take them off.
another aesome suggestion
Mar 5, 2010. 9:37 AMMillenniumMan says:
I have to admit, the design is simple and at the same time kinda cool. Now, if you could do this with sheet metal, you could go and really kick some serious a$s!
What's missing though is gold paint and a dragon design on th breastplate. Still, really cool...
Jan 18, 2010. 10:27 AMdungeon runner says:
Oops, broken link. The real article is here:
en.wikipedia.org/wiki/Lorica_segmentata
Jan 18, 2010. 10:26 AMdungeon runner says:
Good armor, I must say. Did you think about using Lorica Segmentata? It's was used a lot in Roman armor. You can check out the wikipedia article:
en.wikipedia.org/wiki/Lorica_segmetata
Oct 31, 2009. 1:00 PMswords45 says:
i painted the vambraces with gold paint, it looked awesome
Aug 16, 2008. 6:33 AMCamisado says:
Cool! Now let's make some out of metal..... MWAHAHAHAHAHA!!!!!!!!! Errr, uh... 5 stars!
Oct 22, 2009. 2:29 AMolleres says:
same dude i wanna make armour with metal........i give this person a 10/5...
Nov 3, 2007. 5:08 PMtrebuchet03 says:
So today was our home game... A few days ago, a friend and I started construction of our armor. Photo Left (friend) Gauntlets Vambraces Chest and Back Plate Lower Leggings with knee caps Helmet with mane Shield Cape Sword Photo Right: Me Gauntlets (with knuckle covers) Vambraces Pauldrons with fringe Faulds with fringe Chest and Back Plate Lower and Upper Leggings with functional knee covers Shield (made from an Aluminum disk sled and fabric covered) Helmet with mane and fringe Two tone cape Sword Sword Sheath In both cases, thing are tied together through grommet holes :) A lot of people stopped us to take pictures - it was a lot of fun :) Walking up stairs, in my case (full leggings), was a little difficult - I'll have to articulate those pieces a bit better for the next game. For now, things will be hung on the wall :p
Sep 30, 2009. 6:02 PMred-king says:
that's some very nice armour you made!
Feb 25, 2009. 1:00 PMfoxtroot says:
Hey, can you please put some instructions on how to make that? It looks really good! THANKS!
Feb 25, 2009. 12:52 PMfoxtroot says:
Oh My God! HOW'D you BUILD THAT??????!!!!!
Nov 4, 2007. 11:36 PMtrebuchet03 says:
Coming... Sorta... The mad construction dash... and many failures created a lack of pictures :/ I'm going to go back and take some images - and grab some images from sketchup models :p
For the 3D pauldron bit :D I started with a 13"x13" square and scored the diagonal... I cut the score halfway to create a triangle and curled/trimmed the corners... Hrmm.. probably hard to picture from that description - so yes, instructable coming soon (along with everything else waiting - including meatloaf cupcakes :p).
I made the chest and back plate with mostly 2D planes - which solves the 3D issues of faulds. But, in my case, it makes the butt piece stick out funny (so I cut it a little shorter). Yes, there were a few "Assless Chaps" jokes - but the cape covered that up :p
More images here - but that's before I curled the pauldrons down properly...
Jun 8, 2009. 5:18 AMfluffybuddy says:
having trouble finding cardboard. do you know any places in melbourne... and is this armour flexible???
Feb 5, 2009. 9:17 AMflio191 says:
this made me LOL
Apr 11, 2009. 3:25 PMtevers94 says:
same
Apr 20, 2009. 7:23 PMlycoris3 says:
LOL LOL LOL LOL LOL!!!! wonderful ending! me and my sis were rolling!!! and yes, reather funny if i must say so myself.
Apr 11, 2009. 9:07 AMEnder1234 says:
ha ha man my friends are never going to stop making fun of me when I build this...I'm going to try to put some foam camp pad down on the front and back of the "cuirass" to see if it'll hold up better (we hit pretty hard with or foam swords). I'll let you know how it goes. I atcually don't larp, but my friends and I saw Role Models were very inspired :).
Jan 24, 2009. 7:43 AMchaitanyak says:
this is a really well documented diy ! maks me want to go make it right now :)
Jan 24, 2009. 7:41 AMyerjoking says:
Looks like half a pie :S Lol, nice ible :D:D:D
Jan 24, 2009. 2:33 AMThe Jamalam says:
i just realised, that these are kind of spaulders. pauldrons guard the armpit as well.
Jun 28, 2008. 10:07 AMpetethecactus says:
UR A GOD
Aug 30, 2008. 3:35 PMDrWeird117 says:
ess
Dec 24, 2008. 7:35 AMThe Jamalam says:
LOL
Dec 23, 2008. 6:33 AMThe Jamalam says:
Cover this in foil and it would look really great!
Nov 20, 2008. 5:37 PMcommandant Shane says:
ill get a photo up
Nov 20, 2008. 5:36 PMcommandant Shane says:
yo i was able to solve the 3d problem with cardboard by bending it at close intervals to create a bent piece
1-40 of 71next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
231
Author:rachel
I'm the Lead Java Developer here at Instructables, responsible for making sure the site's backend runs smoothly. Feel free to message me with any comments about the site. I'm also a founding member ...
more »
