Glowing colour-changing objects are always cool. So why not make your own? Mood lights have been around for some time and, while it is cool to have a colour changing light, it would be even cooler to have something more complex and geekier. An RGB LED Mood Cube seems to be the way to go.
Remove these ads by
Signing UpStep 1Materials
1x LED Cube Kit Provides the LEDs and all the structure required to create an LED cube |
1x Rainbowduino It is a special Arduino microcontroller built to control up-to 192 LEDs. |
1x UartSB (USB-to-serial adaptor). A USB to serial interface that is used to program the Rainbowduino (or for serial communication in general) trough a USB port. |
1x USB Cable A cable to hook-u the UartSB to the Computer |
1x 9V Wall Adapter A power supply that will power the cube once the assembly and programming are done. |
soldering together?
DIY is certainly an option, and there are many people online who have made custom LED cubes using custom microcontrollers. One approach is to simply bend the connectors on each LED and solder them accordingly. Having the pre-made PCBs makes it easier to solder together (and aesthetic since it makes a perfect cube). If you have some ideas, we are open to showing different types of projects.
