An electric motor is basically a generator and an electric generator is basically an electric motor. The chainsaw provides the power to spin the motor and booyah....electricity. I'm sure all kinds of electrically proficient peeps will shake their heads at the methods here, but it's all just fun, nothing serious.
Final adjustments to this machine, a voltage regulator is not needed if the saw throttle can be incrementally adjusted with a hose clamp. Hook up a multimeter and set the throttle before plugging in the light. Also the gearing in this instructable is way too high, the DC motor sprocket needs to be much larger to slow it down. I can hand turn this DC motor and get 2 to 3 volts, so the chainsaw should barely be running above idle to get the right voltage. This project is a little dramatic; maybe next time I'll use a lawnmower engine ;).
Here we go:
Materials:
1 old chainsaw
1 treadmill motor (DC permanent magnet motor)
1 one-piece 12 volt car headlight bulb
odds and ends tubing, wires, switches (see detailed steps)
bicycle spockets
bicycle chain
motorcycle voltage regulator
scrap wood and screws
Tools:
wrenches
screwdrivers
welder or someone who can weld a sprocket to a chainsaw clutch and treadmill motor flywheel.
jigsaw
(Extra: With a few alterations, this project can be made into a mini generator or a go kart.)
Warning, this can be dangerous. I'm not liable for any injuries or whatnot incurred using the shown techniques. At your own risk and stuff.
Remove these ads by
Signing UpStep 1Remove sprockets from bicycle and line up best fit
My 2c
"WOULD YOU TURN THAT OFF?!"
"NO!!!! I got to a good part in this book!"
We have to define ' a dead battery ' first.
A Battery That Will Take A Charge But Will Not Hold A Charge After A Period Of Time. This could be maybe used, but first when you start your chainsaw light the battery will not control or balance the voltage, but after the battery starts to create bubbles then it would be ok.' but you could start charging your battery first without the light, then later on switch the light on.
A Battery That Will NOT Accept A Charge( no or little bubbles) At All Can Not Be Used At All.
It is best to use a battery that is good.
Or the better option would be to get a load control used for windmills.
The best option would be to use a battery and a car alternator with internal voltage regulator this way you would not have to worry about volts and amps, but a alternator consumes about 40 watts to operate and to function and you need a battery for it to function properly , higher or lower RPM would not mater if you stay between 1200RPM ( start of full power) to 4000 RPM of the alternator.......
I like what you done here. Some folks my laugh at you, but I think it is very very very useful and a cheap generator. It could be coupled with a battery and a inverter ( 12V DC to 120V AC ) and it could be used as a emergency generator to have a 120V light and / or a 120 V TV powered..............
Remember 1 HP = 736 Watts in electrical terms.
Car alternators have between 60 amps to 100 amps, so the max with a 100 amp alternator would be 12V X 100A = 1200 watts minus the 40 Watts = 1160 watts output. But you would need a chainsaw with about 2 HP or better output.
What is the RPM of the DC motor?
I like very much. There are many uses for it.
The alternator makes 3 phase AC power inside the alternator, that's why it would not matter what direction the alternator is turning . Then before leaving the alternator the power is going through 6 diodes or rectifiers that turns the Ac power into DC.
The reason i said '' actually '' is...
electrical it don't matter , but you have a cooling fan on it and it matters what direction it has to run to cool the alternator under the hood under constant load and heat.
But for short run or with less load it would not matter either.
I never would had thought to use a chainsaw like that, that is very ingenious and easy to use when stranded.
Thanks for letting us know.
Well, I done that too about 25 years ago, that makes me feel old.
In Idle it is ok. If you increase your RPM and turn your lights on You will replace all the light bulbs on your car and that was a old car without electronics.
Without the battery the voltage regulator can not function right and will put too much or not enough power ( volts and / or amps ) out or will be erratic in power output.
In newer cars it is a must to keep the power at steady voltage or amperage.
The electronic circuits could and will be destroyed if you drive without a battery.
How would you like to replace hundreds if not thousands of dollars worth on electronic and electrical items on your car? Like computers ( some Cadillac have 7 of them), sensors, injectors, ignition related items, speed control etc etc....
In the older days it was normal to remove the battery to see if the charging system would work, but mechanics back then would do it only in idle.
But those old days are gone with the introduction of the electronic era of cars and mechanics our days will not do this anymore in fear of destroying electronic items that keeps our cars running.
