Change Table Mobile for infant - DIY - Forest Theme by Bonnonon
Featured
This is a very simple instructable that is  low in cost and high in reward, while being easy to make.
My wife was complaining about our daughter rolling around and getting distracted while she was trying to change her. She asked me to set up a mobile and hang it from the ceiling. Considering all the time I had spent on the nursery design I was reluctant to put up a big long hanging mobile; this design was my compromise.
*Important* I have heard of people suggesting to not use string around babies, but I feel that my mobile is safe for one main reason - it is only being used for the change table, which means an adult will be present at all times in and around the mobile.
List
3" screws #8
A corner wall
drill + drill bits
hand saw
Piece of wood 3"-4" diameter and min 32" long
twine
(optional - chop saw)
(optional - duck tape)
Step 1: Find a Branch!
Please do not look at this instructable and then go cut down a live branch or tree. Use dead fall which is readily available and easier to cut! :)
Find branch about 3"-4" diameter and min 32" long.
The longer the branch the farther out the mobile will be out of the corner.
You will notice in the second image I cut both ends flat. If you are good at judging angles you can cut the wood on and angle and save cutting a 45% angle later on.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
