Introduction: Cheap Halloween Chain Decoration $2
In this Instructable, I will show you how I made a Cheap Halloween Chain Decoration for less than $2.
I have also included my Youtube Video, for the people that wants to watch it.
You will need:
6 Foot long Foam Pipe Insulation 1/2" inside diameter ( I bought mine at Lowes for less than $2 )
Scissors
Step 1: Cutting
When buying the Insulation pipe, buy the type that's already split and with glue strips. This will help out in the long run. Then use a pair of scissors to cut the pieces, cut them about 1/2" thick. You should have several pieces, if you need longer lengths, buy more insulation pipe.
Step 2: Putting Together
Now that we have the pieces cut, insert one of the pieces like the pictures and pulled off the plastic, to show the glue, then stick them together like so.
You might have to watch the video to see what I mean.
Also allow the glue to dry 24 Hours, before using outside.
Step 3: Finish
Once you have all the pieces together, used them where you want. I installed mine onto my Pallet Coffin.
Check out my other Instructables on the Coffin, Skelton and Tombstones
Thanks for checking out my Instructable. Happy Halloween
Halloween Contest 2017
Hand Tools Only Contest 2017
