Chrome Polishing, Mythbusters Style
  • last photo ←
OK, I know that the Mythbusters didn't invent this idea, but that's where I heard about it.
Step 1Have some rusty chrome.
I'm sad to say that I've been a bad daddy to my little bike. These pipes were new a few years ago. The originals were completely rotted out, so I got these replacements on e-bay. Par for the course with aftermarkets the chrome ain't that thick.
It doesn't help that I haven't so much as pulled the cover off for weeks at a time.
72 comments
1-40 of 72next »
Jul 8, 2011. 2:53 AMmrlunna13 says:
I have a 1975 Honda Goldwing GL1000 with a LOT of chrome, and the very best thing I have ever used is a product called "Brasso". It is a liquid, but also comes in a paste. It works on EVERY kind of metal.
Sep 11, 2011. 9:47 AMiwilcox says:
Always used a combination of Brasso, Autosol and Elbow grease... and worked well on all the Wing's from 76 thru to present... in fact, brasso is smooth enough (not that abrasive) that it can be used to polish the frame etc!
However, i was introduced to a product recently (the name of which evades me at the moment - I'll check back when i remember!) which put all of those to shame. It was test proven to me on a REALLY rusty bin, literally a splash of this stuff and 3 minutes buffing with a bit of jean material and this thing shone... I mean, really shone, I never seen a bin shine quite like it. Tried it on my stained and pitted GSX400T casing and it came up SHINY, for the first time since I've owned it, and it only took about 10 minutes to do the hole case!
Oct 21, 2011. 7:07 AMrecrafter says:
what is name of that last product you mentioned?
Oct 21, 2011. 7:05 PMmrlunna13 says:
I think he was talking about a product called "BLUE JOB" chrome polish/cleaner.
it is a powder, you can add water to make a paste, and polish with a piece of jean material. It is very expensive in my opinion.
Apr 22, 2011. 10:59 PMabadfart says:
fast orange works well to
Mar 13, 2011. 12:36 PMsunofgod says:
To protect the restored shiny chrome carefully spray with your favorite lubricating oil spray and then polish with an old cloth. This leaves a protective film on the metal which repels water. This is good for cleaning, polishing and protecting
and only takes a few moments effort every time you clean the motorcycle
to keep it looking good.
Sep 29, 2008. 9:49 AMakagoldminer says:
OK I have tried this before with just soap and water and aluminum foil. I didn't use the cola. the foil rubs off the rust and polishes the chrome or rather the foil particles fill in the rust spots and polishes to a sheen. after doing this it is a good idea to either clear coat or wax to protect the new finish.
Dec 7, 2010. 5:33 AMcarpe_noctem says:
both clear coat or wax wouldn't last the heat of the exhaust pipe, unless there's some high temp clear coat i haven't heard of...
Sep 20, 2010. 11:22 PMabadfart says:
i have been riding an orange cb 350 but im moving up to a cb 750 with a windjammer
Apr 26, 2010. 11:33 AMIw-Munt says:
Great Im gonna try this on my Monkey bike.
Mar 24, 2010. 2:24 PMandrew_roark says:
I own a pristine 1972 Honda 350.. Great work on your Instructable
Dec 20, 2009. 9:13 PMerikals says:
i did this with my dad's bike before he (my dad) sold it and the buyer was really impressed (he left $100 more) and now with the money we may just buy ourselves an iMac - know the best model to buy?
Great Instructable
Jan 6, 2007. 2:16 AMironlizard says:
Odd thing about cola, it contains phosphoric acid. Other sodas don't. FYI: much stronger phosphoric acid can be purchased at the auto parts store for about as much as a three liter coke. It also works wonders on non chromed rusty metals.
Dec 18, 2009. 8:07 PMCodaVespre says:
PH down for hydroponics is also phosphoric acid and a much more concentrated solution as well. Its possible to mix it with polymers to create a gel that sticks to things.
Oct 20, 2009. 11:17 AMronmaggi says:
The phosphoric acid in the cola is what does the trick. I have used regular cola without the foil on engine parts. The sugar helps hold the phosphoric acid onto the parts while soaking. After seeing what cola can do to rust you may want to try www.instructables.com/id/Homemade-Carbonated-Beverages/
Oct 29, 2009. 2:56 AMac7ss says:
Diet cola has no sugar... :)
and it would be the Carbonic acid you are referring to.
Nov 7, 2009. 7:37 PMronmaggi says:
 I was referring to what I was taught, that the sugar in regular cola helps hold the phosphoric acid to the parts your cleaning. Carbonic acid does nothing to rust. We sell dedicated rust removers that are phosphoric acid. If you read the ingredient list on most commercial colas, Phosphoric acid is right there.
Oct 29, 2009. 11:38 AMpsychotron says:
You might want to read the ingredients on cola some time...
Carbonic is a very weak acid, the phosphoric acid makes the cola "tart".
Pepsi has citric acid as an added ingredient...
Mar 29, 2009. 5:02 PMxchef95x says:
so just scrub with Dt. Pepsi and Aluminum foil? That sounds to easy, whats the catch?
Oct 24, 2009. 3:27 PMRich99 says:
that's how we did it up az\t the gm plant in tarrytown, ny., to the hundreds of cars sitting in inventory. (in the 60's)
Oct 23, 2009. 5:04 AMt.rohner says:
The catch is that i will rust immediately when it comes in contact with water.
Those spots that rust, are pinholes in the chrome coat. By this or other polishing methods you remove the rust and then you you have the bare steel on the surface. You'd need to clear coat it, but there are not too many clear coats, that can handle high temps on exhaust pipes.
Jul 31, 2011. 7:12 PMLeona3000 says:
When you remove rust with phosphoric acid, you are converting it to a compound with a single oxygen atom. It's black, and inhibits rust. Unless the pits are severe, it won't rrust easily
Oct 23, 2009. 9:59 AMPhoghat says:
Hi Temp engine paint is available in colors, shines nicely, and gives a custom touch (black for eggsample)
Oct 24, 2009. 7:11 AMPhoghat says:
Why no, it wouldn't be. But, given the choice between shiny slightly scratched chrome and a color which looked custom, I think I'll take the color.
Oct 25, 2009. 12:21 PMt.rohner says:
There are other chrome plated parts that don't get hot... it may be helpful for that.
Oct 22, 2009. 10:30 AMLinksep says:
As a former professional detailer I can tell you the best method I've ever seen is "0" or "00" steel wool and glass cleaner. Cola has nothing to do with it. When I saw that episode I was (once again) disappointed in the Mythbusters for totally botching the results of something they tested.
Oct 22, 2009. 10:33 AMLinksep says:
I forgot to add... With "0" or "00" steel wool you will never scratch REAL chrome, but if it's simply polished metal (or god forbid) chrome painted plastic, you will scratch the heck out of it!
Oct 23, 2009. 10:02 AMPhoghat says:
I"ve alwys heard NOT to use steel wool, as it embeds itself in the chrome. Totally anecdotal
Oct 22, 2009. 11:36 AMcriggie says:
Save your elbow grease - take the pipes off and spin them in a lathe (watch out for protrusions)  while holding polishing thing of choice against it.
Oct 22, 2009. 10:09 PMold n grumpy says:
Aside from a little elbow grease what makes this method better than chrome polish ?
Oct 22, 2009. 10:24 AMabqjohn says:
This came up recently on one of my motorcycle lists I subscribe to.  It's the foil, not the coke.  Try it without the coke, and you'll see.  My mom recently gave me my grandfather's F-150, and I tried it with just water for lubrication, and got the same results.
Maybe the coke enhances the process, I don't know.  Just that water & foil worked pretty much like magic for me.
Oct 22, 2009. 11:22 AMpaulm says:
 there is a good chance that cola acts as a catalyst in this situation
Oct 22, 2009. 9:33 AMLynn Marie says:
I have heard of this method but think there are much better ways to clean rust from all metal.  There is a product called PRISM POLISH ( check it out - www.prismpolish.com).  Use it on all metal, fiberglass and plastic (like headlight lenses and wind screens).
I found it works better than anything else I tried.
Jan 14, 2008. 1:30 PMbigbadchevy says:
I have a question. I have a custom truck with some polishing of the wheels in need. My question is in regards to the last few photos (after). Were those hairline scratches already in the finish or is that to be blamed on the foil?? I know the cola will work but i dont want to scratch up the chrome
Oct 22, 2009. 9:04 AMBodhiWalter says:
To avoid scratches, I would recommend you experiment with these:  Bon Ami cleanser, toothpaste,  windshield polish.  If these aren't aggressive enough, try car polishing compound.  If that isn't aggressive enough, move up to rubbing compound.
Bon Ami is much easier on finishes than other cleansers.  It uses feldspar and calcite (I'm looking at a can of it now).  The others, such as Comet, use fine particles of sand.
There are different grades of buffing compound which can also be used, some of which will be more aggressive than anything mentioned in the previous paragraph.  They are discussed on http://www.caswellplating.com/buffs/buffman.htm as well as different buffing wheels.  You can get a wheel arbor to attach the buffing wheels to an electric drill.
To get into nonflat surfaces, you can use a toothbrush or fingernail brush or for larger areas, a floor scrub brush.  A natural bristle scrub brush will be softer than a plastic bristle one.  A buffing wheel made out of string or rope will get into crevices also.  Both are shown on www.caswellplating.com/buffs/buffman.htm
Naval jelly will remove heavier amounts of rust than cola.  It uses the same ingredient to remove the rust (phosphoric acid) and comes in a jelly to adhere to the surface without running off.  Hardware stores will have it.  It won't harm the chrome unless you leave it on forever.
1-40 of 72next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:Captain Pedantic
