There are many possible compound parabolic dish configurations and rather than me try to satisfy everyone, I though it would be better to give you a method to make your own petal templates.
Then you can make a 1 hour, 2 hour 3 hour or 4 hour compound parabolic solar cooker.
Whatever you want is within your grasp! You can easily make petal templates for parabolic dishes with this method too.
For 12 petal templates the error in the method (because you are using flat material to make a surface curved in 3 dimensions) is about 1%. I believe that is acceptable.
If you do not want to read the whole instructable, just read the image notes on the first image.
It should suffice for many people.
Brian
Remove these ads by
Signing UpStep 1: Compound parabolic concentrators, what are they?
Many times the reflectors for box ovens are based loosely on this type of concentration. They are good because if you face the box cooker the right way it stays collecting sunlight well for a long time.
But I wanted something different. I set out to apply the same principle to parabolic dishes.
Parabolic dishes are great because they can focus a lot of energy but they quickly go out of focus and have to be readjusted. There is virtually nothing out there about applying the same principles to parabolic dishes so I had to start from scratch. My first compound parabolic dish was a great success but not many people were interested in copying my construction method. They prefer a template.
Visit Our Store »
Go Pro Today »
I read carefully all information posted by gaiatechnician.
I found this webpage that might be interesting for those of you reading this post:
http://solarcooking.org/plans/parabolic-from-flat-sheet.htm
Cheers!
Thanks Brian.
Please post the patent number for the work you mention by Roland Winston, I'd like to see what he did.
I wrote a freeware program that calculates parabolas of any depth and diameter, you can see or download it here . I'm thinking of writing a calculator to help people make compound parabolic collectors as you've described in this article, they are extremely useful because they don't have to be aimed as parabolic reflectors do, looking at his patent might help me get a few ideas about how to approach it.
Thanks, Mike
It contains some of the math that you need.
Anyway, the seashell troughs are completely new to me but they help show that I was on the right track with my "clam shaped" solar cookers. (Even if I only ever made one).
Have you seen the solar design T-square? Thats what I used to make the clam shaped design. Maybe you could do a better design and more repeatable design with your grasp of mathematics? Brian
However, if the patents have not expired, you just have to be careful about making, using, offering to sell, selling or importing anything that is covered by the patent's claims. All modern U.S. patents have claims. See 35 U.S.C. 271.
If you make "petals" scale them up to be similar size to the ones I used there and there should be no problem. I collected a lot of details about that solar cooker and it worked pretty good. The pot was a similar size to yours. (Fits in an oven turkey bag). I forget exactly what size it turned out but it was more than 800 square inches. The second version (just with mylar without a backing (and an attempt to hold it open like an umbrella) did not work so good. The mylar must be stuck to a rigid surface for best results.
I hope that helps
I still think you should try the cone solar route, it is newer, less traveled but has great potential.
Brian
Yeah, the math is scary hard. I avoided it too.
I suggest that you do not use the petal method.
A guy called Magnar suggested I look into something that I have been calling cone solar. My cone solar project got stalled for the winter but there are several videos on youtube about it. I certainly do not claim to have invented cone solar but currently videos about it are very thin on the ground.
So, I suggest you make the elevation and plan of your proposed dish, with a circle or ball representing the size of your pot and work from there to design your cones for it.
I made this playlist of videos just for you! I hope it helps. I will add videos from other people as they become available and probably remove mine. Best of luck Brian
http://www.youtube.com/my_playlists?p=608E5F0EB26CDDE0
It was really more to show myself and other people what happens with off focus paraboloids and other shapes. YOU are the SUN and the reflection you see is the same size (pretty much) as the area that reflects onto the target.
I spent ages trying to do this in software. It ended up being the basis for the solar design T-square idea.
