Remove these ads by
Signing UpStep 1Gather up those materiels.
2 alligator clips ( may substitute heat shrink tubing, but this is easier)
1 Pair of wire strippers and cutters, I used gardening scissors because of their ability to do both.
1 Pair of cheep headphones, I used some westjet ones.
1 Speaker, mine is just a cheep sony one.
That's it!
Gather them up and continue!
running any amplifier at less than half the rated ohmage cause damage to it.
and about those connections its stereo not mono so each of the wires that go to each earphone have a negative and a positive so you really should hook it up on only one of the wires (preferably the right side) and use the negative and positive on that side. if you don't you could accidentally short one channel without realizing it has happened. and that could damage the amplifier as well.
Are you sure about that?
And I said to use cheap speakers.
a ohmage too low for a amp causes it try and push too much electricty through it so it gets fried.
think of a battery they can go nice and happy on a decent load, but put something that takes too much current on it and it will heat up and get damaged.
Please Help!!!
Try, try, and try again is all I can say.
