3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Convert a NES gamepad to USB with Arduino
Step 6Construction: The atmega
Using your needle nose pliers you need to very carefully bend the following pins of the microcontroller out at a 90 degree angle, right at the base where the pin gets fat.
Pin
1     28
2     27
3     26
4     25
5     24
6     23
7     22
8      -
9     20
10    -
-      16
-      15
the pins marked with a - leave pointing down, these will fit into the original shift register "socket"
The pcb has a silk screen of which way the sr went in, line up the atmega where pin one is on the same side as indicated on the silk screen (facing the cable connection), and where the lasts pins are in the next to last set of holes
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
57
Author:osgeld
