3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Convex Glass Tile from Bottles
Step 1Jig? Yes Please!
Jig? Yes Please!
There are really good bottle cutting jigs out there, but I loath to purchase, store, and ultimately yard-sale a specialized tool.  So here is the simple, flexible, and repeatable setup I use to cut glass cylinders:
52 comments
1-40 of 52next »
Jan 13, 2012. 9:16 AMshuja.shaher says:
great!!!!!!!!!!!!
once you make a bottle to a tile world of options open up
I am not good at glass work
but I am rearing to go
Jan 10, 2010. 3:57 AMlemonie says:
Where do you use the oil? You mention washing it off, but I don't see where it comes in.
L
Jan 10, 2010. 9:34 AMRadBear says:
You would use it to lubricate the cutting wheel of the glass cutter.
Jan 10, 2010. 12:14 PMlemonie says:
A very small drop. Glass-cutters break-up the surface by localised pressure, I guess an oiled surface would retain the glass-dust?
L
Jan 11, 2010. 3:36 PMRadBear says:
I typically roll the cutter blade through a small puddle of oil ( a couple of drops) to coat it lightly. I'm sure it retains the dust but my understanding is that the oil keeps the blade from getting snagged in the score mark it has just made so you can score the glass in one continuos motion. If you score glass multiple times it doesn't break cleanly.
Jan 12, 2010. 12:06 PMlemonie says:
Oh yes, one cut only.
L
Mar 15, 2011. 5:45 PMbricabracwizard says:
The oil also keeps the blade edge sharp for longer
Feb 20, 2011. 5:01 PMDreMMoore says:
I cannot wait to try this out! I have collected various blue and green liquor and wine bottles to make a kitchen back splash in my house. When I have time to get it started I will post my pics. Which leads me to a question: Has anyone tried using thinset or some kind of mortar to attach these tiles to a wall? I'm wondering how well they adhere since there is come curve to the glass.
Jan 27, 2011. 3:35 PMarkrite says:
Brilliant instructable and also everyones ideas about different effects. The waste is what I really want to comment on. The bottle bottoms can be laid within a square frame and epoxed together to for an old English cottage style window, like something out of Hansel and Gretal.
Has any one any ideas for the tops??
Jan 28, 2011. 3:16 AMarkrite says:
Lol..Brilliant. Can you aimagine a bottle room. Windows, lights and walls. Using clear, painted clear, browns and greens and maybe and with a certain amount of difficulty, embossed bottles!!
I still got a ton of work to do on my Land Rover and to rebuild a Lowrider, so I will so enjoy doing thid sort of stuff when I've finished. Thanks for a super Instructable.
Jan 26, 2011. 6:13 PMTheMightyBeagle says:
That's awesome. I had to buy that same glass cutter for another project I was working on. My husband and I are buying our first house now and i've been tossing around kitchen backsplash ideas but i'm a bit of a cheap skate. I love this idea. I might have to try this out. Might take afew cases of beer to get enough tiles for the entire backsplash but I'd take drinking beer and playing in the garage over emptying my wallet any day.
Jul 12, 2010. 7:37 AMthickneckarts says:
I find that my bottles end up with long vertical cracks, from where the bottle was scored, after I heat and cool to separate the 2 parts. This happens more often than not and I have tried just about every "way" to separate the 2 parts with less stress than the previous "way" I tried. Any advice?
Jan 6, 2011. 7:56 PMfretted says:
http://www.greenpowerscience.com/BOTTLECUTTING.php3
Maybe you could get some ideas from this guy he uses water to cut his bottles
Dec 30, 2010. 12:28 PMDriX says:
Try without the cooling. I just heat the scored line with a candle, rotating the bottle as I do that, when I see that it's all cut (you can notice the cut done if you look trough the bottle) I just take the two parts and make a little force to separate them with my hands.
I've used that method and it worked from the first time!
Dec 22, 2010. 7:24 AMcoopgrl88 says:
If you wanted to go a step further, i suppose you could slump the glass to clean it up. Have some kind of metal mold and put the pieces in a kiln, Could make for a different affect. I really do love what you have done, though :)
Dec 16, 2010. 10:25 PMjomac_uk says:
Many years ago, i helped out in a small factory that fitted new gun assemblies to the old fashioned CRT's These tubes were laid face down and near the pin end of the tube neck (like a small bottle) it was scored all the way round the circumference with a glass cutter. Then a home made tool that consisted of a loop of wire, like an upside down letter "U" with the ends connected into a terminal block was used, this wire loop was heated with a low voltage electric current until almost white hot and hooked around the tube neck whilst the neck was slowly rotated until the glass cracked on its own!
I dont see why the same principle cannot be used here?
Dec 15, 2010. 9:40 AMferjanyen says:
I like this. I cut botles by wraping a few turns if cotton string over the mark, soak the cotton with metholated spirit and ser alight, when hot, after a min or so i dunk the bottle in cold water and it will crack jus on the mark, good luck!!!
(use safety gogles and gloves please)
Dec 15, 2010. 12:33 AMpaqrat says:
Oh, forgot to say this before but this is a very, very cool instructable. Good job.
Dec 15, 2010. 12:30 AMpaqrat says:
Some months ago I read of a new product called Looking Glass. It is a spray "paint" that puts a mirror finish on glass. On the inside of glass, making it a mirror. Assuming it works as stated wouldn't it look great on these tiles? I have purchased a can of the stuff but I haven't had the chance to try it out yet so cannot say if it works or not.
Dec 11, 2010. 6:18 AMcamp6ell says:
i really really like this. do you have any pictures of the tiles installed and grouted?
Dec 9, 2010. 6:37 AMBrad I. says:
What about safety of the finished product? Is there a method to prevent people from getting cut if they touch it?
Dec 10, 2010. 9:25 AMhalmars says:
Just rub the sharp edges with another piece of (offcut) glass. This will dull the edge quickly at no cost no tools. The bottle neck will provide a handy handle but think safety and wear suitable gloves.
Dec 9, 2010. 6:42 PMBeergnome says:
Emory cloth should cut down the feather of the glass. also, a dremel tool with a sanding wheel could do the job
Dec 9, 2010. 11:47 AMTransquesta says:
I would imagine you could 'tumble' the glass in a drum, but you'd lose the distinctive transparency. That leaves individual sanding/filing. :-)
Dec 9, 2010. 6:40 PMenforcer72 says:
I remember cutting and shaping test tubes in high school with a propane torch (much to my father's displeasure as the little propane tanks were expensive back then for the amount of gas you got). I had a good amount of luck scoring and even basic glass blowing using them, but had trouble with them if I tried to heat a large section with the torch, the delineation point of heating would cause problems with the temper of the glass I believe. Causing different characteristics of the glass. some would shatter at the slightest pressure, some were fine and just could not be reshaped. I did find an old propane torch and make a fan attachment to spread the heat, but found an oxy-acetylene torch with a makeshift flame spreader worked well (until I accidentally hit the trigger and blew it apart., I was 14-15...). excellent Instructable and I could see the use for this in remodeling to reuse and re-purpose bottles especially in states without return deposits. I would love to make a backdrop for my counters out of the green bottle pieces.
Dec 9, 2010. 11:17 AMvincent7520 says:
I'll save this idea !…
I also saw a transparent wall made from the bottom of wine bottle … this was pretty interesting, especially because the owner used green, yellow and blue bottles …
(blue wine bottles are very rare these days : they used to sell white wine in Paris 50 years ago or before …
Dec 9, 2010. 11:45 AMTransquesta says:
Several variants of reisling comes in blue bottles--most of which would be usable for this purpose. :-)
Dec 9, 2010. 11:06 AMDweevil says:
A crinkled (variegated & cheapo) goldleaf on the back would give bright, changing effects under different lighting.
Dec 9, 2010. 7:40 AMlotusduck says:
Glass tiles at the hardware store just have colored paper taped on the back. If you wanted a variety of green shades or if you had a lot of clear bottles, that could probably work. Spray paint is a good idea obviously, but if you wanted a lot of different colors, it's easier to have a bunch of colors of paper than paint.
Dec 9, 2010. 7:21 AMKarinsart says:
Brilliant!! That turned out really well. I wish I needed to tile somewhere!!
Dec 9, 2010. 7:19 AMTwetwe says:
you can also get a frosted spray paint for glass.
Dec 8, 2010. 10:02 AMrory_woj says:
Very cool. Ive been wanting to do a green glass tile backsplash for a while but couldnt find the right color/price combo. This might just do the trick! Thanks
Dec 8, 2010. 8:52 AMpatricianorma says:
That is an awesome idea!
Dec 7, 2010. 10:17 PMTreasure Tabby says:
Oh neat-o and my dad just got one of those cutting wheels to cut I guess tile and other things too. What a recycletastic idea. :D
Jul 28, 2010. 2:22 AMJuiceWeasel says:
To create a frosted effect, you could also sand blast the back of the tiles. Great idea Thanks muchly!
Dec 5, 2010. 6:53 PMfrazeeg says:
They also make a paste called Armour Etch that will give glass a frosted look and will probably be less expensive than going to a sandblaster.  Just paint it on, let it sit for a few minutes, and wash off.
I will admit it might be a little tedious with a bunch of tiles though, and sandblasting will go quicker.
Dec 6, 2010. 6:16 PMjptrsn says:
Maybe etch before you cut up the bottle? Wash bottle, pour some in, swish it around, rinse, and you're set! Less tedious than individual tiles, and possibly cheaper than sandblasting.
Dec 7, 2010. 8:38 AMfrazeeg says:
Unfortunately the Armour Etch won't "swish" around since it's a paste. It has the consistency of toothpaste. Diluting it to achieve the right viscosity wouldn't work either since the paste has to sit and work on the glass and if it was runny enough it would just slide down and collect in the bottom of the bottle.
1-40 of 52next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
20
Author:asdterror
