You can recreate these steps for any tool and any disability!
Remove these ads by
Signing UpStep 1Ingredients
Shapelock or similar low heat plastic (polymorph)
Spoon or other tool to modify
Warning: There has been some concern about having this material in close contact with skin either while cool or hot. Here is the MSDS for a similar product Friendly Plastic. The MSDS does not suggest any ill results from contact with skin. It is true shapelock has not yet released an MSDS that is easy to find. If someone can find one, please comment below.
Of course with all hot things use caution and if doing this for someone who has low heat senstivities, use a glove or some insulator between the warm plastic and skin. The plastic doesn't stick you your skin very well, so when it dries, it comes right off.
The plastic is prepared at 55-60 C, which is hot enough (scalding) to give you serious burns (10 minutes in 55 C water can cause third-degree burns). So for sure, don't mold the plastic directly from the melt! Let it cool to below 50 C before molding.
Assuming you let the plastic cool enough, then thermal damage to the skin is less of an issue. However, making a "permanent" bracelet is a danger. If you mold the plastic around your wrist, for example, once it hardens you won't be able to remove it over your hand. And you can't reheat it (see previous paragraph). Not a good situation.
What about chemical irritation? Or outgassing? These questions can only be answered by reading the MSDS. Here are two, for CAPA 6800 and for Friendly Plastic. Both of them indicate no chemical hazard, just possible mechanical irritation (chafing or scratching).
So, at least from the actual physical data, rather than lawyers, this should be a safe Instructable.
Gruffalo's and DarkClaw's comments aren't unreasonable.
You might want to add some discussion of the safety issues (see my reply to Gruffalo), and links to the MSDS for completeness.
Also, having the user wear anitrile glove, or a coating of Vaseline as a barrier, is probably not a bad idea.
Hmmm, Ps3 controller Mod? PC mouse mod?!
I like where this is going.
