Introduction: Cutting Wine Bottle Corks
Picture of Cutting Wine Bottle Corks
This is a tutorial on making a simple jig for cutting wine corks in half, along their length.
The jig requires only simple scraps to build and is for use with a band saw, but could also be used to hold corks when using a hand, or even a knife, depending on the size of the kerf.
Using this jig on a band saw, it's easy to, safely, produce a few hundred corks halves in an hour.
Step 1: Cork Cutting Jig for the Band Saw
To make this jig, you need a piece of wood no less than 1-1/4" square on the sides and about 5" long, which happen to be the measurements of my jig.
The measurements of the jig can be varied. As long as you have enough room to drill the hole, and the jig isn’t too cumbersome to use, it could be most any measurement. For example: Your jig could be 1-3/8" square by 5-1/2". In other words, you can make it larger or smaller, as long as it allows you to remain safe. If you do make it larger, you can always shave more off the sides or length later.
Step 2:
Picture of
Once you have your piece cut, you need to drill a hole to hold corks.
To drill the hole, first find center on one end. If your piece is square on the sides, you need only make an X by drawing straight lines from corner to corner.
If your piece is not square, measure the short side and then mark that measurement on the long sides, then draw your X using this points.
To insure the drilled hole runs true, 90 degrees from the table, you can use a couple pieces of scrap to support the piece on a side and end.
Using a 1" spade, spur or Forstner bit, drill down into the end about 1-1/2", using the center of the X you just marked as your starting point.
I used a Forstner bit because they cut smoother than spade bits, but a spur bit would cut about as smooth as a Forstner.
Whether using a hand drill or a drill press, clamp the jig to your support scraps. This will keep it from spinning and, possibly injuring you. Too, if the bit blows out the side because your drill did not stay 90 degrees to the wood, it won’t hit your hand.
When cutting deep holes, back the bit out often, to clear the debris from the hole, so the bit can work less hard and run cooler.
This jig has already been used, so you can see the kerf, which cuts into the hole each time a cork is cut.
Step 3:
Picture of
To help pull the jig back, after each cut, make an indentation on the opposite end from which you just drilled your hole. It only needs to go in about 1/8", but can go deeper, because it’s not a critical.
Step 4:
Picture of
To make your first cut, mark center and the end of the jig, over the hole you just drilled (e.g., if your jig is 1-1/2" wide, the mark will 3/4" from each edge).
Install your band saw fence and set the blade guides so they just clear the jig.
Touch the center-mark you made to the blade, then move the fence against the jig and lock it in place. Now, each time the jig pushes into the blade, it will run down the center of the jig.
Insert a cork in the hole, push the jig against the fence, with the indentation facing up, and run the jig into the blade, making a kerf about 1-5/8" long, or just a little past the bottom of the hole (you only need to go deep enough to cut the cork in half).
Use the indentation o to pull the jig back, then shake the cork out and load another.
Step 5:
Picture of
NOTES:
(1) Sometimes the corks will pull out of the jig as you draw it back to you. I just keep going until several accumulate, but not so many they start dropping off the back of the table. Then I leave the jig in the blade so I can reach around behind the somewhat shielded blade. Of course, use appropriate caution.
(2) If your corks have names you want to display, pay attention to how you load the corks.
As usual, use caution.
jd8of9 (author)2016-10-28
damn .. i need a band saw.....
This is great! It's easier than it looks and it's way safer this way, I would imagine!
If desired, the cork holding jig could be made longer, to keep fingers farther away from the blade.
A stop block in back of the blade, just past where the cork would be fully cut, would also add a measure of safety.
homer35805 (author)2014-08-03
Seems like you could play with the angles and cut a bunch of fishing poppers, you would only need to paint them and glue them to a large enough hook and you would never have to worry about buying that particular lure ever again. You could even dress up the hook with a silicone skirt from a bass spinner bait. Or get even fancier with feathers, rattles, really anything. But great idea for cutting them in half.
Major Blunders 2 (author)2014-07-21
Very good idea! It set off a light bulb in my own mind! If you were to drill the hole completely through the jig, you could clamp it to the table in line with the blade, then continuously feed the corks through the jig without having to stop and load a cork into it. If one were to build a platform for the jig to sit on, the corks could slide down a ramp and into a box or bucket. This seems like it would greatly increase the production rate.
Add to the foregoing, a bit of PVC off the back of your saw might direct the product to a bucket.
KellyCraig (author)2014-07-21
I've already made a couple bulletin boards by gluing these to thin paneling, then framing it.
Cutting the corks in half, they go twice as far and just seem to work better for the cork boards.
A hot glue gun allows you to quickly secure the corks.
I guess it would be a good idea to show the why's of doing this. I'll assemble another in the near future and post it. Meanwhile, there are many good ideas for using corks posted on the Net.
We inherited about five thousand unused corks from a locally winery, which was shutting down. It just seemed a shame to ignore them, considering the saw dust making equipment I have near my back door.
mrandle (author)2014-07-21
What are you planning on doing with the corks?
About This Instructable
25,706views
83favorites
License:
More by KellyCraig:Lawn Vacuum System Using Woodshop EquipmentSHOP RAG STORAGE: SIMPLE, EASY ACCESSShop Eye Glass Storage (Ceiling Mount- Adjustable)
Add instructable to:
