Whether or not I need something is beside the point. The question is 'Do I want it?'
While in the process or setting up my workshop, I read quite a bit about the Cyclonic Dirt Separator - a device that allows the heavier particles of debris, such as wood shavings or sawdust, to settle to the bottom of a container, while the finer particles go into your vacuum's filter.
I had to have one.
But I didn't particularly want to spend a load of money or fabricate individual pieces. So this Instructable was born, using (almost all) store-bought parts.
Remove these ads by
Signing UpStep 1First - A Container
From what I've seen in other cyclone separators, I think the suction pipe step 3 should extend down into the bucket several inches.
I'm thinking that this might work great for the new lead paint requirements the epa has place on remodelers. We now have to clean everything up with a hepa vac. the problem is that these things don't have much volume for debris as they are mostly focused on the fine dust. so with something like this, you could capture all the construction debris and without filling up the expensive hepa filter.
let cure.
Instant fix to the low weight problem, without making it unmovable
(10-15 lb free-weight plate should work ok too.
An unintended benefit to this design is, it makes your standard shopvac into a high-class wet/dry shopvac!
I'd probably just get a small import brake drum from the scrapyard pile, but even some round smooth rocks would work.
You are right about the wet/dry benefit. I haven't tried it, but I would think it would keep your shop vac dry while sucking up spills.
Thanks.
A device as this would be a good thing to my wood lathe. I did a homemade design, it was almost a complete failure: the container collapsed, the tubes rang horrifying, and then I abandon the project.
(Though I know that almost nobody who would do this would ever throw a five gallon bucket away.)
