D.I.Y. Screen Printing
Once you start screen printing your original designs you won't want to stop.
Watch the the video below and subscribe to our weekly show on iTunes to get even more.
Step 1Pick out your design
First, pick out the design that you want to use and print it out. Make sure it's the right size.
83 comments
1-40 of 83next »
Jan 18, 2012. 10:20 PMbuilderkidj says:
I'm gonna make a half life shirt and a Portal shirt!
Pictures:
Oct 19, 2008. 2:46 PMpoor_leno says:
I like this instructable a lot! Could a 'thinner woven mesh fabric' be something like womens' tights/stockings? Cheers
Nov 28, 2011. 4:31 AMMel Fischer says:
I use old sheer curtains that I find at thrift stores - the tighter the weave of the mesh the better. Gets you a ton of fabric for a very cheap price, and it's recycling an old product!
Mar 9, 2010. 11:45 AMlikls says:
I've found lace with a cool pattern to make a girlie florally pattern. I like it especially when making a picture of a bomb. Atomic weaponry + flowery sweetness = best anti-war tee ever.
Feb 24, 2009. 7:46 AMJonesForRevival says:
I used nylon pantyhose and it worked great. Depending on the size of your frame/embroidery hoop, you will need to stretch the nylons to as taught as you can without causing tears. The weight of the mod podge on the nylons will cause it to stretch a bit after you wash it and it dries. If you get a slight run in the nylons after you've put it on your hoop/frame, it's okay as long as it isn't in a place where your screen will remain open. In other words, as long as you mod podge over any runs, they won't hurt you.
Jul 18, 2010. 4:37 AMMagicScarf says:
i tried to draw on my screen in pencil, and found it rather difficult, even though i had it tightly placed in the hoops, i had to pull the fabric around to make it tight enough to get the pencil marks on....i was wondering if other people have found something like a sharpie marker to be better, or if they were having problems with the pencil too? i might have bought the wrong material....i bought something that said 1005 polyester but it just didn't work out very well....at the end the image was not very clean at all. my art was very finely detailed and small lines, i think i just botched the whole thing really. so i'll try again : )
Nov 28, 2011. 4:28 AMMel Fischer says:
In addition to a higher mesh count for fine lines, Tension is also very important.
If your fabric was loose enough that you had to pull it around to make it tight enough to draw on, it wasn't tight enough overall to get a good print from it. You need your mesh to be as close to immovable as possible, so it holds the image in place when you draw your ink over it with your squeegee or what have you.
When I first started hobby screen printing, I made wooden rectangular frames and stretched old sheer curtain material over them, attaching it with a staple gun to get it as tight as possible. Works great for average detail designs and I still do this for one-off prints when I have t-shirt parties for my friends - it might give you better tension than an embroidery frame if you can't get it tight enough. :)
Don't give up! Screen printing is tons of fun!
Dec 11, 2010. 3:24 PMTim-the-Tshirtmaker says:
http://www.silkscreeningsupplies.com/silk-screen-printing-mesh
Try using a higher count mesh for thinner lines and small lettering. 250 or 300 should be good.
Dec 11, 2010. 10:33 PMMagicScarf says:
cool, thanks for the tip tim.
Feb 22, 2010. 6:48 PMGeekyGirl1103 says:
Could I possibly use this with acrylic paints instead of fabric paints?
Mar 9, 2010. 11:42 AMlikls says:
Nope. Acrylic is water-based, so it'll fade or wash out after a first try. Plus, it's not very flexy, so it'll crack straightaway when you wear it. Use regular (read: boring) fabris paint from a craft store.
Mar 20, 2011. 5:11 AMmslaynie says:
Nope... acrylic paint only washes out while it's wet. Once it's dried it's a solid flexible plastic. Believe me, I've got paint in some jeans back from my art school days that went through the washer and dryer many many times and didn't change a bit! :D
Mar 20, 2011. 12:27 PMecampbell1 says:
well, the problem isnt really that it washes out. It is mostly that it cracks and chips when it is on fabric.
Nov 28, 2011. 4:21 AMMel Fischer says:
I have a shirt that I hand painted with regular acrylic craft paints that has lasted for dozens of washes over the last 6 years. It has held up remarkably well. Cracking depends on how thickly you apply your paint. I only had issue with some white that required a lot of coats to get it opaque on my red t-shirt, after about a year or so it cracked a bit. Other than that, it has lasted just as long as any of the shirts I've screen printed using water colour inks or plastisol inks.
Mar 20, 2011. 1:41 PMmslaynie says:
Tell that to my jeans! ;)
Dec 2, 2010. 6:25 AM8bit says:
It is water based, but it cures AND dries. Once it cures, it should be nice and water resistant.
Oct 14, 2010. 9:12 AMuse606 says:
Ive been useing water based for a year or two and i havent had any fadeing or cracking on my custom abrams tank shirt.
Jul 8, 2010. 8:06 PMkingmii says:
are there any other paints/dyes i can use or is it only screen printing paint?
Jul 28, 2010. 8:35 AMlikls says:
fabric paint works, but it's thicker.
Jul 29, 2010. 12:46 AMkingmii says:
Thanx
May 15, 2010. 1:51 PMcraftsrme says:
I just spent major money on  screen printing equipment. Wish I would have found this earlier. Can you apply emulsion without a special tool? I need to find the easiest cheapest way.
Apr 22, 2011. 4:13 PMsuckrpnch says:
I haven't done this, but i thought I heard about using the spine of a magazine as a ghetto method as well...
Dec 11, 2010. 3:25 PMTim-the-Tshirtmaker says:
You need a screen coater. You can get one on ebay for fifteen bucks or so.
Aug 2, 2011. 2:20 AMnutsandbolts_64 says:
Water resistant glue? That's it? Does regular Elmer's white glue work? It's just that not a lot of those other brands over there are existent over here, so I always have to improvise materials around here.
Aug 2, 2011. 2:30 AMnutsandbolts_64 says:
Never mind, Mod Podge glue is just a sort of decoupage glue. Decoupage glue could be made from regular permanent white glue mixed in with water at certain ratios. I'll go 3 parts glue to 1 part water as that is the ratio used to seal decoupage projects, so it might as well seal a fabric for use on screen printing. There we go, improvised!
Jul 6, 2011. 2:14 PMmcecil kieffer says:
I have screens that I've used on several shirts. Is there a chemical to remove all of the design. It is faint but has caused some problems.
Jun 27, 2011. 12:16 AMmischka says:
Thanks for this, cool idea to use mod podge glue as a filler.
Jun 26, 2011. 9:21 PMxtacticalmonkeyx says:
what kind of fabric did you use for the embroidery hoops? What kinds do you recommend
Jan 7, 2011. 11:44 AMakyramoto says:
I finally got to try this, I used 'organza' fabric from the fabric store, it's cheap and it works great!!
On my 4th design, I love that it's simple and interchangeable, I can make multiple screens but only need a few hoops. I just have to remount them in the hoop when I want to use them, so I only need to store my loose fabric 'screens' rather than tons of wood frames.
Nov 23, 2008. 2:56 PMnimajneb2 says:
What does the ironing do? And how important is it? ( I don't have an iron )
Jun 19, 2009. 3:45 PMbeckamphetamine says:
you can throw it in the dryer for about 5 cycles instead =]
Dec 20, 2010. 8:07 AMjohnyradio says:
How long is a "cycle" in the dryer?
May 8, 2009. 8:28 PMmodus_operandi says:
my guess is the heat "sets" the ink/paint in place so it bonds better to the fabric doesn't come out in the wash :)
Jul 20, 2009. 9:34 AMGreigBery says:
Can you use the same screen multiple times - in a row and at a later date? How could you make a multicolored image? Great tutorial! Yours has made the most sense to me so far. Plus I love the idea of using the embroidery hoops!
Apr 5, 2010. 9:33 AMParaPhrasedProductions says:
for a multicolored image you would make multiple screens like for example the image they used you wold make the screen for the outline then make one for the inside area, but if you would do one with a border make sure that the inside design will overlap with the border, and print the border second, that way if you don't have the screens aligned properly, which might be hard with out a press there will be a little room for error and it will still look fine,
Oct 2, 2009. 6:13 PMiglo1234 says:
Can you reuse the screen? Or once that glues on there the fabric can't be used again?
Mar 9, 2010. 11:43 AMlikls says:
Yeah, but make sure your mod podge doesn't rinse out when you rinse the fabric.
Jul 24, 2007. 3:23 PMhannahnanna says:
i was wondering if you could use cheesecloth?? i have some leftover from a previous project.
Mar 7, 2010. 12:18 PMjohnny3h says:
Cheesecloth will work, BUT... it is WAY TOO WEAK to last for more than one or two prints, before it begins to disintegrate.  Once that happens, the smaller parts of the image on the stencil will deform, resulting in a very screwed-up print.
Apr 17, 2009. 8:14 AMStefro says:
Hey, I've been wanting to do this for ages but can't seem to find anywhere in the UK that sells mod podge. Anyone have any idea's where I can get it? or any alternatives to using mod podge? cheerz
1-40 of 83next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
768
Author:threadbanger
Threadbanger is a network for people who love to DIY, recreate, refashion and craft. Forget about corporate stores, we're here to help you create and find your own style! From our episodes, forum and ...
more »
