We built a 1000 watt wind turbine to help charge the battery bank that powers our offgrid home. It's a permanent magnet alternator, generating 3 phase ac, rectified to dc, and fed to a charge controller. The magnets spin with the wind, the coils are fixed, so no brushes or slip rings necessary.
Step 1Build the magnet disks
We had 12" steel disks hydro cut. We cut a template for mounting the magnets. Then we mounted 12 grade n50 magnets around the outside edge. We then built a form, and poured the resin with hardner.
1. the gearing robs power
2. the field coils rob power
3. not designed for high power long term output
4. only about 60% efficient turning rotary motion into electrical energy.
What wind speed is needed to generate 1 kW? Thanks!
thanks and nice DIY.
-. Juan
I love your work.
Going to build your Stator and put it on a 55 gallon plastic VAWT set up. It will be a 12v system.
During my research, months ago, I saw places that you could buy pre-wound copper coils. Now I can't find them.
Do you know of any place that I could buy your suggested wire set up already wound?
Thanks!
Rambob
Question: In the first picture. It shows the man installing a few final parts. Do the electronics have a nose cone to deflect water, or what would protect these electronics. Do they need protection from the elements ? This is an amazing creation !
Very functional.
So you are saying you pump AC to the house then condition it? What about ramping the the output voltage to 620VAC for transmission to reduce losses. I need to build a 130 foot tower because I'm in the woods in a valley, then another 200 feet to the house.
Also, I assume from the photo that your turbine is fixed directional. Any hints on omni-directional. I was considering a vertical turbine because our "prevailing" winds in Wisconsin, in this valley, could be any direction for days. But the vertical turbine, along with lack of efficiency, is noisy.
Thanks, Dan
What is the separation between the coil and the magnet face? I didn't see a stat on the field spread. I did note that the magnet has a 175 F max temp before damage and I have visions of a 100F plus day with the turbine cranking. How do the magnets stay "cooler" along with the coils themselves during power production?
