DIY - 4S1P Li-Ion 18650 3400mAh Battery
Published
Introduction: DIY - 4S1P Li-Ion 18650 3400mAh Battery
About: I love fly. Im a electronic, robotic and automation technician. I like drawing 3D parts.
I love flying and DIY.
I checked that some people fly a lot of time with wings with these batteries, so I decided to do my own 18650 battery.
Step 1: What Do You Need?
18650 Li-Ion Batteries - https://bit.ly/2KWxf43
Solder Station - https://bit.ly/2rDxdWR
Tweezer https://bit.ly/2wxEgVC
Larger Iron tip - https://bit.ly/2rDiF9F
40mm heat shrink tube - https://bit.ly/2wD0rKp
Some silicon wires
4S balance connector, you can get it easily from one bad battery.
Step 2: Prepare Your Batteries to Solder
With one knife scrape both poles, plus and minus.
Step 3:
Join the 4 batteries with a measuring angle square and put some hot glue.
Step 4: Soldering
Put your solder iron at 350/400º degree.
Put iron solder for 2 seconds on the battery pole and put enough solder to wiring.
Step 5: Wiring
Step 6: Heat Shrink Cover
Cut a little piece of heat shrink tube more 20mm than length of 18650 battery.
Almost done!
Step 7: Already Done to Fly.
A comparison with Tattu R-line 1550mAh battery.
I can fly with my Reptile S800 Sky Shadow 40 minutes, important to say at 25% throttle.
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    2 Comments
    Nice work! It looks very professional. Thanks for sharing links to the parts.
    That plane looks like it would be fun to fly.
