3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
DIY Awning
DIY Awning
Hurricane Ike hit us in 2008 and knocked out power for a few days.  My residence was not designed with energy efficiency in mind and so relied 100% on AC to keep it cool.  I made this awning in attempt to keep it cooler inside by blocking the radiant sun energy.  Indeed, it was about 3 degrees cooler inside with the awning than without the awning.  After the power was restored this awning served to lower the energy bill.  I did not measure that, however I'm sure it did.
In all the whole thing cost about $20.  Here's how I made it and what I would do differently next time...
Step 1Frame
Frame
Start by making the frame.  You'll need 1/2" PVC pipe, the T's and elbows shown here, PVC cutters, and primer/cement.  Visit your local Home Depot or Lowes.
The amount of pipe depends on the width of your window.  Mine window was about 5' wide, so a 6' wide frame was selected.  A main reason 6' was chosen -- I'll say this now -- is that the awning material (canvas drop cloth) is available in a 6' width.
I would not make the awning much bigger than this without more frame support structures.  A 3' gap (like mine) is about the maximum I would recommend.  I base this on having watched how it handled windy days.
Don't use solvent/cement yet.  You can dry-fit parts for now.
9 comments
Apr 12, 2011. 10:35 AMSandLizard says:
For the support brace where you didn't glue it you can drill a hole and put a clip through it. Like the ones used on towing hitches. Then you know it won't come apart but you can take it apart when needed.
Feb 3, 2011. 7:30 AMemit says:
Don't use bleach, use pure vinegar. Spraying will cover a large area.
Jan 16, 2011. 9:39 AMsabr686 says:
Great concept, and good job on making it. I live in a wetter-than-most climate, so I'm going to have to research what kind of material to use.
I would think that grommets would work well here, instead of the tacks. That way you can line up the grommet holes to the PVC, then strap it on with zap straps.
Again, great idea, bclamore!
Nov 6, 2010. 8:50 PMmikesnyd says:
nice touch. i am a huge fan of zap straps when it come to holding things down. Make a small incision between the edge and the seam to slide the strap through. Make sure not to make the hole on the right of the stitching. If you live in a windy area it will only be a matter of time before it strains and rips. Might have to replace the straps once a year or two. U.V. will make em brittle after a while.
I have a slight alteration of this where the awning can roll up. Just another pvc pipe and a slightly different stitched loop. thanks for the ible
Oct 22, 2010. 10:07 PMl8nite says:
It looks sweet! instead of tacks or whatever, check this out http://www.instructables.com/id/PVC-Clip/ you can see by my recent comment that it came in handy for me
Oct 22, 2010. 5:10 PMbobby sissom says:
very nicely done i was over planning a pvc version of this same thing but thank you for a much easier design i will follow your version
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:bclamore
