DIY Copper Style LED Painting Illuminator
  • last photo ←
Do you have a painting or a photograph, that you want to illuminate? Why use an old, boring light bulb, when you can make a much more energy efficient illuminator, that is a piece of art by itself.
Copper is a really good looking metal. It's rarely used for domestic applications, such as light fixtures. Almost everything, that is made out of metal these days is made out of stainless steel. I'm tired of it, so I thought: why not make something different. Something unique.
This instructable will show you how to make a very energy efficient and unique light fixture for illuminating your paintings or photographs.
I will also show you how you can make it light sensitive, so that it automatically turns on at night.
Step 1Materials
Materials
  • last photo ←
Here is an overview of all the parts, you need to make your very own Copper style LED Painting Illuminator:
  • A copper tube. These are widely available. You can get them at Home Depot and other stores that sells plumbing supplies. They're available in many different diameters. Try not to get one, that is too thin, as it will make it difficult to wire up the LEDs. The one I used was 1.5 centimetres (0.59 inches) in diameter, and I don't recommend using a smaller diameter than that.
  • LEDs. For this type of project, you'll definately want warm white LEDs. The normal white or cool white LEDs will often be more bluish in their light, and you don't want a bluish light on your painting or photograph. In the next step, I'll show you some of the many LED possibilities. The quantity depends on your needs and the length of the tube. I used 9.
  • Some enemaled copper wire a.k.a. magnet wire. It's a good idea to use two different diameters, so you can easily identify the polarity.
  • Resistors. The quantity and value depends on the type of LEDs and how many you use. I will show you how to calculate the value of the resistors in step 3.
  • Two screws for mounting your fixture on a wall. Brass screws are the preferred ones for this project, because they almost have the same color as the copper tube.
  • Some hookup wire to connect it to your power supply.
  • Some thinner hookup wire to connect the two ends of the tube together.
  • Heat shrink tubing. You'll need different diameters of it.
  • A sheet of ordinary paper.
27 comments
Jul 26, 2009. 9:28 PMspyler03 says:
One question. How many volts did you use to power this?
Jul 31, 2009. 4:06 PMjustinhyp says:
It looks like 12v... it said that somewhere... You can use a number of voltages... according to the resister you use.
Aug 1, 2009. 7:08 PMspyler03 says:
Oh... Youre right in Step 3 it says it. Thanks
Jul 19, 2009. 4:37 AMstarmoon125 says:
œ"; ;†›; I †¶ (ÙÛ„ I like painting and painted a lot pictures.When I get married,I'll get this idea.Very great!
Jul 20, 2009. 9:55 AMstarmoon125 says:
Plus.I'm a student of Art Department in a college of China.And I saw lots of great ideas in here.So intelligent and different mode of thinking were not like Chinese. Anyway,I like them.
Jul 20, 2009. 9:47 AMstarmoon125 says:
ÓZØé@b ÈÈ`/,*(Ù*QÙŒ²Ý„º ì:} Ë„ OK,But It has so long time till I get married. You are the first person talking to me when I join into this web site.We'll be friends.
Jul 20, 2009. 7:02 PMstarmoon125 says:
Thank you very much.
Jun 10, 2009. 9:05 PMCoodude26 says:
The setup for the light-adjusted switch seems a little overly complicated. Why nor just connect the photoresistor to the + supply and the collector of an ordinary NPN transistor? It would trigger when the photoresistor limits the current below the threshold of the transistor. I don't know if you said somewhere what voltage you were using, but you could still use a pot inbetween the photoresistor and the supply to make it less sensetive. Last thing, you might want to aim them a bit lower so the bottom is also illuminated. Also, I'm pretty sure they make photoTRANSistors. That would simplify the whole thing...
Jun 11, 2009. 12:18 PMCoodude26 says:
Don't transistors use digital logic? IE, above 5v = on, less than 5v = off?
Jun 12, 2009. 1:18 PMCoodude26 says:
AAAGGHHH oh my gosh. why in the world can't I get a simple explanation of how a transistor works. my brother is an electrical engineer at U of I and he can't explain it to me. can you give me a simple rundown of how a transistor would be "triggered" or how it's switched or whatever and what that triggers or sets in motion? Pleeeeeeeeassseee?
Jul 7, 2009. 8:18 AMpfred2 says:
Maybe because your question is flawed? There have been several different kinds of transistors developed. They mostly all work differently from each other too. I've even heard tale told that some of them are quantum tunneling these days!
http://www.google.com/#hl=en&q=quantum+tunneling+transistor&aq=f&oq=&aqi=&fp=F2LdvTVQwLA
Me, I'm more the old fashioned bipolar type though :) Those work on PN junctions and migrating electrons and holes. Just wait until you're checking out characteristic curve traces of those puppies. Switching is pretty dull stuff. Yawn, I'm all about analog myself.
http://www.google.com/#hl=en&q=transistor+curve+tracer&aq=f&oq=&aqi=g1&fp=F2LdvTVQwLA
Then there are different ways of using a transistor in a circuit.
One way:
http://en.wikipedia.org/wiki/Common_collector
Short answer to a screwy question though a small current controls a larger current flow.
Jun 23, 2009. 6:55 PMkemper says:
I love the amazing painting! hah
Jun 21, 2009. 8:14 AMgjm says:
Nice instructable; very well written with lots of photos. A picture is worth a thousand words.
Jun 11, 2009. 7:46 PMjay ess says:
looks great! but how much should it cost? or did i miss that part?
jay ess
http://importantless.com
Jun 10, 2009. 6:40 PMsdallesasse says:
It's like art illuminating art.
Jun 10, 2009. 8:44 PMThe Ideanator says:
very neat, I'll have to try something like this
Jun 10, 2009. 4:59 PMChrysN says:
NIce job! This looks really stylish.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
80
Author:Artificial Intelligence
Hi all, I'm a college student in the copenhagen technical college. I'm currently working with 3D printers and I'm building my own RepRap.
