You could be accelerating electrons to non-relativistic velocities after a trip to Home Depot and a visit to your local AC repair store and neon sign shop! Best of all, no advanced electrical or mechanical knowledge or tools are required.
Judges, see step 12 for contest entry details.
Here's some video evidence:
Thanks for all the support, guys! This project was featured on Hackaday, Slashgear, Engadget, Gizmodo, Gadgetblog, Tecmundo, Matuk, Zedomax DIY, and Make, as well as in the weekly newsletter and multiple times on our own front page!
Please don't forget to rate/vote!
Xellers
Remove these ads by
Signing UpStep 1: Design/Theory
Essentially, our cathode ray tube is just two electrodes in a vacuum chamber with a high voltage applied between them. When enough of the air in the chamber has been removed, electrons will freely accelerate from the negative electrode (cathode) towards the positive electrode (anode). However, instead of impacting the anode and returning to the power supply, some electrons will fly right past it and keep going until they hit a glass wall.
Some interesting effects that can be observed at this stage are sputtering and magnetic deflection.
Sputtering:
If the acceleration potential is high enough, then some electrons striking the anode will have enough energy to knock metal ions right off the electrode. These ions will be deposited on the walls of the chamber near the anode and will create a silvery band somewhat reminiscent of the "getter" inside of an old vacuum tube.
Magnetic Deflection:
In physics, we all learned the Lorentz force law ( F = q[E + v x B] ), or the force on a point charge due to electromagnetic fields. In this context, it tells us that electrons will be accelerated from the cathode to the anode due E, the electrostatic field created by the high voltage power supply and that those electrons will also be accelerated by another field, B, in a manner that is dependent on the velocity, v, of those electrons. Since the velocity vectors of the electrons will be pointing roughly from the cathode to the the anode without an external magnetic field, we can use this to find out what effect a magnetic field will have if we introduce one.
Let's say we bring a magnet close to the tube while it's energized and we align it so that its field is roughly normal to the surface of the vacuum chamber. If we compute qv x B, we will find that the force due to the magnetic field is perpendicular to the paths of the electrons and to the magnetic field (by the definition of a cross product). In other words, the magnet curves the paths of the electrons and this effect is amplified by the duration that the electrons spend in the field. This effect can easily be observed inside of our cathode ray tube if a magnet is present nearby.
I've included a diagram of the mechanical construction of the accelerator to give a rough idea of how everything will work.
Visit Our Store »
Go Pro Today »
Thanks especially for including the (non-relativistic) physics background!
for the help,to make this very interesant project.
Very nice project being a person who enjoys High Voltage projects this looks like a fun one.
hope my advice helps :D.
Quite posh indeed sir.
Well done and good luck .
Don't stop doing what you are doing - you will be the first I will follow on Inst'
Aug 15, 2011, whereas this one is dated Apr 21, 2010. Here is the link to the "United Neko Technologies" Youtube video explaining in great detail.
Thanks for you comment!
this is the link to the power supply unit I am talking about ..
http://www.philipharris.co.uk/secondary/electronics-and-electrical-equipment/power-supplies/eht-psu-phe/?ev=search
