DIY LED car headlights!
This INSTRUCTABLE will go through the steps I am going through in the making of homemade fog lights for my car, a Hyundai Atos (sold as a Dodge Atos here in Mexico).
At first phase completion, my first 78 LEDs are dissipating 5.8 watts while my resistors only dissipate 0.85 watts, and the array is already powerful enough to dwarf the two front marker lights, which draw 3 watts each. My final objective is installing, at the very least, 300 LEDs at a total energy expenditure of 21 watts at the LEDs and 3.2 watts at the resistors.
All comments welcome.
UPDATE:
I Can pick the laser cutter up either in Florida or in a couple of addresses in Texas. I'm still on the run!
Here's an index:
Introduction
Step One: Justification and Objectives
Step Two: Exploration and drawing the assembly goals. I decide here to go for two construction phases.
Step Three: I procure the stuff I'll need for phase one.
Steps Four, Five and Six: I build the LED modules, prepare the area to receive them and install them.
Step Seven: I put the first 78 LEDs to a road test.
Step Eight: I put finishing touches to Phase One and start drawing objectives for Phase Two.
Step Nine: Minor improvements.
Step Ten: Brake Lights
Step Eleven: What not to do
Step Twelve: How to do it right.
Step 1Justification and Objectives
It seems silly to me to start working on something before knowing why.
Lets explore why I decided my Atos required more light fixtures:
A) The low beam setting is dim. Not in the sense of 'Wow: that top-end race motorbike emits more light than my car'; no, it was in the sense of 'Man, I'm driving behind a scooter that sounds like a never-ending fart because its light lets me see the potholes 20m ahead.' Matter of fact, some older fellows have told me they can't even tell from the inside if the lights are on or off.
B) The 'high' beam setting legally is a normal low setting, as these are defined by Mexico's Federal Road Legislation: it allows me to see the road just over twenty meters ahead and doesn't bother drivers moving the opposite way.
So yeah, I do feel justified to add more lights to my car.
Now, let's draw some objectives for this project:
A) The new lights should improve my overall visibility; supplementing and eventually leaving my headlights as 'secondary lights' for those times I enter the somewhat more dangerous sectors of Cancun.
B) The new lights should not add further strain to my car's tiny battery, tiny engine and tiny alternator.
C) The new headlights should not draw criminal attention to themselves. This should be achieved through either making them invisible at a cursory glance or by making them obvious and ugly. Personally, I'd prefer not making my car ugly on purpose, so my primary focus should be stealthy design.
D) The lights need a separate control from the default headlights, thus deserving the name of fog lights. This keeps me from being caught with my pants down in case a police officer pulls me over and asks why I'm driving with my headlights off.
E) Whatever the light needs, I cannot modify the aerodynamic profile of the front end. This includes symmetrical work and not blocking enough of the front grid to make the radiator work more than it already does.
F) The arrays themselves have to be designed so they cool themselves on the air. Most people design LED arrays like they were light bulbs, forgetting that LED's are heat-sensitive microelectronics that have to stay below 85Celsius to work their best.
134 comments
1-40 of 134next »
Mar 5, 2009. 8:42 PMitstemo1 says:
OMG... I have been complaining about my head lights for the longest time. They just don't cut it. I use my brights all the time... well just when no one is around. I am so doing this this. And I like how you don't care about modding your car. My car isn't in such a bad state (its been body kit modded) but I am still afraid of having big giant buttons on my dash board. Anyways I am so going to do this!!!!!!!... I hope the Salt, Snow and Water from Michigan doesn't kill my car. Y tu ingles es mucho mas mejor que el mio. Y eso que hablo y escribo ingles todos los dias.
Nov 7, 2010. 9:50 PMBGreenHVAC says:
The plastic outer portion of the headlight lens becomes oxidized, and sandblasted from various debree. This makes the plastic have a yellowish or dull finish.
There is Turtle wax brand headlight restoration kit for about $11 that works great. I used it on two vehicles and had enough left-over for at least one more vehicle.
The kit is for one use. Once the package is opened, it has to be used. The sealant is in a tear open package. It will evaporate and become a dry cloth. I reuse the left over of the other ingredients for future touch-ups. The sealer that dries out can be substituted with Future floor wax. I will need to be reapplied every once in a while, because weather will eventually wash it off.
It is probably the cheapest way to fix the problem. The $11 kit is a fraction of the cost of replacing the headlight lens.
Good luck
Bill
Feb 21, 2010. 1:45 PMjholton says:
If your headlights are dim due to weathering or 'sandblasting' (normal use) like my 2000 Camaro, use a very fine jewelers rouge & cloth Dremel wheel to polish back to gain some more transparency.
Apr 22, 2010. 10:22 PMgrimgroper says:
i plan to get 20x10w 700L LEDs to replace my head lights and high-beams.
LED from ebay:
cgi.ebay.com/20-x-10W-white-High-Power-LED-700LM-light-10watt-20pcs-/120549980213
ill use some sort of lens, possibly the oval one:
www.led-spot.com/p_square.shtml
what is the best way to set it up so that they will be dimmer when the high-high beams are off, then full power when i flick the high beams on? would also like to install some kind of variable resistor so i can adjust the brightness whenever..
correct me if im wrong, but i was thinking to do that id have a few different circuits each with a different resistor in it. then to choose the brightness i would just change between them. would that work?
Sep 25, 2011. 3:44 AMbpfh says:
Sep 25, 2011. 3:42 AMbpfh says:
You may well need active cooling for this then. The higher power the LED, the more heat they generate. If you are driving at a reasonable speed, then OK, a small heatsink will be enough with the airflow, but if you are in traffic, you risk overheating them, and as mentioned in this instructable, either a really shortened LED life (along with chromatic aberations - a.k.a. the led changing colour), or even go to a critical burnout....
For these reasons, unless you make up spares, I would personally go using these high power LED's for foglights/spotlights and install HID bulbs that can be swapped out with regular bulbs if there is failure.
OK, Audi used LED headlights to amazing effect on their Le Mans car this year, but they had a decent stock of spares ;)
http://www.autoevolution.com/news/audi-r18-tdi-le-mans-racer-gets-full-led-headlights-35029.html
Cheers,
Daniel
May 30, 2011. 12:31 AMnerys says:
That is my only problem. HOW to focus the lights. Here is my plan so far
4x6 inche copper slab. on the front a 70mm 20watt 1900lumen LED
on the back 2 massive copper heatsinks. Ram air tubing for cooling while moving though I think I have sufficient copper to dissipate 20watts even without the ram air.
12v to 32 step up converters (the led's are 32v)
my problem is how do I FOCUS the light into a SPOT like a headlight instead of the flood they will be stock.
I checked your led-spot link but it don't work and its non obvious where to go on the site.
any suggestions would be greatly appreciated!
May 30, 2011. 8:23 AMgrimgroper says:
its been along time since ive read that post so iv moved on from those led im not even sure what the brand was... so iv been looking at lower voltage LEDs which make the divers cheaper because you have to have constant current drivers resistors are not a good idea...
iv started a thread on candlepower forums which has been pretty informative. at the moment im basically just playing the waiting game till i have all the information/time/money to start this project
jump on have a read feel free to add anything
http://www.candlepowerforums.com/vb/showthread.php?282539-24x-p7-off-road-light-array-(3x-p7-12v-driver)
May 30, 2011. 10:22 AMnerys says:
Sadly I have found CPF to be 100% useless. They refuse to alter the discussion from "its illegal if not dot approved"
sad that they are the only real LED forum around and they probably HAVE the info that I need.
Mar 24, 2011. 10:06 PMericinthebox says:
this is nice.
I am also getting some LED lights from http://www.ijdmtoy.com for my bike mode
Apr 23, 2010. 8:32 AMgrimgroper says:
ah yeh i know where your coming from with the actuator, good idea, however it would probably be very difficult to get right due to constant vibrations, bumps etc...  i think ill just have to get some smaller more suitable leds for low beams and run them separately..
i have got the heat sink covered, a mate that is in the metal working industry, said he would be able to cnc route out some aluminum for me, ill just have to work out a design for him.
not 100%sure what you mean with the break lights?
Aug 18, 2009. 8:45 AMawupper says:
Looking at the picture of the front of your car. Your stock headlights are dim because the covers are fogged. You need to polish them back to clear. This will make a huge difference in your ability to see.
http://www.automedia.com/Polishing_Plastic__Headlight_Lenses/ccr20041101pp/1
Sep 25, 2011. 3:35 AMbpfh says:
I agree. You seem to have "mercedes headlight syndrome" (I see a lot of Mercs with the same foggy headlights!).
Try and remove the headlights, and rince the inside out with a lot of soap and hot water to remove dust and crud, then leave to dry in the sun.
After that, if you want a real cheap solution, start polishing the glass of the headlights with toothpaste. They should end up much clearer but it takes a lot of effort! (but toothpaste is far far cheaper than commercial glass polishing compound!). A google search for atos headlights turned up this site : http://restoreheadlamp.blogspot.com/2011/01/hyundai-atos-restoration.html (no affiliation with these guys). The results look spectacular!
Cheers,
Daniel
Dec 26, 2010. 7:11 PMBhakto says:
whats the difference in 5mm leds and 3mm leds?
does the 3mm have more range but less angle (zone)but more range (distance)
May 27, 2010. 10:57 AMdiego_sathanae says:
 oye amigo eres de mexico verdad? podrias ayudarme con un proyecto similar es que yo quiero aprender a hacer tiras de leds y la verdad es que la verdad nunca e hecho nada con leds pero realmente tengo la inquietud de poder manejalos algun dia y me parece fantastico tu trabajo. ojala me puedas ayudar te lo agradeceria mucho.
ATTE. Diego Soto A.
Mar 2, 2010. 3:28 PMmickey_079 says:
Hey,
I really don't see the purpose in this mod. I'm not being nasty or rude as I see you did put alot of work into it, but in my opinion... you put too much work into, it doesn't that look that good (especially the interior).
Why didn't you just purchased a HID kit, LED parker globes, and those LED light bars similar to what you see in the Audi's.
But I do have to go you a big thumbs up for the time you have put into it.
Mar 23, 2010. 6:55 PMabadfart says:
That wouldn't be diy  and not all cars will take led kits without mods anyway
Feb 18, 2010. 12:53 PMSwishercutter says:
Having just returned from Cancun (and having spent some time driving in the local chaos) I can see why you need as much light as you can get.  It's a different type of driving down there.
Good work.
Feb 19, 2010. 1:36 PMJohnnyDD says:
 I can see your number plate. someone can easily clone your car numberplate.
Feb 4, 2010. 1:14 AMautomd says:
This DIY looks really tempting to do. I saw several cars near our place that have blue and red LEDs as their lights and it really looks cool.
Feb 16, 2010. 11:06 AMsteveo625c6 says:
Just FYI, Blue and Red LED are illegal! You may only have Blue on your vehicle if it is for emergency/medical use. And red is only allowed on the rear of the car. Go ahead and make this in those colors and let me know how long it takes to get pulled over.
Feb 18, 2010. 12:56 PMSwishercutter says:
In Mexico (Cancun)...I saw tons of blue LED mods.  The taxis are usually the ones with the most LED's (from what I saw).  I saw some pretty creative driving down there...not really sure what it takes to get pulled over.
Feb 18, 2010. 11:03 PMsalobyte says:
si ya le hiciste esas modificaciones, yo buscaria la manera de implementarle un generador de frecuencias (probablemente un 555) para que se vea como los autos lujosos que usan leds en las calaberas traseras ;)... excelentes instrucciones!!
Feb 18, 2010. 9:46 AMcidblacky says:
que tal yo soy de mexico tambien muchas felicidades por tu idea se ven de lujo los de la parrilla yo soy fanatico de los led tambien y me gustaria poder hacer algo similar sin embargo no tengo tanto conocimiento de electronica.
Feb 16, 2010. 11:22 PMArbitror says:
ATV, here I come!
Dec 7, 2009. 5:27 PMKirk says:
http://pdfserv.maxim-ic.com/en/an/AN3256.pdf
you may find it interesting
Nov 16, 2009. 1:56 AMcrash138 says:
 well after finally seeing your headlights I know why you needed the extra lighting... goto walmart and get some of that polishing compound for your headlights!  They are so cloudy you are probably at 10% of what they should be...  Id have just bought some driving lights to put on, but the leds are cool, prolly woulda mounted them in the weather proof boxes, with "Tamiya" style connectors for easy removal....
Oct 15, 2009. 11:01 AMFik says:
Very nice instructable (how didn't I thought this before?).
If it weren't for the restrictions our government puts on internationalpurchases, I would be already online buying a bag of high intensity LEDsto supplement my car's headlights (yellowed plastic and expensive toreplace) and interior lights.
I'm curious, why do you blur your car's license plate in step 2 butleave it visible here in step 7?
Jun 3, 2009. 5:22 PMxxrd says:
instead of using a resistor plus a serie of 3 why don't u plus LEDs in serie of like 8? Furthermore, if a resistor is plugged before, the voltage (12V) for LEDs will drop making less than 3.5 V per LED
Feb 27, 2008. 5:14 AMstevie1 says:
you should blur the license plate numbers
Dec 12, 2008. 6:52 PMbenthekahn says:
why?
1-40 of 134next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:Nachoman
