Step 9The Springs
As an anglepoise lamp, he has four different springs. Two of them connect his Neck together to his upper Mid Joint, and his other two connect his Z bracket to his Leg Joints. Both are extension springs, meaning they are designed to stretch when Luxo Jr is flexed.
Now, to save money, I used the same extension springs as the one my lamp originally came with. I merely cut it into a smaller shape (1'' across for me) and bent a loop at the end using a pair of pliers. I made two of these for the straight bracket.
For the inner, shorter springs, which connects the Z bracket to the Leg Joints, I just used a rubber band. It was really small, so they worked the best.
Add Comment
