So I decided I had to use polycarbonate or acrylic sheet for the job. I heard stories about acrylic sheets melting in heat, solar cells getting destroyed by moisture etc. But I still decided to go ahead with it because it was the simplest, strongest and safest encapsulation I could think of.
The panel cost me around $35 to pack 22 3"x6" cells (.5V x 3A x 22 = 33W). The whole setup can be folded and connected in different ways to charge Li-Ion, SLA or NiMH Battery packs.
Remove these ads by
Signing UpStep 1: Things needed
Optix Acrylic sheet: $28 (32x44inch sheet) cut into 4 - 16x8 sheet and one 1 16x12 sheet. Picked this one up from Lowes and they were kind enough to cut it for free. Thanks Lowes!
Silicone sealant - $6 (This one is from GE and is flexible, clear and cures in 24 hrs)
Rubber electrical tape (optional).
Small 3/8" tile spacers ($2 for a pack of 100).
Some wires.
Visit Our Store »
Go Pro Today »
A good instructable though!
I'm a glass glazier, and have some thoughts. Plexiglass will eventually yellow and become brittle if left to the weather. Another issue is the it will not bond well with silicone. It appears to have worked for you though :)
Thanks for sharing your knowledge.
My problem with glass was that heat resistant glass is expensive and difficult to find and the ones you get at Lowes/Home depot might crack if they are hot and exposed to sudden rain.
