Most of us have an old radio lying around, so I based the $5 price on the cost of purchasing/ acquiring a solar powered garden L.E.D light.
I suspect there are plenty of scrap ones lying around, not working because of slightly corroded battery terminals in damp environments - the solar panel will probably be perfect....
With this Instructable I have left my radio on now for 4 weeks, (12 hours a day) while I work and it has never let me down, even at a reasonable high volume level.
You could either leave the solar radio out on a sunny wind sill as I do or leave it in the sun outdoors - every so often to recharge the battery's.
Remove these ads by
Signing UpStep 1Step 1
1. A portable radio, AM/FM or DAB, (2AA or 3AA battery type).
2. One 4 or 4.5v 80 mA solar panel, prised off from a Solar Light.
3. ideally a BAT43 Schottky diode or Silicone IN4001 (more voltage loss)
4. soldering iron, solder and red and black cable 6" lengths.
5. 2 or 3 NiMh rechargeable batteries (NiCd are ok but not as good) minimum capacity 800 mAh per battery.
Optional - heat shrink sleeving, Adhesive foam strip
This is a very quick project, that can be made in about 2 hours, and helps save the planet :)
This is really a sweet project! I am setting up a workshop in my garage and need to provide some sort of lighting to it. I have a couple options but honestly want to do it as cheap as possible. This idea occurred to me and I am like a very beginner in solar power. What I was wandering if I could take a few of these solar power squares as shown above and tie them together into one big solar panel?
How would it be possible to charge the battery? Can the circuitry work on that? I have placed a diode already on my radio but Im not sure that the current being supplied to my radio would be stored in the battery. Though it's still working on now because my battery is still new, but are we really sure that the battery is are being recharged by the solar?? How did you connect the solar to your battery series or parallel?
Thanks
I'm wondering if the watt requirement of the radio is a function here? I mean is there any limitation in terms of what wattage should the radio has in order to be run by the solar panel model? Reply anyone please.
Thanks for your prompt answer.
Most small diodes that you can get at hobby shops/parts places are only 0.25 watts each. I also wouldnt go over 5v for a 3v system, and no more than 12 volts on a 9v system or it will get hot. Batteries will cook, too.
I got fifty 5W diodes from Digi-Key for five dollars, shipped an hour after I'd placed the order. I cant remember the name of the big elec online seller in the UK. You can make a voltage divider from those with some resistors (plans online)
Ignoring losses:
Watts = Volts * Amps
Amps =Watts/volts
Volts=Watts/amps
You need to use a rechargeable battery to charge when you arent using it, because people forget about voltage drop, and important things like no shadows on the panel at ALL.
You also need to use diodes (check watt rating too) to prevent the battery from discharging when theres low/no light or a shadow on the panel; its STILL a complete circuit and the battery will drain.
People overestimate solar. The dashboard chargers you plug in your cigarette lighter barely do anything (150mA in full sun).
You may want to experiment with rechargeable batteries, use them as you have this hooked up. You will NOT be able to move something like that with a tiny panel like in this IS. Get a panel from Northern, Newegg, other places. The 36" panels I have are 12v and 5watts each. (5w divided by 12volts = 410 milliamps, almost a half amp at 12 volts.
You could build a voltage divider to get the voltage down to what you need, but I cant remember how to calculate the loss in power from the resistors in a VD circuit. I think you can use Kirchhoff's law to calculate it and still have enough to run it without the batteries (but why?)
Most solar projects I see on here SHOULD have batteries in them, but dont. Most panels are FAR oversized, too. The current needed to start a motor can be 6 to 10 times the current needed to run. This could be overcome with a capacitor
Everyone should use batteries in anything solar they have.
